Missing airplane on flight from Penticton to Edmonton
Cliff Jumper
Re: Missing airplane on flight from Penticton to Edmonton
Post by Cliff Jumper »
pdw wrote: Sat Dec 02, 2017 8:27 am It's a good call, when reaching altitude above 8000ft in " lowering vis " at the much higher groundspeed (200kts?) and arriving at turn location ("that first turn"), that would have been (have created) an enhanced circumstance for missing it right there.
English words - yes.
English sentence - no.
It is extremely easy to choose the wrong valley. On my one trip crossing the rocks in perfect weather, I started down the wrong valley, very similar, and only a relatively minor heading difference, to correct valley, for a few miles before realizing the heading did not make sense with the map (I was practising without GPS assistance).
Must be double checking navigation , finger on the map.
pdw
Post by pdw »
RookiePilot wrote:and only a relatively minor heading difference, to correct valley
That makes sense then to retrace the map similar way to pinpoint 'most likely spot" for such nav error potential (as per previous page discussion .. ie "could easily have misssed one of those turns").
One or two track-points from which an error-deviation was more-likely and also passing within Fidelity Mt cellphonetower's service area wherein the ping of the PICs cellphone is being sourced (this being the cellphone service area centered 32km past Revelstoke and 29km past the last on-track radar hit about 2 miles NE of town) can be considered.
EDIT:
I used Nov27th data by mistake, ..on the 25th there was 15kts up there at Mt Des Poilus.
Stallspin
Post by Stallspin »
In that area, with winds comparable to what have been posted here, I've had a lightly loaded sr22 turbo firewalled and still descending at 1500 feet per minute. That experience would have been a lot less fun in a 200hp Mooney.
Does anyone have the ability to post the GFA from that day?
GyvAir
Post by GyvAir »
Stallspin wrote: Sat Dec 02, 2017 4:43 pm In that area, with winds comparable to what have been posted here, I've had a lightly loaded sr22 turbo firewalled and still descending at 1500 feet per minute. That experience would have been a lot less fun in a 200hp Mooney.
Is that what you're looking for?
CpnCrunch
Post by CpnCrunch »
I think it's this one:
http://gfaarchive.info/gfaDisplay.php?r ... Offset=000
I think PDW and CNPC might have been looking at the wrong day. The plane departed Sat afternoon, but you both were looking at the Sun afternoon weather. The weather actually looks fine from what I can see. The only minor concern is that green hatched area, but it would have been easy enough to see if that had been a problem. Only other concern would be that Lee trough which could indicate strong mountain winds, so I'd want to check the upper winds. I'd also want to check weather at Golden and Revelstoke in case that scattered cloud at 6000ft had gotten any worse than forecast.
Diadem
Post by Diadem »
CpnCrunch wrote: Sat Dec 02, 2017 5:59 pm
Scattered 6-8000 in those mountain passes can easily become a ceiling at a couple of thousand AGL locally in the valleys. Add in the conditions in the hatched area, and what you thought might be a nice VFR day can turn into a really bad trip. I've been through that area a lot, including on a day with nothing worse than SCT forecast when I almost got trapped; the clouds aren't enough to form a real ceiling over the whole area, but when you're in a narrow valley you can't really maneuver laterally to get by them like you could over flat terrain. If you don't leave enough room to turn around, you don't have any choice but to continue forward, and if the vis drops you're in real trouble. I personally won't go VFR through there with any forecast clouds lower than the tops of the mountains anymore, and that GFA looks pretty bad to me.
I agree with Diadem. Plus add with that GFA, someone tell me how exactly one is supposed to land in Edmonton? Unless I've misread the map and where I think Edmonton is, looks sketchy.
Trying to fly between those hatched areas....dicey even if clouds remained scattered otherwise.
Checkout the icing and turbulence graph, too.
No thanks for this cowboy. Too much risk.
Let's remind too a chunk of this flight was to be attempted in the Dark. Risk upon risk.
RatherBeFlying
Post by RatherBeFlying »
Mt des Poilus is on the other side of the Columbia Valley, pretty much North of Kicking Horse Pass. Any weather observation there can't really be extrapolated to Roger's Pass. Wind fields change a lot in the mountains.
I'd consider stopping by the Alpine Club Wheeler hut to see if anybody heard an aircraft The ACC national office knows who was booked there. There's also the avalanche control crew and CP. Wouldn't be surprised if SAR's already touched base with them. There are lots of people out and about in the West side of Roger's Pass. Somebody outside should have heard something if they went up that pass unless the wind was howling or a train was nearby.
There's other valleys north and south of Revelstoke where they could have gone up.
CpnCrunch
Post by CpnCrunch »
Diadem wrote: Sat Dec 02, 2017 8:48 pm Scattered 6-8000 in those mountain passes can easily become a ceiling at a couple of thousand AGL locally in the valleys.
Actual weather was scattered at 7000ft ay YRV and YGE. Not sure if there's any weather stations in the passes.
I don't think any of those valleys are particularly narrow, if you stick to the VFR route. I certainly agree that it's a bad idea to go up any narrow valleys in bad weather. Even in good weather it's not a good idea unless you know the area.
CpnCrunch
Post by CpnCrunch »
rookiepilot wrote: Sat Dec 02, 2017 9:07 pm I agree with Diadem. Plus add with that GFA, someone tell me how exactly one is supposed to land in Edmonton? Unless I've misread the map and where I think Edmonton is, looks sketchy.
I'm certainly not suggesting that anyone should go flying in marginal weather in the mountains, and as I said I'd have checked carefully to make sure the hatched area and lee trough weren't an issue before taking off.
Icing isn't a factor here if you're below the clouds, which they would have been in the Mooney (unless utterly insane *EDIT I see they were below the clouds from the track log). Edmonton is in the clear area (go to the regular GFA on Navcanada's site and it will show airport name if you hover over the airport).
I'm not saying that people should necessarily fly in that weather. All I'm saying is that it isn't obvious from the GFA that the weather was really shitty at the time.
I agree that leaving at 2:30pm was a strange decision. It would mean they would barely be out of the mountains by sunset, with no margin for any delay.
Here is the track log:
http://flightaware.com/live/flight/CFES ... Z/tracklog
Looks like their last radar track was a slow circling descent over Revelstoke. Presumably they were ducking under the clouds at 7000ft, and were below radar coverage after that. (I assume they could have easily made the field if it was an engine failure or other emergency).
cncpc
Post by cncpc »
Nothing on the Flight Aware links.
CpnCrunch
Post by CpnCrunch »
cncpc wrote: Sun Dec 03, 2017 12:53 am Nothing on the Flight Aware links.
Link seems to work for me, but you can just search for CFESN on flightaware to get it.
Pratt X 3
Post by Pratt X 3 »
CpnCrunch wrote: Sun Dec 03, 2017 8:56 am
You'll need an account with FlightAware to see it since it is a Position-Only Flight and you can only select that option with an account. It can be found under the My Account tab > 6 Position-Only Flights. VFR flights usually only show up if they have ADS-B Out or flight following has been used (i.e. transponder code assigned and entered in the ATC system).
When this option is activated, you can see additional flights for which FlightAware does not have a filed flight plan.
Tracking data for position-only flights is incomplete and potentially inaccurate.
Have Pratts - Will Travel
cncpc
Post by cncpc »
Pratt X 3 wrote: Sun Dec 03, 2017 11:25 am
I have it now, thanks. Anybody got the 4 pm MST Metar for Revelstoke that day?
It seems that Revelstoke was an enroute waypoint as the route is sort of direct there, and always to the northwest of the direct track between Penticton and Edmonton.
CpnCrunch
Post by CpnCrunch »
cncpc wrote: Sun Dec 03, 2017 5:18 pm
Sorry, I didn't realise about needing an account on flightaware to see that. I was wondering why it said the flight was hidden, but I could see it (I was logged into flightaware).
If you google "ogimet metars" you can search back for historical metars and tafs. I think it was saying scattered at 7000ft at the time, and the track data shows them descending below 7000.
Notapilot1
Post by Notapilot1 »
Based on all the information posted here, is there a possibility of some location suggestions? There seems to be a lot of “I wouldn’t have done that” but the knowledge from the posts I’ve read seems abundant. Compiling all the information; weather, winds, speed, ceilings, cell phone pings, routes, etc. Where could they be?
I have seen what areas have been searched but there’s always doubt of course, that SAR could be missing something.
Thinking like a pilot, where would you have gone?
ska
Post by ska »
Hi there, I'm a reporter with CTV Edmonton. We are reporting on the missing plane, and I'm interested in speaking with a pilot about this situation. If you have a moment, would you please be able to reach out today? My email is shanelle.kaul@ctv.ca.
Thank you.
CpnCrunch
Post by CpnCrunch »
Sadly the search is ending if they are not found today:
https://www.castanet.net/news/BC/213157 ... ane-ending
It's certainly an eye opener that we have had 2 planes go down in the mountains this year and we have no idea where they are. ELTs are very unreliable, cellphones can't be relied on, and radar tracking only works if you're up high. Once you're on the ground your plane is virtually invisible under the trees. You really need a SPOT or similar device if flying in remote terrain.
Notapilot1
Hello,
I had tried posting a question earlier but it I am unsure if it went through or if it wasn't approved by a mod for some reason. Anyways, here we go again.
I am seeing a lot of great conversation here about potential location possibilities. Taking all of the environmental factors, plane make and model, experience, weather, etc into consideration is there a consensus as to where they might be? I do have more information if needed, and I feel that the knowledge base here is pertinent to recovery efforts. Experience and pilot train of thought is crucial to the efforts being made (in my opinion.)
SAR is no longer looking and family and friends are relying on public assistance from here on out.
CpnCrunch
Post by CpnCrunch »
Notapilot1 wrote: Mon Dec 04, 2017 11:49 am Hello,
The news stories say they think the most likely location was between Revelstoke and Rogers Pass. That would make sense, as it would be the most likely route they would fly. The cellphone ping at night (if that is correct) seems pretty definitive proof that they crashed in that area and that at least the cellphone survived.
P-40
Post by P-40 »
The search team has been overflying the areas where the pilot's cell phone registered a ping to a nearby tower and where their suspected route took them. A flight plan was not filed which exasperates things further. Finding a light GA aircraft in the mountains really is like searching for a 'needle in a haystack'. There are so many visual difficulties that make finding a downed aircraft in the mountains near impossible, especially this time of year with the addition of snow. The rocks are good at hiding things, sometimes forever.
I hope for the sake of the family and friends of both pilot and passenger that the aircraft is eventually found.
P-40
Post by P-40 »
CpnCrunch wrote: Mon Dec 04, 2017 11:38 am Sadly the search is ending if they are not found today:
You're so right. I never obtained my Mountain endorsement and have no plans to so have no relevant mountain flying experience to speak of. However, a fellow pilot I know who travels across the rocks frequently does not leave the ground without his SPOT. For a relatively inexpensive piece of equipment, it can be extremely invaluable and perhaps lifesaving if you go down.
I very much second this, to the point of saying that if a pilot won't equip themselves with this simple, low cost equipment, which would greatly affect the size of search areas, should those large areas be being searched at taxpayer expense. Other jurisdictions are not so giving of search resources.
For those who have not seen/remain unconvinced, the person you appoint to follow your progress, gets a computer screen showing where you have flown, like this:
Wherever the last SPOT mark is, is where you were within the last ten minutes. If your line of SPOT marks is straight, ahead from your last waypoint for ten minutes worth of flying is the first place to search. If the SPOT was destroyed in the crash, 'doesn't matter. 'Makes searching kinda straight forward!
Millions would have been saved had MH370 had one!
piperdriver
Post by piperdriver »
CBC is now reporting the search has been called off.
https://www.msn.com/en-ca/news/canada/a ... spartandhp
