Atlas Air 767
av8ts
Re: Atlas Air 767
Post by av8ts »
Something tells me that this investigation is going to go quiet til the final report
Heliian
Re: Atlas Air 767
Post by Heliian »
sounds like the autopilot went into antistall or go around and the elevator failed.
Turbulence broke the old plane and it crashed.
telex
Re: Atlas Air 767
Post by telex »
Heliian wrote: Wed Mar 13, 2019 7:32 am sounds like the autopilot went into antistall or go around and the elevator failed.
Can you expand on the antistall system and it's operation?
Is go around also a function? 6000' seems like an odd place for a go around?
Heliian
Re: Atlas Air 767
Post by Heliian »
telex wrote: Wed Mar 13, 2019 7:45 am
no, i was just making something up as per the previous comment.
However, the quick release from ntsb said they hit turbulence and shortly after nose dived.
Why else would throttles go full?
telex
Re: Atlas Air 767
Post by telex »
Heliian wrote: Wed Mar 13, 2019 8:57 am
Does turbulence and a nose dive usually command full thrust?
I think it would be unusual for autothrottle to remain at full thrust in a nose dive?
lostaviator
Re: Atlas Air 767
Post by lostaviator »
telex wrote: Wed Mar 13, 2019 9:02 am
telex wrote: Wed Mar 13, 2019 7:45 am Can you expand on the antistall system and it's operation?
Unless it was intentional.
goingnowherefast
Re: Atlas Air 767
Post by goingnowherefast »
Power causes most aircraft to pitch upward. Flight control problem, can't control pitch, so worth a shot with power. I could see it as a last ditch effort to try and save the day.
Hypothetical discussion, I know nothing of the actual details.
C-GGGQ
Re: Atlas Air 767
Post by C-GGGQ »
LETUN wrote: Tue Mar 12, 2019 8:48 am From NTSB, released today:
. Shortly after, when the airplane’s indicated airspeed was steady about 230 knots, the engines increased to maximum thrust, and the airplane pitch increased to about 4° nose up and then rapidly pitched nose down to about 49° in response to column input. The stall warning (stick shaker) did not activate.
FDR, radar, and ADS-B data indicated that the airplane entered a rapid descent on a heading of 270°, reaching an airspeed of about 430 knots. A security camera video (figure 4) captured the airplane in a steep, generally wings-level attitude until impact with the swamp. FDR data indicated that the airplane gradually pitched up to about 20 degrees nose down during the descent.
Seems to say it all right there....
ReserveTank
Re: Atlas Air 767
Post by ReserveTank »
C-GGGQ wrote: Wed Mar 13, 2019 3:27 pm
Possibly left the speed brake deployed from the crossing restriction. What speed does the 767 maintain if doing a LVL CHG? 245?
telex
Re: Atlas Air 767
Post by telex »
ReserveTank wrote: Wed Mar 13, 2019 3:54 pm
It maintains whatever speed is selected in the speed window.
C-GGGQ
Re: Atlas Air 767
Post by C-GGGQ »
It was the 49 degree nose down in response to control input. Not the 230 kts I was pointing to...
Re: Atlas Air 767
I have been worried about this.
Heliian
Re: Atlas Air 767
Post by Heliian »
If you read the previous posts or reread the current linked article it was changed to read "elevator deflection" and not "column input".
If it was intentional, I'm sure you'll hear the other two people in the cockpit fighting it and case closed. If you hear all 3 wondering what the @#$! happened, then it would be something else.
Bede
Re: Atlas Air 767
Post by Bede »
This accident has me worried. Jump seater from other airline. Reminds me of fedex in the 80’s. I really hope that my fears are wrong.
telex
Re: Atlas Air 767
Post by telex »
Bede wrote: Thu Mar 14, 2019 6:12 pm This accident has me worried. Jump seater from other airline. Reminds me of fedex in the 80’s. I really hope that my fears are wrong.
The jump seater just got hired at a major (American?) and was supposed to start ground school shortly.
ogc
Re: Atlas Air 767
Post by ogc »
telex wrote: Thu Mar 14, 2019 6:23 pm
United. They gave him his wings and left his seat empty in the class.
Gino Under
Re: Atlas Air 767
Post by Gino Under »
Looks like pilot induced loss of control.
Old fella
Re: Atlas Air 767
Post by Old fella »
Gino Under wrote: Fri Mar 22, 2019 6:23 am Looks like pilot induced loss of control.
Elaborate and the source?
telex
Re: Atlas Air 767
Post by telex »
Take it for what it's worth...
"Got this info from my airlines unofficial forum. Unofficial of course .
The initial bobble is from turbulence at 6200’. When the FO called for flaps 1, the captain accidentally hit the toga button. Toga didn’t engage until after flaps were set to 1, which then brought engine power to full, and started the initial pitch of 10 degrees nose up. The FO was startled, and shoved the nose forward... The CVR is startling, and baffling. The CA was pulling so hard against the FO that he sheared the pins on the stick and at that point had no control. They were IMC at the time. When they broke out into VMC, the FO said oh schit and started to pull. That was the round out you see. I won’t get into anything more until everything comes out. The records, the CVR, and what happened in the flight deck is truly shocking. They hit a negative 4 G dive initialy on the FOs push. All you hear is stuff hitting the ceiling and at one point a loud thud. They think the thud may have been the JS hitting the ceiling and maybe not wearing the shoulder harness. Like I said, I won’t get into anything more about the background of how it all happened. This is the accident in a nutshell. The facts that will come out are shocking."
C-GGGQ
Re: Atlas Air 767
Post by C-GGGQ »
Same being reported by wall street journal, business Insider etc. Just not in quite that graphic detail.
tbaylx
Re: Atlas Air 767
Post by tbaylx »
telex wrote: Fri Mar 22, 2019 9:52 am Take it for what it's worth...
How does one accidentally hit the toga buttons going for flaps?
FL_CH
Re: Atlas Air 767
Post by FL_CH »
The switches do happen to be on the backside of the throttle levers on the 767:
ReserveTank
Re: Atlas Air 767
Doesn't the 767 have a "Go Around" annunciation or something similar on the PFD?
C-GGGQ
Re: Atlas Air 767
Post by C-GGGQ »
That seems like an awkward set up for the toga switch...
telex
Re: Atlas Air 767
Post by telex »
ReserveTank wrote: Fri Mar 22, 2019 10:34 am Doesn't the 767 have a "Go Around" annunciation or something similar on the PFD?
GA will become active in pitch and roll. Annunciated on the Flight Mode Annunciator.
