Calling level
charlie_g
Post by charlie_g »
Pygmie wrote:
pelmet wrote:Actually, . . . I do give my altitude when checking in on a new frequecy. Everyone seems to do that, even when it is busy.
And it's a good thing too, as if you didn't controllers are required to ask for it, otherwise the altitude readout on the radar is rather useless.
Indeed. You should include the alt on check-in, for validation purposes, and to make sure there wasn't a screw-up when the alt was passed to that sector by the previous controller. In this case you need to make the check-in transmission anyway, so the extra 1 second isn't really a waste. Otherwise I wouldn't get my gitch in a knot over it. Highly unlikely someone's going to hassle you for not making the call.
Notice that the first sentence from the AIM says ""Pilots shall report reaching the altitude to which the flight has been INITIALLY cleared. "
What do they mean by "initially"?
Canus Chinookus
Post by Canus Chinookus »
good question.
swordfish
Post by swordfish »
yeah...that's a tough question...
...for those who are not instrument rated
Well tell us what it means Swordfish.
swordfish
Post by swordfish »
When you take off for higher altitudes, you are sometimes cleared to the ceiling of the departure controller, not your final requested altitude.
e.g. a SID may limit you to 7000' off Calgary or Edmonton. The terminal controller will then clear you to some altitude in their sector (depending on traffic), then you get handed to an enroute controller where you finally get your flight-planned altitude.
Of course if there are no traffic conflicts, you might get cleared to your cruising altitude right away.
The altitude you get cleared to initially either by SID of the terminal controller is your "INITIALLY cleared altitude".
When leaving Grande Prairie, for example, you will frequently get: "Cleared to 11 thousand, expect higher enroute". If you have a comms failure there are procedures that cover this so you don't run out of gas at too-low an altitude.
It appears that way. Why it would be that way, I don't know.
cyyz
Post by cyyz »
Got a CARs link?
charlie_g
Post by charlie_g »
cyyz wrote:Got a CARs link?
Curiously, I was told (but have not verified it myself) that the requirement to call level does not appear anywhere in the CARs -- that it is an AIM thing only.
Canus Chinookus
cpl_atc wrote:
swordfish wrote:The altitude you get cleared to initially either by SID of the terminal controller is your "INITIALLY cleared altitude".
I'd never noticed that in the AIM before. I don't know why it would refer to "initially cleared" either. The call is no more or less valuable to a departure controller as it would be for en route, so I have no idea why they would make that distinction.
RAC 8.4 off the top of my head.
Thanks for the replies.
