Single Pilot IFR Advice- Discussion
Redneck_pilot86
Re: Single Pilot IFR Advice- Discussion
Post by Redneck_pilot86 »
GYQA wrote:
Water off wrote:The 50 hour requirement is only for revenue passenger flights. If you are flying cargo or just flying company personel around non-rev, you can do it single pilot.
Can you show me in the cars if the autopilot is still required if it is cargo only?
Additional Equipment for Single-pilot Operations
702.43 No air operator shall operate an aircraft on a single-pilot operation in IFR flight unless the aircraft is equipped with
(a) an auto-pilot that is capable of operating the aircraft controls to maintain flight and manoeuvre the aircraft about the lateral and longitudinal axes;
(b) a headset with a boom microphone or equivalent and a transmit button on the control column; and
(c) a chart holder that is equipped with a light and that is placed in an easily readable position.
Assuming you are flying cargo for hire, I don't see how the above can be interpreted as not needing an autopilot. A non-rev flight I suppose you could as it would fall under 605.18 which does not list anything regarding number of crew.
KAG
Post by KAG »
SPIFR is only as safe as the properly equipped machine your in and being properly trained.
Organized, staying ahead of the plane, not exceeding your limits and flying safely you shouldn't have any issues.
Don't be afraid to ask the more experienced pilots tips and know when to say no.
Chase lifestyle not metal.
skymarc
Post by skymarc »
SPIFR is perfectly safe with a well equipped aircraft and a well trained current pilot.
