tools for an AME apprentice
Re: tools for an AME apprentice
those leatherman's are junk IMHO. get yourself something similar from victorianox, farrrr better quality.
i skimmed the list so far and i didn't see drive adapters. ie 3/8 to 1/4, 1/4 to 3/8, etc etc etc. i have a whole pile of them. also i would suggest flex sockets in 1/4" drive, a good mirror, and a rechargeable flashlight....one that uses the same batteries as your cordless drill. and lots of different length extensions, i suggest snap-on wobble extensions, they're the only ones i even use any more.
I hope this is a joke...all the Leatherman's I've owned in all of my years have never let me down, excellent quality, 25 year warranty, how can you go wrong.benchmark wrote:those leatherman's are junk IMHO. get yourself something similar from victorianox, farrrr better quality.
I'm still using the Leathermen I bought 17 years ago.
The Victorianox I bought four years ago broke and couldn't
get it replaced. Something about it not being meant to be a
hammer I think was the reason. I've used my leatherman as
a hammer and it still works!
mcrs
mcrs
.... Maintenance is a science since it's execution relies, sooner or later, on most or all of the sciences. Lindley R. Higgins Maintenance Engineering Handbook; Mcgraw-Hill, NY, 1990.. Look ma, I'm a Scientist!
black hole
Hammers. A good mechanic has to have hammers.
Most things can be fixed with hammers.
One way or another
BH
One way or another
BH
tired of the ground
Hammers are for carpenters.
AME's require calibrated tap-o-meters
I've talked to some guys at the workplace, they say a good deadblow and brass mallet are good to have.
edited
Even the torch (flashlight) can be used as a hammer thus the name flashenhammer.
And the Philips #1 makes a good center punch tool too!
- FreaKy_DeaKy
a box of gloves from all the chemicals your going to use and a 3M respirator
it'll save your life slowly, good luck
- FreaKy_DeaKy
singleburner
I would hold off buying tools until you figure out where you are going to work. You could end up working on a swing wing, and need to buy a whole wack of metric stuff.
A good rule of thumb I like to tell apprentices is, if you borrow something more than once, buy it.
I do however recommend a Snap-On ratcheting screwdriver...
- Flash Gordon
I know this has been mentioned but since I have started as a new apprentice and mostly held off on buying tools til I get a feel for what I need(except for the obvious basics).When asked the most common answer from engineers is the Plier Wrench from Knipex.
http://www.knipex.com/index.php?id=65&L=1&L=1
and from my short experience also
cordless drill,a nice mix of lightweight and power,definately with torque settings
a really good easy-out combo,drill bit on one end left hand thread on the other,for stripped fasteners
anything wobble is good to have in your box
headlamp
just a cpl more items for ya...
headlamp
on the subject of knipex i purchased the whole set for what snap on sells em for from these guys
http://chadstoolbox.com/
specifically
http://chadstoolbox.com/index.asp?PageA ... ProdID=198
specifically
