Impulse coupling, that's the term I was looking for
The vast majority of light aircraft use impulse coupling magnetos
for starting. Shower of sparks is comparitively rare.
More trivia: most engines only have ONE implulse coupling magneto,
on the left side. When you are cranking, the switch grounds out the
right mag, so it can't fire BTDC and make the engine kick back.
Only having one impulse coupling magneto means that only one
spark plug is firing, in each cylinder, as compared to 2 when it is
running normally.
Our Maule has, somewhat unusually, two impulse coupling magnetos,
which probably explains why it's TCM IO-360 is so easy to start
in comparison to some other engines which are complete pigs to
hot start.
But back to the majority of the fleet, which only have impulse coupling
on the left mag. Some day, you are going to fly an aircraft which
does not have the industry-standard Bendix ignition switch - it might
have individual switches for magneto on/off like the Citabria or Decathlon
or Maule or PT-19 Cornell. The list goes on, and on.
If you are starting an aircraft which has such manual control over
magneto on/off (ie no Bendix switch) then be sure to select ONLY
left (impulse couling) mag on, for starting. After starting, turn on
the right (non-impluse coupling) mag.
If you do not do that, you may get kickbacks if the right (non-impulse
coupling) mag has enough RPM to fire at the normal 20 to 30 degrees
before top dead center.
A little systems knowledge really pays off. I know I'm a ridiculous
gearhead - I've been working on piston engines since the 1970's - but
there are some operational details that pilots should be aware of.
