snoopy wrote:@swordfish,
Interesting. I would bet your comment about Ops making the decision is correct. If true, how then does it work with a large carrier, if (and assuming it is safely within the aircraft performance envelope to do so) for safety reasons the crew elects to ignore the "recommendation" from Ops and land as is, where is? If S/E ops are a non-issue (and assuming no loss of critical services), does that mean that CFR capability or lack thereof at the landing site bears no significant weight in the decision making process?
As pointed out by subsequent posters, it was an assumption that SOCC made the decision (which of course can always be countermanded by the Captain...but why would he want to?), not a fact. My LIMITED experience in 705 is that with Class A or B dispatch, SOCC is as much a part of your crew as the F/O and the cabin crew. It would be a synergistic approach to the problem at hand.
While my contention is that an engine out a no-brainer, it
IS an emergency, and Yes, CFR would have to be notified with the high-speed landing, limited flaps, no reverse, and brakes only, and a crosswind from the wrong side.
btw...here are some "brainers" (i.e. some things that the QRH/SOP does not provide for)
- Fire in the baggage or cargo that cannot be extinguished.
Unexplained vibration in an engine when all your indications are normal (including prop deice).
Outflow and dump valves frozen closed (recognized in the types that have a delay before pressurizing after takeoff), or a loss of vacuum (moisture frozen) in that line from the pressurization controller. Yes I am aware that the QRH will say close the bleeds; but when you took off from Rankin below the landing limits, and your destination is Yellowknife, Baker is your takeoff alternate, you have a mountain of conflicting decisions on your hands. Nothing is cut-&-dried, believe me.
Noxious unidentifiable fumes from the cargo or in the ventilation system, and you can't determine which.
Elevator trim frozen or immobile.
Flying with one engine operating on the fuel topping governor.
Windshield anti-ice not working on 1 side, and a limits approach coming up.
Ice all over the plane, and you've passed your PNR.
There are many others - I just can't remember them all right now.
