Cherokee spins?
- Shiny Side Up
Re: Cherokee spins?
Its possible you might need multiple airplanes.
carbeerater
Re: Cherokee spins?
Shiny Side Up wrote:Its possible you might need multiple airplanes.
Sorry ssu, one at a time... it's gotta do both or I need to win the lotteryCriteria: Fully aerobatic
Functional cross country (2 up with let's say minimum 300nm range)
Float and ski capable as a bonus?
I_Drive_Planes
Re: Cherokee spins?
My airplane is a Cherokee C (1966) and I do believe I've seen a Cherokee B, but I wouldn't put money on it.Shiny Side Up wrote:(I don't think there was a Cherokee "B" or "C")
- Colonel Sanders
Re: Cherokee spins?
Super D is close. Skis but no floats.Criteria: Fully aerobatic
Easy to land.
Re: Cherokee spins?
I imagine that only a Citabria would meet this list - Citabria read backward is?....Criteria: Fully aerobatic
Does this aeroplane exist?
It will not be possible to have a plane which is good for all of these things. You'll find good at one, and marginal at the others, or compromise all the way around. A C-150/152 Aerobat would be the compromise all the way around (but no floats or skis).
Though I have no recent experience maintaining them (so I don't know the parts availability), I liked the Tomahawk for simple, versatile and cheap, as long as short unpaved runway operation was not on your wish list.
Historically, as the FAA moved away from spin training, the American aircraft manufacturers moved away from spin certifying their planes - it was simply easier. Bear in mind that every certified single engine aircraft, right up to the Caravan has demonstrated spin recovery to be certified, though that does not mean they get spin certification - that is much more rigorous testing. Non spin approved aircraft can be recovered from a spin, though with a much lesser margin of safety.
Grand Caravan at gross weight - 9200 FPM peak descent rate, 2.8G AT Vne to recover - 10 times that day, for certification testing....
[youtube]https://www.youtube.com/watch?v=zjB_q7AIvDo[/youtube]
- Pop n Fresh
Re: Cherokee spins?
Which is the best Kawasaki?
I want to do this.
I don't want to edit this but I suppose I should. Sorry I originally posted some dummies ripping around on public roads. I feel remorse.
And this.
I want to do this.
And this.
Re: Cherokee spins?
Edited, my comment is no longer relevant.
- Pop n Fresh
Re: Cherokee spins?
Interesting direction you took that.
I merely googled "mud bogging" then YouTube searched "porsche 911 cornering".
Point narrowly missed by you like the on coming traffic in the video was...
Sometimes you need a different unit to attempt a speed record at the salt flats than the one you would use to move a refrigerator.
- Shiny Side Up
Re: Cherokee spins?
You could do one, then the other. You know, get an acro plane, fly the hell out of it, then get a cross country machine. OR the other way around, which you might want to do if you still have kids who fit into airplane seats, fly them all over the place, then when they're too cool to be seen with Dad, get an acro plane. Many solutions! Maybe get an acro plane, and rent a cross country cruiser when you need it. Maybe buy both and lease them to a school so they don't cost you as much. Get creative! Maybe buy shares of both, get some like minded fellows who want access to both.carbeerater wrote:
- Pop n Fresh
Re: Cherokee spins?
I'm surprised at how bitterly annoyed I am about that lecture. Too bad you were not around when I was cleaning trout for the first time to drone on about knife safety. Giving examples of real life cuts you've seen.
Re: Cherokee spins?
Lots of good discussion here about responsible flying, and safety, and that's great.
Re: Cherokee spins?
I have resigned myself to a number of things ...
1) there is no perfect all singing all dancing airplane,
2) to get what I want, I would need 3 or 4 airplanes,
3) bank account does not support 3 or 4 airplanes (barely supports one)
On the plus side, if the lotto ever hits I know how I will store my 3 or 4 airplanes.
https://www.youtube.com/watch?v=fnI9-dltQcI
- Shiny Side Up
Re: Cherokee spins?
I would say that if you are going to go through with the financial drain of owning an airplane, buy what you can afford and fly the most. Don't buy an airplane for a once a year mission. If you want to fly acro once a year, but fly across the country 20 times a year, then don't worry about your missed acro, enjoy what you can do. I see so many airplanes that were bought and sit since the mission they were bought for only happens once in a blue moon. Pilots have the bad tendency of wanting way more than they need, then not being able to use it. Their wife won't go, their kids won't go, they have no friends. Ninety percent of pilot/owners are going to fly most of their time with at most one passenger for less than an hour.
Tailwind W10
Re: Cherokee spins?
I don't know if it's an option for you, but I believe an RV homebuilt would fit the requirement. RV-6 or -7 for sideby side seating, or RV-4 or 8 tandem seating. (The RV-9 and -10 aren't aerobatic, not sure about the -12 and 14)carbeerater wrote:Shiny Side Up wrote:Its possible you might need multiple airplanes.
Floats: Why not!
http://www.clamarfloats.com/downloads/0711_feature.pdf
https://www.youtube.com/watch?v=qPvBZJXJvS0
I haven't spotted one on skis, but it's experimental so why not be the first?
There are plenty other homebuilt designs that have legitimate cross country capability, and some basic aerobatic abilities as well, a couple more that come to mind are Thorpe T-18,Mustang II, and GP-4, but a bit of research would bring up more options. Needless to say purchasing an experimental would require a good deal more research and inspection than a certified airplane.
Gerry
- Pop n Fresh
Re: Cherokee spins?
And I suppose if I'm going to be honest I have certainly endangered people with my irresponsible operation of ground transportation units. As a "professional driver" and unwitting father/mentor, I like to think that's in my past. Maybe I subconsciously know it's not.PilotDAR wrote:Lecture not so much intended as a reminder of consistency. Lots of good discussion here about responsible flying, and safety, and that's great. Anyone here who describes (or worse admits) poor judgement or airmanship here is opening themselves to criticism. Fair enough, but the attitude to responsible operation should extend beyond just airplanes, to become a culture, rather than "Okay, I'll be safe, now I'm flying".
As for mud bogging - yup, I've had my ATV up to its fenders a few times. I was surrounded by my mates, with their winches at the ready. Neither speed nor non participant motorists involved!
Yes, I do now see your point about different vehicles for different applications, fair enough. Perhaps the hard cornering on a closed course (that one in every TV ad for a car) would have allowed me to focus. Sorry....
More so I feel defensive about my imagined heightened degree of level headed safe choices when I fly.
I'll have you know the safety of my aircraft and crew are my top priority every time I fly!
