Identify This Aircraft
Pirate Pilot
Re: Identify This Aircraft
It pays to friends in "high" places. Just love those staggerwings. D17S Pratt&Whitney 985 CF-BKQ Whitehorse, Yukon. Something about the difference in the engine cowling length and shape and the fairing into the fuselage?? Denotes the model letter??
Meatservo
You guys will never guess what this is:
- plane 2.jpg (30.17 KiB) Viewed 1904 times
- plane 1.jpg (86.39 KiB) Viewed 1904 times
linecrew
Travel Air converted to run on steam power known as the Besler steam plane?Meatservo wrote:You guys will never guess what this is:
Youtube link
- Siddley Hawker
Meatservo
Bah!
Correct on both counts. Except they called him a "stoker".
Lost in Saigon
Looks like a 3/4 scale home built replica.....
(but he forgot to install the struts and bracing wires)
Old Dog Flying
That big yellow BE17 look alike is 985 powered and all composite construction kit plane..but I can't think of the name...
Clearly inspired by the Staggerwing, it is indeed a kit-built aircraft. Designed to carry six people at 190-kt cruise, with a mid-50 kt stall speed. It is powered by the Pratt & Whitney R-985 450-hp radial. The kit is no longer in production. I'll let you determine the identity.
- RenegadeAV8R
imarai wrote:Clearly inspired by the Staggerwing, it is indeed a kit-built aircraft. Designed to carry six people at 190-kt cruise, with a mid-50 kt stall speed. It is powered by the Pratt & Whitney R-985 450-hp radial. The kit is no longer in production. I'll let you determine the identity.
It is a Lionheart
The picture was taken from this website http://www.griffon-aerospace.com/lionheart.html
- YYZSaabGuy
Old Dog Flying
Above
fighter" is a much modified T-6/Harvard built for the Commemorative Air Force's Tora, Tora, Tora display
linecrew
Yep! To be specific it's a (or was a) Canadian built Harvard Mk.IV.Old Dog Flying wrote:Above
- Rank Moderator
Anything, as long as it's steam-powered, hey?!Meatservo wrote:You guys will never guess what this is:
Meatservo
Well old friend, as you're no doubt aware, steam power has the advantage of consistent power output regardless of density altitude. The downside is, that output is quite small.
Moose47
"Yep! To be specific it's a (or was a) Canadian built Harvard Mk.IV. "
Actually it's Mk. 4 built by CC&F (Canadian Car & Foundry of Fort William, Ontario. It's manufacturer's designation is CCF-4. The R.C.A.F. had done away with Roman numerals being used to distinguish the Marks (Mk.) of new R.C.A.F. aircraft types prior to the introduction of the Harvard Mk. 4 to service with the R.C.A.F. on the 2nd of November 1951.
Cheers...Chris
Cheers...Chris
- Siddley Hawker
Old Dog Flying
Curtis C-46..although the cockpit/nose doesn't look right.
Lost in Saigon
Only 17 C-46E models were built with a "Stepped Nose" and squared off wing tips.
- Siddley Hawker
Correct LiS, you're up.
And you didn't get the answer from the properties function of the pic either.
- Tubthumper
Lost in Saigon
Old Dog Flying
