Dreamliner Down in India
cdnavater
Re: Dreamliner Down in India
Post by cdnavater »
scdriver wrote: Wed Nov 26, 2025 2:14 pm I genuinely can’t tell if I’m fckn dense or if these posts don’t make much sense…
It’s not you, no one seems to be able to make sense of the gibberish that pdw posts, I assume it makes sense to he/her/they/them.
The one thing you need to consider is that this poster has zero relevant experience to the events he posts about, he has a fixation with wind and quite possible experienced an incident caused by wind that perhaps caused a TBI, then you begin to understand!
Nauclerus
Post by Nauclerus »
pdw wrote: Tue Nov 25, 2025 5:22 pm In researching it became clearer that this aircraft’s flightpath transitioned from V-1/V-2 in a runway headwind to more-like tailwind by 200agl into/closer-up-to drier/hotter inversion (narrow transition / coolest at the surface).
Looking at the smoke plume, the upper wind appears to continue to follow the same direction as it was on the ground, at least to the approximate height the aircraft was able to climb to.
171 Smoke.png (108.99 KiB) Viewed 5064 times
cncpc
Post by cncpc »
cdnavater wrote: Wed Nov 26, 2025 5:35 pm
PDW's OK. But you're not wrong in your critique.
Dias
Post by Dias »
It is in bad taste to troll post on such a tragic event.
pdw
Post by pdw »
The photo above, also a fair distance, is very low smoke, taking a real close look (doesn’t show ANY opposite smoke though because smoke still too low there, maybe well after). The camera is facing toward/into that smoke, camera facing basically SouthWest.
The shear rate IMO is only very significant for just those few minutes around this tragic take-off. A smoke photo on Aviation Herald’s site (mentioned earlier in this thread) is very soon after the impact, “from a distance”, facing mostly North, appears to barely capture the two nearly opposing directions; the 8:00z metar (8minutes prior) indicated surface reading was 7kts 20degrees off the beak closest to that take-off time (worked out to 6.58kts rwy-headwind). The opposing direction air above 200agl (aforementioned), ie the real hot dry air moving in from east/higher-ground … still requires some interpolation to prove accurately (lndore wx-hist/East .. 12mph/ene)
In the hour of this accident, just after high noon, the extreme hot dry air is moving in steady from ENE (along the north/ne side of an eastward moving low pressure centre situated well SE of VAAH ) … the hottest in India
in 2025 (118.4F).
A shear rate, is expressed in knots per 1000 feet. To compare with other shears one would have to multiply any potentially provable negative shear-numbers here by a factor of 5 (what ever they actually were in just these approx 200 feet above ground level of this aircraft).
pdw
Post by pdw »
Nauclerus wrote: Wed Nov 26, 2025 6:40 pm
Did not see it right away, that the impact smoke on this photo is up to 4000 meters away and SW of the camera (the AC on the pic is ready to roll rwy23?). An illusion of being higher due to the distance; rising toward east at shallow angle. After the accident 3knots/240 reported, later 2kts, meaning this photo at least 20 minutes later …smoke has travelled slow/low for that great a distance, maybe not as accurate a marker ….
DanWEC
Post by DanWEC »
I am so utterly, fist fuckingly confused here... is your working theory that some sort of extremely (so much so as to be undetectable) minor atmospheric anomaly could have the same catastrophic end result on an airliner as shutting down the engines?
pdw
Post by pdw »
The warmer inversion air above is travelling almost directly opposite here (rare I might add) and is still capping the 98F cooler air beneath it that we see there moving toward the camera, preventing it from rising ….in the photo above. The shear-effect would be more than one might think; it is just fact (clear to me) that it is there as a factor. What was going on with the engines is separate, happens at the same time, but it is still (must be) a separate issue.
(So much as to be undetectable)
This very dry inversion air (hottest ever) would be mostly tailquartering relative to the aircraft once it got high enough with sky above remaining clear, but then no condensation is possible to form cloud in that airport area at that time. So yes, it is invisible, “undetectable”, unanticipated and unexpected.
SpyPilot
Post by SpyPilot »
You've been away for a while and now reappear to the forum with an even more baffling degree of gibberish.
Complete and utter nonsense, especially with regard to this crash.
Old fella
Post by Old fella »
Deleted
goldeneagle
Post by goldeneagle »
Old fella wrote: Sat Nov 29, 2025 7:15 am I am quite surprised the moderator(s) still permits this dude(pdw)“ flowery nonsense “ disguised as “technical expertise” to be posted on this very tragic crash that resulted in the loss of many lives
:rolleyes: :rolleyes:
the pdw account is essentially a very old, not very smart by modern standards, auto posting bot designed to inject aviation terminology into threads to increase view counts. It's all about increasing revenue from adds. I'm sure a modern AI could inject considerably more intelligent posts into a thread, but, implementation would likely cost more than the add revenue generated....
cdnavater
Post by cdnavater »
goldeneagle wrote: Sat Nov 29, 2025 10:03 am
I’m not up on bots and or how they work but based on previous posts from this account giving background information, I feel it is a human posting this nonsense!
According to a not to distant past posting, he was a farm equipment salesman who had a couple close calls which were according to him attributed to inversion and or quartering tailwinds, bear in mind I’m going from memory and the details are likely not exactly as described.
Suffice to say, this poster has a singular focus on wind and temperature inversions and only comes out of the woodwork when there is a slight chance this could be a factor.
The only part any inversion could have played in this accident is where they initially hit the building, the plane was going down regardless of any difference in temperature or wind, the why both engines were shut off is the only real question that needs to be answered, anything else about the conditions is just noise and from him, utter and complete nonsense!
Sulako
Post by Sulako »
Handy guide to blocking posters you don't like on AvCanada:
Find a post they made and click on their username.
This will take you to their user profile.
Find "Add foe" and click on it. You can always undo it later if you wish.
The forum software will remove posts of anyone on your foes list, and highlight posts of anyone on your friends list.
You will still be able to see if a foe posted on a thread, and if you want to see what they posted, you can click on their post to reveal it.
Enjoy!
I haven't banned pdw because they honestly appear to mean well, and they don't go out of their way to offend anyone. I think they might be a little bit eccentric (I'm being diplomatic), and I confess that reading their stuff hurts my brain a little bit if I try to process it (so I don't try to process it) but aviation is also full of strong personalities and we see lots of other peoples' hot buttons on full display here on a regular basis too.
5x5
Post by 5x5 »
Bravo Sulako!
It would be a very miserable place if we lived in a world where we only read or heard information we agreed with, stated in a manner we approved of.
Mark Twain
cncpc
Post by cncpc »
The Air India 787 crash was caused by fuel starvation. How that happened is not yet determined.
It had nothing to do with your man's wind theories.
Well said, Sulako.
Nauclerus
Post by Nauclerus »
cncpc wrote: Sun Nov 30, 2025 1:31 pm It had nothing to do with your man's wind theories.
I think pdw is just trying to explain the dreaded 1 knot decreasing perfomace shear they "might" have encountered. I'm sure we have all experienced this many times and never even noticed it. Now with this information presented by pdw we're considering modifying our SOPs to have the NFP fixate on the OAT guage to identify any impending inversions and immediately call out any airspeed fluctuations exceeding +/- 1 knot. Safety First.
pdw
Post by pdw »
6 1/2 knots given for the runway and if there is just 3 1/2 knots going nearly opposite direction (hot/hotter) closer overhead it is already ten knots negative up into the inversion’s transition . Then a “1kt” you could say could be eddy enhancement (ten percent more in this case) , if present. There are diagrams of L.L. inversions available to import that show simply what that would be.
Here seems to be in sync with a very strange power anomaly, barring suicide of course.
Old fella
Post by Old fella »
Deleted
Dry Guy
Post by Dry Guy »
When people stop giving him attention, dummies.
SpyPilot
Post by SpyPilot »
"if there is just 3 1/2 knots going nearly opposite direction (hot/hotter) closer overhead it is already ten knots negative up into the inversion’s transition."
"Then a “1kt” you could say could be eddy enhancement (ten percent more in this case), if present."
Those of you who have been following along with pdw have to admit that this is some of his best stuff. Are you not entertained?
pdw
Post by pdw »
Entertain …. as in considering an idea or suggestion.
For example, where does the intense heat radiating back out of 3km of runway ashphalt recirculate-to when convecting upward in such conditions (under same said capping effect)?
SpyPilot
Post by SpyPilot »
en-ter-tain
1. provide (someone) with amusement or enjoyment.
"a tremendous game that thoroughly entertained the crowd"
cdnavater
Post by cdnavater »
pdw wrote: Thu Dec 04, 2025 10:16 am Entertain …. as in considering an idea or suggestion.
Who cares, what does that have to do with the price of tea in China??
pdw
Post by pdw »
The pilots, and it doesn’t matter where …. but here, as you must know by now, there are no realtime wx/indications until well east of this airport (for a very long distance). Maybe time to consult “the manual on low level wind shear” (to see if something like this is actually in there).
But yes, the temperature used to compute derate here is IMO possibly a big thing too … as it has a compounding effect , …maybe even confuses (I mean … somehow messes up) the FADEC during such low/reciprocal shear … in some way (ie once right in the middle of it) ?
cdnavater
Post by cdnavater »
pdw wrote: Sun Dec 14, 2025 10:59 am The pilots, and it doesn’t matter where …. but here, as you must know by now, there are no realtime wx/indications until well east of this airport (for a very long distance). Maybe time to consult “the manual on low level wind shear” (to see if something like this is actually in there).
This was almost a coherent post, however low level wind shear will not “confuse” FADEC.
The only thing you said that has any sense, I hesitate to validate your musings but yes, the “manual” has guidance on the possibility of wind shear or reports of windshear, going rated would be recommended as opposed to reduced thrust. Keep in mind this is my manual but I can assume the 87 would have similar wording.
However, wind shear would have no effect on FADEC, a temperature change would but not to the extent of confusing it, the engines by reports so far indicate they were intentionally shut down, switches moved so any shear and to be clear it would have to be significant to bring down an airliner, something associated with downdrafts from thunderstorms.
As usual you’re chasing ghosts and far off the deep end of anything remotely close to having anything to do with this event!
