The powerline is 820ft from the runway (according to http://aviation-safety.net/database/rec ... 20150329-0), but the approach lighting extends to 1500ft (according to the CFS and Cap Gen). So they would have seen the lights well before hitting the powerline.MUSKEG wrote:Did they not take out a power pole prior to contacting approach lights? If so then those lights as well as runway lights would have gone dark as the impact with the power pole did cause a power outage at the airport. Or were the approach lights on a different feed.
Air Canada Accident in YHZ
Re: Air Canada Accident in YHZ
- HiFlyChick
That power line is a different system from the runway lights. In any case, even if that had've been the system, the emergency back-up system for runway lighting, nav aids, etc is extremely quick. Can't recall the exact number, but something less than a second I believe. There's a Cat II ILS on 23, and for that the system needs to be even faster (don't know if the backup for the Cat II includes all other systems but it would make sense.MUSKEG wrote:Did they not take out a power pole prior to contacting approach lights? If so then those lights as well as runway lights would have gone dark as the impact with the power pole did cause a power outage at the airport. Or were the approach lights on a different feed.
A question for those familiar with the YHZ airport. Are there any lights short of the threshold that could be mistaken for runway lights, PAPIs etc in poor visibility.
There was a USAir 737 years back doing an approach in Kansas City in poor vis who mistook lights in a parking lot for the runway and hit power lines with their tail prior to going around.
I have been to YHZ and it seems fairly remote so I would expect not but I have seen a pilot initially go for a set of lights that were not even close to the airport and that was at a remote airport.
Hi RockieRockie wrote:I'm curious, does your system provide pseudo-glidepath guidance while actively tracking the localizer, or does it only present the calculated information on your display without linking it to the flight director? Also do you have the capability of flying flight path angle or do you use VFPM?KK7 wrote:We also fly a LOC as an SCDA with the FMS providing a pseudo glideslope like any other NPA.
Regardless...nice information to have when doing those approaches.
(Not sure where KK7 flies- they may have different FMS and/or software, but....)
The current DH8 100/300 FMS installation at Jazz has the ability to fly coupled VNAV approaches for all enabled FMS approaches that can be retrieved from the database (RNAV/GPS/VOR/NDB). It cannot fly localizer based approaches.
The Jazz Q400 FMS installation has the ability to fly those same approaches. Additionally it is WAAS enabled so it can fly to LPV minima. It has 'LOC Steering' capability which allows it to fly localizer based approaches and uses a coded FPA (BARO-VNAV) that is flown fully coupled.
All of the approaches mentioned above have coded flight path angles in the approach that cannot be changed. When the approach is loaded, you get whatever the coded FPA is with the approach (whatever is labeled on the Jepp plate). I can only adjust the flight path angle when programming enroute VNAV. We can program desired FPM, and the FMS calculates the required FPA for that. In short, the FMS flies FPA, and both Jazz Dash fleets have that information coupled to the FD.
The only time the Q400 would ever fly a step-down procedure is if the published/coded FPA on an approach exceeds the CARS limits (2.9 to 3.5 degrees) or approach more than 15 degrees offset from centreline; still presented by the FMS, and will gladly couple to it, but not permitted. The other time a step-down is flown is doing a 'circling approach'.
If I was landing on 05 in YHZ that night in a Q400, I would have loaded the RNAV (LPV) approach. My second choice would've been the LOC approach. Either approach would have been flown fully coupled to the VNAV (Baro VNAV for the LOC, and Satellite based VNAV for the LPV). It's great technology that improves flight safety and permits a nice stabilized approach to the runway.
Hope this helps.
Valid commentary.. Now that Law Firm in Halifax may want to revisit their their issue against us(NC) on lack of precision procedure Rwy 05Canoehead wrote:Hi RockieRockie wrote:I'm curious, does your system provide pseudo-glidepath guidance while actively tracking the localizer, or does it only present the calculated information on your display without linking it to the flight director? Also do you have the capability of flying flight path angle or do you use VFPM?KK7 wrote:We also fly a LOC as an SCDA with the FMS providing a pseudo glideslope like any other NPA.
Hope this helps.
However the Jazz Dash 100/300 aircraft do not have WAAS or "loc steering" so all loc only based approaches are flown as step downs
ReserveTank
And there we have it. Why was that airplane at the same altitude as the approach lighting before the runway? Because it was below mins. They reached mins and kept going. That can't be denied.The ODALS is 1500ft long and they landed 1100ft short, so how could they possibly have been "without visual reference" when they landed right on top of it?
You don't need to have visual reference with the runway before descending below minimums. The "visual reference" includes the approach lighting. So they perfectly legally descended below minimums because they had the required visual references to continue the approach legally below minimums.ReserveTank wrote:And there we have it. Why was that airplane at the same altitude as the approach lighting before the runway? Because it was below mins. They reached mins and kept going. That can't be denied.The ODALS is 1500ft long and they landed 1100ft short, so how could they possibly have been "without visual reference" when they landed right on top of it?
The interesting question is why the visual references were not sufficient to get them onto the runway.
ReserveTank
That may be how it works where you're employed but it is not the way it works at Air Canada - "sneaking it in" is not part of our culture nor should it be at this level. This is not a bush operation where that kind of stuff is tolerated by either management or the crews themselves.
We all know what is supposed to happen and what actually happens. My company - your company, it doesn't matter. It's individual choices. They tried to push it in through the weather and broke the airplane.
Something tells me if this was Asiana's airplane, we would not have 16 pages of talk about SCDA. We like to defend our own sometimes, even if it's unreasonable.
ReserveTank
You sort of missed what I'm saying. I know very well what references are required to land.
But you are asking the same question as me. Why are they at field elevation short of the runway.
They had the legal weather to complete the approach and the legal visual references to continue below MDA for landing. Saying they tried to push weather and broke the airplane as a result is not only incorrect, but deflects attention away from the real issue of overly permissive approach ban weather limits coupled with inadequate required visual references for non-precision approaches. It's a good thing the TSB doesn't jump to conclusions like you do or this crew would have been hung out to twist in the wind already.ReserveTank wrote:They tried to push it in through the weather and broke the airplane. Something tells me if this was Asiana's airplane, we would not have 16 pages of talk about SCDA. We like to defend our own sometimes, even if it's unreasonable.
Based on your input on this topic and your inside knowledge as an AC pilot, also the known WX sequence, would you have attempted conducting that approach into Halifax RW 05. Let me also back load the question, if you say this crew was legal however lets suppose the crew decided not to try this approach and instead headed over to their alternate(which I understood was Moncton, NB), would the Captain have to answer/justify that decision knowing it was"legal".Rockie wrote:They had the legal weather to complete the approach and the legal visual references to continue below MDA for landing. Saying they tried to push weather and broke the airplane as a result is not only incorrect, but deflects attention away from the real issue of overly permissive approach ban weather limits coupled with inadequate required visual references for non-precision approaches. It's a good thing the TSB doesn't jump to conclusions like you do or this crew would have been hung out to twist in the wind already.ReserveTank wrote:They tried to push it in through the weather and broke the airplane. Something tells me if this was Asiana's airplane, we would not have 16 pages of talk about SCDA. We like to defend our own sometimes, even if it's unreasonable.
ReserveTankReserveTank wrote:.How do you know they went below mins without visual reference ?
Because they hit obstacles prior to the runway. Just like all below mins crashes.
We don't need 2 years to figure out that they tried to sneak it into YHZ like a Navajo captain tries to sneak it into YTL. The weather at the time is a corroborating factor. They pushed it like so many do, but this time an airliner was crashed.Has a report come out saying this? I think everyone needs to step back and let the investigation run its course
No kidding? As long as no one is dead and feelings are not hurt let's keep crashing planes.We all have to be glad that everyone is alive
Very well put and right on. To all you aviators who have a doubt, think this one out for a nanosecond or to put it more down to earth, if it walks like a duck, talks like a duck, looks like a duck........
Once again I have no inside knowledge of any kind even though I am an Air Canada pilot because nobody is talking and everybody is carefully waiting for the TSB report. I could say what I would do based on the only known facts at this time which are the weather sequence, what kind of airplane it was and what approach they had to be doing and I'm sure my answer wouldn't be much different from yours or anyone else's. But it wouldn't mean much because I don't know who the crew was, I don't know what their fuel state was and I don't know how long their duty day was. I do not know what they actually saw on reaching MDA. I do not know what part turbulence and windshear (if any) played in this accident. I do not know if the human tendency to push down toward the approach lights in very poor visibility played a part. I don't know if the crew may have mistaken ODALS for centreline lights or not. I don't know what part ATC played in this. I could fill a book with what I don't know about that night.55+ wrote:Based on your input on this topic and your inside knowledge as an AC pilot, also the known WX sequence, would you have attempted conducting that approach into Halifax RW 05. Let me also back load the question, if you say this crew was legal however lets suppose the crew decided not to try this approach and instead headed over to their alternate(which I understood was Moncton, NB), would the Captain have to answer/justify that decision knowing it was"legal".
With reference to the back part of your question, no, the Captain would not have to answer for it if he decided to not attempt the approach and instead proceeded straight to his alternate. Safety decisions are the Captain's to make, and anytime I've made a decision like that nobody has questioned me about it afterward. I can say without hesitation that Air Canada does not operate that way.
Do you have specific knowledge that nobody else does? If not maybe you should consider that the TSB doesn't use the "walks like a duck" method of accident investigation for a reason.duranium wrote:To all you aviators who have a doubt, think this one out for a nanosecond or to put it more down to earth, if it walks like a duck, talks like a duck, looks like a duck........
Rockie.
A reasonable response for sure. Your airline has been flying A320 or variants of it for a good many years- would 20+ be close. This aircraft(variants) flys into Halifax every day of the year winter, spring, summer, fall. It has done countless non-precision IAPs to this runway(05) and others over the years with much the same avionics since coming on line- that a fair comment and more to the point it has done so safely in all kinds of wx to whatever landing minima approved by the regulator. Yours is a top notch airline with A+ record.
This is why the final report will be eagerly awaited wondering how this could happen....
Old fella
I'm sure the TSB will focus very closely on what visual cues were available below the MDA/DA/DH/MDH including if any PAPI's were visible, whether this kind of approach puts the aircraft in a position to continue a normal descent to the runway, and what the rate of descent was during the approach and after minimums.
A PNF can be extremely useful in poor conditions by calling out the sink rate and speed relative to Vref or Vapp several times in situations like this, circling approaches, etc when 100% concentration is being used by the PF to align with the runway.
On a nice long runway, any descent path error would seem to be preferable on the long side.
Eric Janson
The Jeppesen plate I have for this approach shows altitude vs. DME all the way from ODKAS (D13.3 IHZ). After ODAKAS there are 11 points at which the vertical profile can be checked with the last one being the MDA.pelmet wrote:I'm sure the TSB will focus very closely on what visual cues were available below the MDA/DA/DH/MDH including if any PAPI's were visible, whether this kind of approach puts the aircraft in a position to continue a normal descent to the runway, and what the rate of descent was during the approach and after minimums.
A PNF can be extremely useful in poor conditions by calling out the sink rate a speed relative to Vref or Vapp several times in situations like this, circling approaches etc when 100% concentration is being used by the PF to align with the runway.
If you start your descent from 2500' at D7.8 IHZ there are 6 points at which the vertical profile can be checked with the last one being the MDA.
There is nothing difficult about flying this approach in LOC FPA mode in an airbus imho.
Thanks.Eric Janson wrote: After ODAKAS there are 11 points at which the vertical profile can be checked with the last one being the MDA.
If you start you descent from 2500' at D7.8 IHZ there are 6 points at which the vertical profile can be checked with the last one being the MDA.
I'm sure the investigators will look into whether they were on profile at the MDA and what the trajectory was after that point as well as what information was available to them in order to maintain a proper profile during the visual segment.
Half a mile vis is not a lot for a non-precision approach although with blowing snow, it might be OK until the flare. Difficult to say. Perhaps pilots who landed previously will be interviewed as well.
CFM Symphony
http://www.tsb.gc.ca/eng/enquetes-inves ... 5h0002.asp
Update from the TSB. Nothing new that we didn't really know already. 3 images of the interior are shown too, which I believe is the first time those have been published.
That's the hardest hard landing I have ever seen pictures of.
concorde88
So any updates? I'd kinda like to know before I attempt my own non-precision landing in YHZ. I have to admit that I am disappointed with the TSB that it takes this long to produce a report on an accident where the aircraft pretty much remained intact and the crew a passengers survived.
Maybe the TSB needs to change their culture of secrecy. There could be critical information that they are withholding until the final report(including translation time) which could prevent an accident. If something similar happens, they will have been part of the accident chain.
One can see the difference between the TSB and the NTSB with the Asiana crash where information was given out very quickly in the name of promoting aviation safety and preventing similar automation confusion in the interim.
Old fella
Perhaps it could be that Air Canada has issues/concerns with "Findings for Cause and Contributing Factors" as determined by TSB and both parties want to iron out any differences before public release. I do believe a draft report is sent to the responsible carrier for their review and commentary before going public. Just my thoughts.
