Rouge is a ULCC? I thought you had more credibility than that.cloak wrote: ↑Thu Sep 05, 2019 11:37 amThat was my point as well that it is actually Air Canada that has and continue to bring down the wages for pilots in particular, other (carriers) have simply responded. It was the one that started Sky Regional that almost bankrupted Jazz. It extended the probationary pay from one to two and then to four years, which also caused Transat and WestJet to lower their initial pay. And then it started Rouge causing WestJet to respond by Swoop. In an attempt to lower its costs, Air Canada continues to chase the lower end of the market. This is fundamentally flawed because by design, the largest airline cannot possibly expect to have the lowest cost in the industry to make money, it has to use its vast network and resources to do that. That is the root cause of the problem.Tdicommuter wrote: ↑Wed Aug 28, 2019 7:06 am That logic does not check out in any way shape or form. Do you think the legacy carriers in the states get better raises because new ULCC's with sub par conditions and wages show up? Nope it actually comes from the other carriers of equal importance getting bigger raises. AA gets raise... United gets raise... Delta goes back to the top. ...
Rouge is actually a response to WJ’s LCC. WJ.
