an antenna able to broadcast out toward space-based ADS-B receivers emitting 1090 MHz Extended Squitter. This requirement can be met either through antenna diversity (the use of a top and bottom antenna) or with a single antenna that is capable of transmitting both towards the ground and up towards satellites.
The Uavionics is a good one but I would have to add their dash device in order to use the transponder.
Where are you going to put your antenna?
Other than the tailbeacon, I can't find any location that would qualify to receive both space and ground signals.
