New Twin Otter set to fly
Re: New Twin Otter set to fly
Post by North Shore »
Anyone know about that Twin otter lookalike. Is it the Y-12? Why is that not widely used around here?
Ahhh, 'cause it's made in China? I defy you to find any consumer product made in China that doesn't break some small, irreparable plastic part within the first year, thus rendering the whole thing useless..
Happiness is V1 at Thompson!
Airtids
Post by Airtids »
gggq, thanks for the update.
NS, that's exactly the rationale I'd heard as well. We had a dozen folks from Vietnam through here, and that was generally their response when I asked about the Y12.
just curious
Post by just curious »
If your fleet had all -27s and you wanted the new 400 but with 27s would they sell you one?
Since the operating differences between them are slight, and the redundant spares are not widely different, there would be no operational advantage in ordering one with dash 27's or 28's. Dash 34's or 35's would be easier for spares availability.
brownbear
Post by brownbear »
The 34 uses lots of the same stuff as the 27. Governors etc. Fuel nozzles are the same. The only difference I can think of offhand is the FCU. You can use lots of different FCUs on the 34. But the 27 won't like the 34 fcu. I found that out one night. There is differences.
The 27's new are a lot cheaper too. If you have no use for the high altitude, hot environment -34's and your fleet is 27's I think a -34 might not be worth it. But the -34 is a nice engine on Twin otter. Lots of Torque up to very high altitudes.
Airtids
Post by Airtids »
Update from NBAA
http://www.youtube.com/watch?v=W2vwMg8Q7uw
One of my co-workers just got back from Orlando and said folks were absolutely flocking around the machine. Also said it was one of the few aircraft there with any color (other than white) on it!
Donald
Post by Donald »
Airtids wrote: Let's try and remember that gyros also take a beating in cold, rough and saline conditions. I think it will be a wait and see scenario as to how well the glass/chips will stand up.
No need to guess as there are machines running around and overnighting in extreme cold with glass cockpits. Unless you drive something with absolutely no electronics/radios in it, no plane likes to wake up frozen c*ck stiff without pre-heat.
Plug-in the engines, then the battery, then the avionics. If you don't have the resources to plug that much in, better run the herman on the avionics/cockpit for an hour before start.
Remember, there are more companies operating successfully in the north than just KBA...
Airtids
Post by Airtids »
Excellent points.
Otter envy
Post by Otter envy »
I don't know what all the fuss is.... I fly the twin otter with - 20s. Its a solid powerplant (clearing my throat) for that airframe. Its never let me down ( checking for lightning ) it never quits when you need it most. :shock: What? Really!! I'm serious over here. And as for the avionics, its a twin otter! I've never had a instrument fail on me .... ever. Least if all the fuel guages or the troque meter. So what good will all those fancy/reliable instruments do us salt of the earth twotter pilots anyway? Its time we all stopped taking this flying so serious... its not like our lives are on the line. What could possibly go wrong?
Nice work Stack.
Bring on the 400!!!!!!
just curious
Dash 20's... aren't they the ones with the compressors made out of wood?
linecrew
Post by linecrew »
The PoC bird has been pretty busy on it's way back from Florida...
http://flightaware.com/live/flight/CFDHT/history
Human Factor
Post by Human Factor »
Which is exactly why I never married a Chinese girl. :lol:
Will fix airplanes for food.
Caracrane
Post by Caracrane »
Didn't look at every posts but it doesn't seem that they had the idea to revove the landing lights away from the exhausts blast :roll:
Thats something I was wondering about too! And which crazy engineer thought that was a good idea. Geez!
lownslow
Post by lownslow »
Caracrane wrote:Didn't look at every posts but it doesn't seem that they had the idea to revove the landing lights away from the exhausts blast :roll:
A cheap anti-ice system?
Low-N-Slow
