A little background: If you have never taken a
statistics course (and as such have never learned
not to buy a lottery ticket) ....
If one collects a lot of samples of stuff in nature -
such as people's IQ - you will notice that the data
forms a curve, with some data points with small
values, most data points clustered around the
average, and some data points with high values.
This is pretty neat:
http://en.wikipedia.org/wiki/Normal_distribution
Here's a picture:
Notice the symmetry of the curve. The average is
thusly in the middle, and the shape of the curve is
determined by something called the "standard deviation".
95% of the data points are within two times the
standard deviation of the average. 2.5% of the
points are above that range of 2 sigma, and 2.5%
are below that range of 2 signa that.
How on earth is this aviation-related? Don't teach
the turnback to PPL's on the left hand side of the
curve (i.e. with performance less than average).
A PPL with performance at least one sigma (certainly
two) on the right side of the curve is a candidate
for learning the skills to perform a descending steep
turn.
PS As previously mentioned, what can really help
the ability to perform the turnback, is practicing
a wingover (at altitude). The wingover teaches
you that you can fly very steep angles of bank
at very low G and very slow airspeed, which might
sound familiar.
A wingover is not terribly difficult to perform, nor
does it involve high G. It does not stress the
aircraft in the least. Here's a picture of one:
A wingover is a really nice way to turn around.
It is a gentle and elegant 180 degree turn. But
instead of doing it with high speed and high G,
what you do (in the first half) is a climbing turn,
to convert your airspeed into altitude. Power
is never touched. The slower speed allows you
to turn with a tight radius, using light G. The
second half of the wingover is symmetrical,
a descending turn.
I personally like to see around 90 degrees of
back at the apogee (highest point) of the wingover.
The G is light and positive, and the ball is in the
center. The aircraft is ballistic at that point.
IMHO a wingover at 3000 feet is definitely within
the capabilities of nearly any PPL on the right
side of the curve.
