akoch wrote:
Am I crazy?
Nope, but wrong, here is why:
akoch wrote:We have excess lift that make the plane go up, or insufficient lift to keep it at the same altitude. It descents. Lift equal weight = aircraft does not change altitude.
This is only true while you are accelerating either upward or downward. Once in a steady climb or descent, you are not accelerating aren't you? Therefore, all the forces acting upon the system are cancelling each other. (Sum of all forces) = mass*acceleration
What happens when you pull on the stick? You are not asking your airplane to climb, you are saying "I want a higher AoA". Inititally this higher AoA will produce an excess of lift, hence making you accelerate upward. This higher AoA brings more drag with it thought, and also part of the weight vector now points opposite to where you are going. The airplane will therefore stabilize in a steady climb, but guess what, it will be moving slower than when you were straight and level.
You don't continue to climb because you have excess lift, you climb because you have more power output than what would be necessary for a straight and level flight at this speed and AoA.
We could also climb by generating more power but keeping the AoA steady. What will happen? Initially, the airplane will accelerate forward, but since you keep the AoA constant, it will experience an excess of lift, hence accelerating you upward. What happens then? Same poutine as with the first example, only now you will stabilize in a steady climb, at the same speed and AoA as what you had in straight and level before you pushed the throttle.
Little note: since most SE light aircraft have the elevator in the slipstream of the prop (which make the elevators more effective), what I described above is not exactly true, pushing the throttle while not moving the stick will make you stabilize at a SLOWER airspeed than what it was, and pulling the throttle will make you descent faster than supposed... An AoA indicator would then be a better tool than just trying to not move the stick!
Keep this in mind akoch: you climb/descent because you have too much/not enough power for your speed/AoA.
You accelerate (in any direction) because there is a force imbalance. As soon as you are steady, there are no forces imbalances.
Power really controls your altitude while the elevators control your AoA/speed.
