1) first yyw as posted is a remote airport at 8pm in the winter you are lucky to here a crow calling. you will here the cn main line trains rumble by at warp 5 though.
2) next there is no approved approach into yyw used to be but no more not even a restricted c.a.p./ therefore pic beware applies.
3) I have been in the exact same situation different aircraft but same scenario. it goes like this > empty back after patient return to ygq occ requests wx check to divert to yyw/ well no wx reporting so check notams
wx acceptable/ all you can do is say is well go take a look. that what atpl 's do take a good look and make the call . Then overhead runway check looks ok quick confirmation with the f/o about his observations. fly a vfr circuit do the sop's . brief and be mentally ready with the go around early if things aren't where they need to be. they did it right as far as normal operational situation.
4) as stated dark then toby's butt white surface . aircraft drifts left. .
3yrs back was overnitn in ywg as the only alt that we could hold was yxu and occ did not want the foot the bill in cyqt if we missed with a metar of variable 1/4to 3/4 mile in blowing snow .So next day on the way back to base occ request a diversion to nm5 fuel good/ wx severe clear/ I decllined no runway report after a snow storm . I am expecting 6 inches of the white stuff . advised them no problem once the runway condition report is confirmed and published.
The only thing after a 5k hours doing the exact same thing is possible and this is remote, is to do sim training for this exact scenario/ as the when one touches down and reverse thrust is selected the blade angle goes negative which means the hand/ feet reaction thing becomes a bit unnatural throw in a slippery surface and a departure from ones intended centerline track may be the outcome.
5) as posted the notam thing does need to change. and to all the legal eagles out there. if you read the disclaimer from nav canada the liablity there is enough room to put several semi trailers through the that sideways . in short expect you to follow all the wx rules best info etc then wash their butts with the metars and notams when they pooch the info .
well all of you out there have a very safe and wonderful holiday with family and friends Cheers and call a taxi best wishes in 2011
