Best Bear gun?
Wonderdog
bear gun
Post by Wonderdog »
I am sleeping beside a Model 1300 Winchester, 190 miles north of YZF and it always services it's purpose, only as a last resort.
SMcL.
Doc
Post by Doc »
This time of year.....you maybe should find something a little softer and warmer to sleep with?
LH
Post by LH »
A .12 Ga pump loaded with SSG. Unless he's a Polar bear, that'll do the job just fine.
Apollo
Post by Apollo »
Who needs guns when you've got 'nades :D
(l) Black Market.
tiny
1300
Post by tiny »
I pack a 1300 winchester withs slugs and buck shot when guiding backpacking trips. With a pistol grip and an 18" barrel its fairly compact and packs a punch and its also not restricted.
Doc
Post by Doc »
I tried a 1300 with a pistol grip.....couldn't choke the chicken for a week!!
ragbagflyer
ouch
Post by ragbagflyer »
hey Doc, for your sake I hope that your "chicken" isn't as weak and flimsy as your wrist obviously is. 8)
Brewguy
Post by Brewguy »
A Lee Enfield 303 should work quite well... but it only takes a couple of rounds to give your shoulder a nice bruise.
rigpiggy
Post by rigpiggy »
get a folder for any of the popular shotguns, shorter in the plane, and more useful than the pistol grip as always unfold the stock, if you have time
http://www.combatstocks.com/images/bc_700moss.jpg
Neil, learn to pull the buttstock to your shoulder tighter then roll with the blow. either that or spend the 20$ for a slip on recoil pad.
w squared
Post by w squared »
Rigpiggy is right. With proper technique, a .303 shouldn't be giving you problems with excessive recoil. It's not exactly an elephant gun, ya know?
Brewguy
Post by Brewguy »
What I should have said was "The first couple of times you fire one..."
I haven't had any problem with that in years, but the 303 was the first rifle I ever fired; and at the time, it hurt like heck!
w squared
Post by w squared »
I can see how it would sting the first coupla times if you didn't get the right instruction on technique.
AntiNakedMan
Post by AntiNakedMan »
I usually find a Ruger Mk II to be a decent bear gun... easy to pack, ammo is very cheap, and it holds 10 rounds.
Really though I only need one round, because I just shoot the bear in the left eye. Or from a side profile, in the ear. Then I of course hop into my airplane and perfectly fly it away.....
Or... on the other side of the insane coin, I just use a SAW with a 200 round clip.... after a full clip into a griz you don't even have to skin him, there's not much skin left.....
Anti
"It's not the size of the hammer, it's how you nail" - Kanga
rigpiggy
Post by rigpiggy »
ANM, the SAW249 uses a 200 round disintegrating link belt, or the 30 rd M16 magazine. The magazine isn't too reliable due to reduced drag on the operating mechanism allowing the cyclic rate to increase markedly. Thereby causing the bolt too override the ammo as it can't rise fast enough.
AntiNakedMan
Look Everyone!!!
Someone thought I was serious!
This is too much
B18rules
Post by B18rules »
12 gauge pump with slugs excellent to 25 yards and enormous hole also can be found cheap so who cares if your garbage leaks on it
rigpiggy
Post by rigpiggy »
anm, I knew you weren't serious, just misinformed
Doc
Post by Doc »
ragbagflyer....thanks for the concern for my chicken. He's not as good as he once was. But, he's as good once as he ever was!
buck82
Post by buck82 »
Anyone have experience with RPG's? Guess if you got the bear far enough off it might work... but then that wouldn't be protecting yourself would it... that'd be poaching.
w squared
Post by w squared »
Use a 84mm RCL HE round. An RPG won't give you the kind of effect you're looking for, and probably won't detonate effectively against the bear unless you tamper with the fuzing.
The 84mm round will make a much bigger hole.
buck82
Post by buck82 »
Ahhh, thanks for the tip, I'll be sure to have the ME list updated to include one of those. Sure would be funny to see if transport would approve one.
w squared
Post by w squared »
Tell them that you're using for firing signal rounds. You know, parachute flares and the like. There might even be parachute rounds out there for the 84mm.
If not, tell them that it is a "big game rifle".
It's big. It's rifled.
buck82
Post by buck82 »
Yeah I don't know about the parachute thing.. they may get confused and demand I either have a designated drop zone or file a notam 24hrs prior to releasing any.
geesh this is going downhill
w squared
Post by w squared »
I think it bottomed out about the time that somebody suggested an SKS as a bear rifle. We're just maintaining that trend. At least we have a pic!
fredoqc
Post by fredoqc »
