losercruiser wrote: ↑Tue Dec 31, 2019 3:09 am You realize this entire conversation has been in regards to RADAR controlled airspace, right?
Clearly.altiplano wrote:Deciding on your own to just turn direct somewhere in a terminal environment because you were cleared an approach while on the STAR isn't reasonable either. You acknowledge that the controller wouldn't have cleared them direct because they were below his MRVA, so why did they do that? You acknowledge they weren't on vectors... so if you're going to try to cut the corner on your own, you better have your own terrain.
Doesn't change the fact that, just because you're in radar airspace with a terminal controller, you aren't absolved for your own responsibility for terrain separation unless on vectors.
And who just turns direct the fix on their own without a clearance?
