I worked north tower four sessions in a row on the dual-arrive 15s that afternoon and it felt like it was a lot more than a 50 rate. The number of offloads on 15L was a bit out of control at times.
Whoa whoa whoa... You're telling me there's a tower that actually does that?!?Married a Canadian wrote:Cossack...tower called down the other day to compliment the arrival spacing....
I'm thinking hoaxer activity.cyeg66 wrote:Whoa whoa whoa... You're telling me there's a tower that actually does that?!?Married a Canadian wrote:Cossack...tower called down the other day to compliment the arrival spacing....
We'll start as soon as we get compliments on our departure spacing!cyeg66 wrote:Whoa whoa whoa... You're telling me there's a tower that actually does that?!?Married a Canadian wrote:Cossack...tower called down the other day to compliment the arrival spacing....
Funny you should mention that. I have before. Believe it or not, some of your group still (appear to) have fun doing the job and like to push it a little more than the rest. I've given them kudos on occasion.NJ wrote: We'll start as soon as we get compliments on our departure spacing!
You only guess right 50% of the time?ZBBYLW wrote:A couple questions about arrivals. During the 0630 post noise abatement rush, most of us will start decent prior to 630. Is there anyway that the ATIS can reflect the post 0630 runway usage? If it were to include ARIVAL RUNWAY 15L active but expecting RUNWAY X and Y at ZZ time it would help out. Usually you can take a guess on runway but it's only correct 50% of the time. For us it's nice to have everything loaded into the FMCG prior to starting down as it does help out our descent planning and it's nice to have all our briefings out of the way while in cruise.
This is more for Terminal but I have some experience in this from the distant past and I know that here they use similar techniques here. If we want you down quickly we'll let you do that first then reduce speed. "Descend to 4000 feet, then reduce speed 210" sound familiar?ZBBYLW wrote:Second question: Many times we are given a speed and altitude assignment. Say we are at 250 and 7,000feet it may be 210 and 4,000. Some times we are told speed or altitude first which is obvious. My normal technique if not specified would be to get the altitude first and then once the airplane starts levelling out change it's target speed to the new one. The main reasons are the fact the airplane descends better with the higher speed, and it does a very poor job of descending if you're trying to bring the speed back at the same time. It goes into a 5-700fpm descent while taking forever to slow down, which is your preference? I can see speed being a priority for spacing issues, but if not told one way or the other it is easier for us to prioritize the altitude as the speed burns well in level flight or in the base turn (even if we have not had a chance to slow down by this point).
Thanks guys!
This is my problem it seems! If I am on a curfew restricted flight I seem to be coming from YYT/YDF or YHZ on the RAGID arrival. We usually do place a bet, one guy thinking 5, the other 6R and knowing our luck it will be on 6L! I was not aware at how complicated the runway determinations can be for you guys and yes if we are landing just after 630, it would seem it's too late by the time we start down. This is why it's awesome you guys are on the forum and making things more transparent for us airplane drivers!Married a Canadian wrote:The rough guide would be that if you are coming in from Linng or YWT then expect a southerly runway...if you are coming in from FLINE or IMEBA expect a northerly runway. RAGID...50/50.
I would say about 20-40 % of the time we get a "descent 4,000 then 210 kts" I have been treating other situations when not specifically told the same way.Married a Canadian wrote:In relation to your speed question....I fall into the category of telling you to descend first then bring back the speed
Yes somedays it is more difficult than others, with the speed all the way back to 170 being the major hinderance. We do have the drag to make it work most of the time, though it's more work than other days.Married a Canadian wrote:On the 06s of course...when you are coming in from YWT with the tailwind...I shudder to think how awkward it is to descend for the ILS and stabilise and usually slow back to 170kts within 15 miles of the airport.
I would not have figured the determination would have been so late, rather some formula which could be applied based on various weather and runway requirements.cossack wrote:After 6:30 you can expect to land on 5 or 06L/R or 23 or 24L/R unless there is a 25kt+ crosswind component. The actual runways aren't decided on until maybe 6:10 when demand, staffing and runway availability have all been discussed between the tower and terminal supervisors. Even if we put out an ATIS at 6:15 it would probably be too late to help you arriving at 6:30.
