iflyforpie wrote:Photofly, in your first scenario you've got to remember that if it was a heavy jet landing in front of another heavy jet, that the first jet would also have to slow from 120 knots at touchdown before exiting at the end of the runway... so really, sequencing shouldn't be any different.
Let's say you're in a 172 and your goal is to achieve the maximum separation between you and a jet on approach behind you until the time when you exit the runway.
There are essentially two things you can adjust: the speed profile (for a given distance from the chosen turnoff point) and the chosen turnoff point itself.
In terms of your speed profile you want always to fly as fast as possible, then as close to the turnoff point as possible use the maximum deceleration to safely exit the runway at the fastest speed possible. That may mean no flaps etc., depending on how much extra drag the flaps give you.
Now note that at all times you're flying slower than the aircraft behind, so the distance between you is continually decreasing. That means the minimum separation occurs at the moment you exit the runway.
You should therefore fly an approach that exits the runway as early (in time) as possible using an approach that keeps the speed as high as possible until then. That means using the first (in distance) turnoff, not the one at the far end.
Considering it in reverse: you can spend another thirty seconds flying down 6000ft of runway at 120kts before closing the throttle and landing, but in that thirty seconds the following aircraft which is closing on you at 20 or 30 knots has decreased the distance by 1000 or 1500 feet. Of course it closes the distance even more as you slow to land, but it does that in any case. By planning to touchdown at the end of the runway you just threw away an extra 1000 feet of separation.
If the aircraft behind is approaching at the same speed as you it doesn't matter where you choose to turnoff - the separation is the same. And if the aircraft behind you is flying more slowly then a longer landing gives you a bigger separation.
It's possible that ATC's goal isn't just to maintain maximum separation; maybe they have a good reason to ask you to land long. Or it might amount to the same thing. For instance, the first turnoff might be well past the midpoint, in which case the first possible turnoff
is a long landing.
