Nanchang CJ-6A gear-up landing at Oliver Airport BC [video]
tonyhunt
Re: Nanchang CJ-6A gear-up landing at Oliver Airport BC [vid
Post by tonyhunt »
cgartly wrote:I do not know the owner/pilot of the aircraft personally but I do know of him and have heard a couple of things from someone close to him.
- Yes he screwed up and forgot to put the gear down
- He doesn't have hull insurance so he will be paying to fix this himself
- The wrecker that picked the plane up did not position straps properly nor did they use wide enough straps so there is now significant recovery damage as well on the fuselage.
Hurts to see this video. Thin straps, expensive hull noises when they lift it, but of course the gear drops and locks when he selects "down".
http://www.youtube.com/watch?v=KBvLW7Rq3YI
They used a friggen tow truck to lift it? Narrow straps, no bar to spread them out and ensure it was being lifted on its center of gravity, boom too short, people reefing on non-structural parts to position and steady it.
I know there has got to be a least one crane operator in Oliver, which would have been cheap compared to the damage caused by this fiasco! :roll:
Shiny Side Up
Post by Shiny Side Up »
That's what impatientce gets one. You would have thought at the very least some old mattresses, blankets, foam, etc. could have been rounded up to help mitigate some damage. Nope, Get 'er done!
carbeerater
Post by carbeerater »
That was painful to watch. I can't believe the used such a small truck and such dinky straps. As was mentioned they probably did some serious damage there!
A pretty good demonstration of how not to lift an airplane. What were they thinking :cry:
Doc
Post by Doc »
If your idea of lifting an aircraft is using a tow truck and brassiere straps.....You might be a RED NECK!
Shiny Side Up
Big Pistons Forever wrote: What were they thinking :cry:
One of the things I've found is that when shit like this happens, people's brains often aren't thinking for a fair chunk of time. Probably the best thing to do when an airplane comes to grief like this is to let her sit, everyone sleep on it and then come back and think more clearly through what needs to be done.
If it was absolutely necessary to hoist the airplane with only a winch truck available, there would have been ways to do it to get it back on its wheels much safer and with substantially less damage. Suprising we didn't see a video of someone losing some fingers there or getting injured. A real crane would be preferable of course.
SeptRepair
Post by SeptRepair »
Its usually the guy who yells the loudest and postures the greatest that gets listened to when gong shows like that unravel.
Doc
Post by Doc »
Can't be a heavy airplane? Must have jacking points? A few guys, some mattresses and a wee jack. A case of ice cold beer, and it's all done?
KISS
flyinthebug
Post by flyinthebug »
Doc wrote:Can't be a heavy airplane? Must have jacking points? A few guys, some mattresses and a wee jack. A case of ice cold beer, and it's all done?
KISS
2414 lbs BEW
A longer boom with those straps and some "cushion" even would have done the job. This video should be required viewing for anyone planning to "lift" any aircraft...of things not to do.
boogs82
Post by boogs82 »
I expected to see some injuries with the way all of those folks were around the aircraft. Thankfully nobody got hurt but there were some potential candidates for a Darwin Award if something went bad.
Rookie50
Post by Rookie50 »
That is one scary video. Wow.
FlySigi
Recovery Of A Nanchang CJ-6A After A Crash Landing
Post by FlySigi »
Recovery of the Nanchang CJ-6A (C-FTQW) that landed gear-up Western Warbirds Association (WWA) meeting at the Oliver Airport (CAU3) in BC Canada [September 07, 2013].
Yeah,
I'd like to collectively post "+1" to all the comments about what an embarrassing display of poor judgement that recovery was!
In the number of recoveries I have assisted with, we have never damaged an aircraft more, unless it was a total wreck, and we planned to. Unless a person is at risk, there is just no reason!
Post by sky's the limit »
This whole event is like a never ending train wreck.... :shock:
AirFrame
Post by AirFrame »
Extraordinary. All I could do was shake my head for five minutes while I watched that. It wasn't on the runway, there should have been no rush to move it.
GyvAir
Post by GyvAir »
Somebody mentioned something about wrecker operator liability a while back. Having seen the video now and that they were talking about using an actual wrecker, I think all liability falls upon whoever made the phone call to the towing company and not a crane company.
Maybe just it's just projection, but I get the impression the person holding the camera had a pretty good idea of how the show was going to go.
A little off topic (OK, just barely on topic at all), but is anyone else checking in on this absolute opposite of the spectrum recovery effort going on today?: Concordia Recovery
Walt seems conspicuous by his absence.......
Big Pistons Forever wrote:Walt seems conspicuous by his absence.......
Yes he does.... Does he still have his shop there or has he packed it in?
AirFrame
Post by AirFrame »
Thinking about it further... Would it have made more sense to pick it up by the crankshaft? The towtruck lifting the heavy end, and 20 stout warbird pilots on the wings and tail, and maybe they could have hoisted it far enough to drop the gear? Not meant to criticise... There's been enough of that already. Just wondering out loud and making mental notes for the next time this happens (mind you, the last one I heard of it happening to was a T-28... I don't know how they lifted it, but i'd bet it wasn't a towtruck... :)
Not good. However, removing the cowls and lifting carefully by a selected part(s) of the engine mount can work well.
Sometimes a rush to move the plane prevents objective thinking and planning for recoveries. An independent group of qualified people, to the person who Ooops'd the plane, is a good idea in these cases.
AirFrame
Post by AirFrame »
PilotDAR wrote:Not good.
I'll admit my possible ignorance, but why? The crankshaft certainly sees extremely high loads, even bending loads, due to gyroscopic forces while doing aerobatics. You don't think it would take a static load equal to half the airframe weight?
I'm not suggesting that the crankshaft could not withstand the load - it could. However, this would certainly qualify as unusual loading, an impose the expectation for an inspection by disassembly. If there were absolutely no other way, than yes, and enter it into the aircraft logs as an unusual event on the engine requiring inspection. But, in most cases, there is every other way to lift the plane!
crazy_aviator
Post by crazy_aviator »
The reply of the last poster is the same reason WHY pilots shouldnt be hoisting aircraft PERIOD ! If the actions of a bunch of greying pilots in lifting the A/C back on the gear are ANY indication, you can well imagine HOW the plane got to be in that condition in the first place :rolleyes:
J31
Post by J31 »
True there are high loads on the prop but it only weighs 50-100 pounds hanging on the crankshaft.
