AC A320 slides off runway at YYZ
Re: AC A320 slides off runway at YYZ
Pelmet. CAT I runway ILS critical area sterilization does not meet the standard required for CAT II runways. Argue against that all you like. Auto lands are not certified on CAT I runways in part for that reason, for anyone including Air Canada. Argue against that all you like too.
Tower sterilizing the ILS critical area on a CAT I runway does nothing to permit auto lands, it doesn’t move that ball down the field so much as an inch. It’s irrelevant. The sterilization required for an auto land does not occur on a CAT I runway because it doesn’t exist on a CAT I runway. Is that sufficiently clear for you? In fact for a CAT I runway it’s not a requirement to even have a control tower to begin with. You also have no idea if attempting an auto land would have prevented this incident unless access to alternate timelines is one of your talents.
It’s not relevant to why your argument is wrong in the US, but why are you quoting FAA tower procedures when this incident occurred in Toronto? You also didn’t answer my question if you’ve ever seen CAT II/III hold lines on a CAT I runway.
- Flying Low
The CAT I protected area is smaller than the CAT II/III protected area. On a CAT II/III runway you will often see different hold lines for CAT I vs CAT II/III. I know a 757 crew that set up for an autoland on a CAT I runway in the early hours of the morning only to have to take over manually at 50-100' agl as the the plane nosed down at the runway. There is nothing that says you can't do an autoland but if CATII/III or LVOP/RVOP operations are not in effect then you do not have the same protected area and the signal may get interfered with. In a case where they lost visual reference close to the ground would they have noticed a divergence due to signal interference? Hard to say.
I agree with flying low.
There is nothing that prohibits you from doing autolands on a Cat 1 runway.
Auto lands are not certified on a CAT I runway. Nobody said they were prohibited unless your company chooses to make that policy which some do. AC doesn’t. Others specify which ones you can and which ones you can’t. In all cases where it is not certified you do so knowing it’s not certified and act accordingly.
The exact same thing can happen....and has happened on CAT II/III runways without sufficient protection.Flying Low wrote: ↑Wed Sep 26, 2018 8:21 am I know a 757 crew that set up for an autoland on a CAT I runway in the early hours of the morning only to have to take over manually at 50-100' agl as the the plane nosed down at the runway.
From TC...….
"It has become evident that further clarity is required regarding when ILS signals are protected while an aircraft is established on an ILS approach. ILS signals will only be protected under the conditions described below. Glide Path Signal Protection Procedures A controller will protect the glide path signal when: 1. The ceiling is less than 1,000 feet or visibility is less than 3 miles, or both; and 2. The arriving aircraft is inside the final approach fix (FAF) on an ILS approach. "
https://www.navcanada.ca/EN/products-an ... 017_01.pdf
Thanks Rockie but it sounds to me like at least some AC pilots are doing exactly as I suggest. Did you tell them differently. I suggest you ask your company why they have not prohibited what I suggest...an Autoland which would have prevented this AC incident. Advise ATC in advance and be ready to disconnect even if they have been advised.
Still don’t know the difference between a CAT I and a CAT II runway or that there even is a difference.
Still don’t get that auto land is not certified on a CAT I runway...or why...or what that means.
Still think you can predict with absolute certainty this wouldn’t have happened with an auto land.
Still haven’t answered if you’ve seen CAT II/III hold lines on a CAT I runway.
I consider myself lucky I won’t ever have to fly with you Pelmet. No matter how many times it’s patiently explained to you, you refuse to acknowledge much less recognize, consider and prioritize the big picture. You’re the guy fixated on the lightbulb while the captain futilely tries to get you looking out the window at the Everglades rising to kill you.
Still can't admit when you post wrong information and are corrected(a very hazardous attitude).Rockie wrote: ↑Wed Sep 26, 2018 5:55 pm Still don’t know the difference between a CAT I and a CAT II runway or that there even is a difference.
Still think you can predict with absolute certainty this wouldn’t have happened with an auto land(which would have prevented yet another incident).
Still think you know more than the FAA and TC when their information is specifically used to prove your statements wrong(on this and the earlier thread).
Still haven't told us why autoland is not prohibited at Canada' biggest airline on CAT I runways.
Still haven't told us why two of your co-workers disagree with you right here on this thread.
Still think that this incident would have happened if autoland had been used.
Still think that insults somehow make your argument the correct one as compared to factual information(which shows complete immaturity and lack of credibility).
Still haven't told us why you would not use something because it is not certified.
Are you really serious that just because something is not "certified" you consider it to be invalid for use?
1. Everything I’ve said is correct. I could give the link to look it up yourself, but if you wanted to you would have done it already. You don’t want to.pelmet wrote: ↑Wed Sep 26, 2018 11:28 pm Still can't admit when you post wrong information and are corrected(a very hazardous attitude).
2. I’ve posted TC, FAA and cited manufacturer and company policy on this and the other issue that proves me right. You’re not interested in it because it proves you wrong.
3. You didn’t ask why auto land isn’t prohibited on CAT I runways at AC. It is allowed for practise using the required degree of caution under certain conditions. It is not allowed as normal procedure to accomplish something the pilot cannot do that it is not certified for. It is not certified to land on anything but a CAT III/III runway with all the appropriate procedures in place, and within certain environmental and aircraft conditions. This is from the A320 limitations section:
Automatic landing system performance is demonstrated with CAT II or CAT III ILS/ MLS airport installation. However, automatic
landing in CAT I or better weather conditions is possible on CAT I ground installations or on CAT II/III ground installations when ILS/
MLS sensitive areas are not protected, if the following precautions are taken:
– "The airline checked that the ILS/ MLS beam quality, and the effect of the terrain profile before the runway have no adverse
effect on AP/FD guidance. Particularly, the effect of terrain profile within 300 m before the runway threshold must be evaluated
– The flight crew is aware that LOC or G/S beam fluctuations, independent of the aircraft system, may occur. The PF is prepared to
immediately disconnect the autopilot, and to take the appropriate action, should not satisfactory guidance occur
– At least CAT2 capability is displayed on the FMA and the flight crew uses CAT II/III procedures
– Visual references are obtained at an altitude appropriate for the CAT I approach. If not, a go-around must be performed."
Notice is says nothing about protecting the ILS sensitive area on a CAT I installation Pelmet. That's because it isn't relevant...it make no difference whatsoever unless it's on a CAT II/III installation with CAT II/III ILS sensitive area protection. It is not written anywhere that the company has satisfied the first precaution on that list, and until that is completed I cannot do an autoland on this runway as it would be violating the aircraft limitations.
4. None of my co-workers have disagreed with me on this thread. If they had they would be disputing company policy and manufacturer guidance, and I haven’t seen anybody do that.
5. Show me where I said this incident would have happened if they used auto land. I on the other hand can show where you said with absolute certainty - twice - that it wouldn’t have.
6. I give you factual information but you refuse to see it. Don’t talk to me about insults.
7. Show me where I said I wouldn’t use something because it is not certified. I explicitly told you when and under what conditions I could.
8. Show me where I said something is invalid for use because it is not certified. Again, I’ve explicitly said when we could use it.
You make stuff up, and you do not recognize or even acknowledge evidence that doesn’t support your belief. It is not possible to have a rational discussion with someone like you.
Ignoring the rest of your typical rant, you did actually post something useful(I suppose because it is a quote)…...
Boeing says(at least for some of its aircraft) in their FCTM discussion of Autoland capabilities...... "ILS beam quality may vary and autolands performed from a Category I approach at these facilities should be closely monitored." Admittedly, I assumed the Airbus is the same, especially with this quote from the accident report....."The flight crew discussed the lack of centreline lighting on Runway 15R and the possibility of using the Autoland system if conditions worsened."
However, the truth is the truth and that is all I am interested in. It appears that my recommendation should not necessarily apply to Airbus aircraft unless the airline has actually taken the opportunity to spend some money enhancing safety and checked the appropriate items, ideally this would be done at a home base like YYZ. Safety costs money. Maybe AC should spend a little money doing so and getting the new rain repellent for their windshields. Might prevent an incident like this.
See my next post about why I brought up the Autoland discussion but meanwhile, I amended the post initiating the Autoland discussion.
I have never flown an Airbus, therefore this information is new to me. The Boeing manuals are different and simply say to monitor more closely and nothing that I have seen in Boeing manuals mentions about the airline checking out the approach.Rockie wrote: ↑Fri Sep 28, 2018 3:28 am This is from the A320 limitations section:
hamstandard
Speaking of autolands at YYZ, has anybody noticed an unusual pitch up of several degrees tendency on runway 06 during an Autoland? Seen it a few times.
Except on the 320 at AC; as per ATB 560:
CAT 2 or CAT 3 OPERATIONS MUST BE IN EFFECT FOR AUTOMATIC LANDING. AUTOLAND during CAT 1 operations is prohibited for line operations until clarification of the procedure is received from airbus.
So is it an A320 thing only? Sounds like a little ass covering by Airbus for potential liability protection.
From the report....."The flight crew discussed the lack of centreline lighting on Runway 15R and the possibility of using the autoland system if conditions worsened." and "Autoland can also be executed on a CAT I approach. In this occurrence, because the reported RVR was almost double that which was required, the PF determined that an autoland was not necessary."
No wonder I thought that it could be used on the Airbus on 15R and now you know why I suggested it. Because of what was written in the TSB report. And as I said earlier, apparently AC Airbus pilots ARE obviously willing to seriously discuss using it.....according to the TSB. So I didn't make up anything as falsely accused by guess who...once again.
I didn't know that... I'm not flying the bus...
Anyway, I can imagine whose idea it is... and I think it's garbage, but what are you going to do...
I’ve found over the years that manufacturers and airline fleet management people who make policy generally have more information at their disposal than we do. It’s also generally a good idea to follow those policies even if it contradicts what the Avcanada peanut gallery thinks.
So to sum up...…
But...autolands are not allowed in the Airbus at AC and therefore company procedures concerning this were followed regardless of the earlier discussion in the cockpit. However, if your company has taken the time to analyze the cat 1 Autoland ability for a particular runway(or there is no restriction on your aircraft), my earlier advice stands....do the Autoland.
Then we got a good example of how the inertia of larger aircraft can take time to counteract and at a critical location....this can be the result. The drift continued even after touchdown.
"when the aircraft was descending through 26 feet AGL, the PF made a brief large right roll input (approximately 75% of maximum deflection) on the sidestick, and the aircraft responded by entering a 4° right bank. The aircraft heading began to increase slightly and the aircraft began to drift to the right of the runway centreline.
Approximately 1 second later, the PF reduced the thrust to idle.
".....at approximately 8 feet AGL, the aircraft was 32 feet to the right of the centreline, and the PM told the PF that the aircraft was drifting to the right. The PF acknowledged and input a left roll command and applied left rudder. The wings returned to level, although the drift to the right continued due to the aircraft’s momentum."
"the left main wheels touched down on the runway surface, followed quickly by a very brief right-main-wheel touchdown, or skip. At this point, the aircraft was on the paved runway surface, 2227 feet from the displaced threshold and 64 feet to the right of the runway centreline. The outboard wheel of the right main gear was approximately 20 feet from the right runway edge. The aircraft continued drifting to the right following the skip, and when the right main wheels touched down again, they were approximately 8 feet to the right of the paved runway surface, in wet grass.
As the aircraft continued to move laterally to the right, the nose wheel touched down on the grass, approximately 280 feet beyond the final right-main-wheel touchdown point, and struck 1 runway edge light. The outboard left main wheel and left engine cowling then each struck 2 runway edge lights, and the outboard left tire was punctured and deflated."
If you are drifting, especially in poor vis, you might want to consider going around as it might prevent a runway excursion.
I have never flown the Bus, so I am not sure if a 75% roll input during the flare in light winds is a normal event or not.
Autolands are designed and intended for use in low visibility conditions with minimums below what a pilot can safely land in visually. Normal aircraft environmental and operational limitations (and therefore the pilot's) far exceed what the autoland can do, so If you need it as a crutch to land in conditions other than what it was designed for you should find another line of work.
As I've also stated several times before, autoland in other than its certified conditions must be treated with heavy suspicion. It is sometimes an option, but one that comes with its own set of problems you may not want to add to the mix. Blanket advice like Pelmet's is ill-informed, ill-considered, and not supported by any operator I've been involved with. I can't speak for his but I'd be interested in their position if he's willing to post it. Heed at your own risk.
Jet Jockey
You two (pelmet and Rockie) are just like two lovers having a spat at each other, LOL.
All this crap about autoland, meeeh! Just hand fly the darn aircraft down to CAT II or CAT IIIA minimums if authorized.
I was thinking of changing my handle to Bullwinkle and charging anyone who reads this thread a small fee for our shows. Hopefully I might make as much as I did when I bought AC stock for a little over a dollar(wish I had bought more though), which is when Rockie started working for his favourite shareholder.....Me.Jet Jockey wrote: ↑Sat Sep 29, 2018 9:37 am You two (pelmet and Rockie) are just like to lovers having a spat at each other, LOL.![]()
Almost certainly would have prevented this incident though(but one can never prove it 100% for sure). I wonder if AC is now checking out 15L/R for Airbus autolands now. They are retroactively getting the hydrophobic windshield coatings that have been available for a long time according to the report.Rockie wrote: ↑Sat Sep 29, 2018 9:04 amAutolands are designed and intended for use in low visibility conditions with minimums below what a pilot can safely land in visually. Normal aircraft environmental and operational limitations (and therefore the pilot's) far exceed what the autoland can do, so If you need it as a crutch to land in conditions other than what it was designed for you should find another line of work.
My company had a similar incident and retroactively re-installed rain repellent on type.
altiplano wrote: ↑Fri Sep 28, 2018 10:51 pmI didn't know that... I'm not flying the bus...
Thanks Altiplano.
Now that we have seen what the Airbus policy is, can you let us know if pilots on your fleet are doing autolands in marginal weather conditions on CAT I runways in the belief that there is a safety enhancement.
Aircraft I fly are certified for autoland on an ILS. Of course required visual reference for the category of approach you are doing. It's an option available within the autopilot limitations.
I don't know what "other" pilots are doing.... I speak for myself.
Thanks for the reply. Just out of curiousity, I assume that the certification is for CAT II/III but that there is a statement for your type saying to be cautious with CAT I ILS/runways but no restriction. Do you see autolands on CAT I runways, perhaps in the past in situations where you might expect poor visibility in the flare(with appropriate precautions taken, of course)?altiplano wrote: ↑Mon Oct 01, 2018 3:49 am Aircraft I fly are certified for autoland on an ILS. Of course required visual reference for the category of approach you are doing. It's an option available within the autopilot limitations.
Updated three days later: I knew you would not answer this question based on the tone of the discussion from your fellow worker and I understand that. But I know the obvious answer based on your previous statements and no reply here. Pilots at your company are doing what I recommend using appropriate caution. And I am sure it has prevented other excursions.
If it looks like the vis will be poor but still legal for the landing, consider an Autoland. As the report states in this incident, these pilots did consider it as well but the restriction that applies only to Airbus aircraft possibly kept them from doing it.
Be ready to disconnect and to go-around(as these guys should have done).
I have, I'm surprised you didn't ask me. They work well...until they don't for all the reasons I've been bombarding you with to no effect. That's why it's not to be trusted and definitely not to be used as a crutch every time the weather hits minimums on a CAT I.pelmet wrote: ↑Mon Oct 01, 2018 7:16 amDo you see autolands on CAT I runways, perhaps in the past?altiplano wrote: ↑Mon Oct 01, 2018 3:49 am Aircraft I fly are certified for autoland on an ILS. Of course required visual reference for the category of approach you are doing. It's an option available within the autopilot limitations.
As for using the autopilot below minimums during any kind of approach (precision or not) in minimums weather, I'm a big fan and do that habitually until the runway environment is unquestionably visual or the limit I am allowed by manufacturer limitations, whichever is higher. Autoland however is another animal altogether which relies on a CAT II/III "protected" localizer rollout to be used with any confidence or manufacturer assurances. CAT II/III localizer and glideslope protections are more stringent than CAT I for certification, and are flight checked regularly by NavCanada, the FAA and other relevant agencies for rollout. CAT I runways are not.
Appendix "A" of this manual gives some detail as to the differences, for the FAA check out rule 6750.16
http://www.tc.gc.ca/eng/civilaviation/p ... u-2861.htm
Rockie wrote: ↑Sat Sep 29, 2018 9:04 am Autolands are designed and intended for use in low visibility conditions with minimums below what a pilot can safely land in visually. Normal aircraft environmental and operational limitations (and therefore the pilot's) far exceed what the autoland can do, so If you need it as a crutch to land in conditions other than what it was designed for you should find another line of work.
The FAA agrees with me once again.....
"Use of Autoland at U.S. CAT I Facilities or Equivalent. For CAT I, autoland may be used at runways with facilities other than those with published CAT II or III IAPs if the precautions discussed in subparagraph 4-282C are followed. This is to aid pilots in achieving stabilized approaches and reliable touchdown performance to improve landing safety in adverse weather.....".
"All operators approved to use autoland- or HUD-equipped aircraft should be encouraged to routinely use these systems at suitably equipped runways during operations in VFR and in CAT I IFR conditions."
"Use of this capability may be particularly important for pilot workload relief in stressful conditions of fatigue after long international flights; night approaches; crosswinds or turbulence; when there may be other aircraft non-normal conditions being addressed; or to aid safe landing performance in otherwise adverse weather, restricted visibility, or with cluttered runways. This is true even though reported visibility may be well above minimums (e.g., heavy rain distorting view out the windshield, snow-covered runways where markings are not easily visible)."
Yes, there are some precautions mentioned but my idea is definitely supported by the FAA. The AC incident report specifically talks about windshield distortion which is what my original post was all about. Thanks FAA.
http://fsims.faa.gov/wdocs/8900.1/v04%2 ... 02_005.htm
Here is Delta Airlines policy for one particular type..... "Except for facilities that have a restrictive note, autoland approaches are permissible to all [instrument landing system (ILS)] facilities. When a restrictive note regarding the localizer or glide slope appears on [an approach chart], autoland is not authorized."
https://www.ntsb.gov/_layouts/ntsb.avia ... 1318&key=1
Same as all the companies I've been involved with either as a pilot or training, although you're conveniently leaving out the cautions that go with it. You also keep refusing to acknowledge the differences between CAT I and CAT II/III runways and their effects that I keep posting here. Why?pelmet wrote: ↑Wed Oct 03, 2018 10:29 am Here is Delta Airlines policy for one particular type..... "Except for facilities that have a restrictive note, autoland approaches are permissible to all [instrument landing system (ILS)] facilities. When a restrictive note regarding the localizer or glide slope appears on [an approach chart], autoland is not authorized."
I'll ask the same kind of question I asked regarding landing distance calculations and give you a chance to not answer it too. What kind of airplane do you fly, and what is your company's policy regarding autolands with it on a CAT I runway?
