You're missing the point. The check would be useful, they already should have done it according to their SOPs. The check you are suggesting *was* already mandatory, yet they didn't do it. Piling on another check would not have helped this situation. It demonstrates that just throwing more mandatory checks to a crew does not work when they need it most.pelmet wrote: ↑Fri Nov 25, 2022 11:04 amYou might notice that I mentioned how a fuel leak could be found doing the check that I recommend. And guess what, I did discover a fuel leak one time(on a Citabria). You are welcome to stick to the belief that a quick check of items at top of climb is piling things on and won't help but it would have helped here. The reality, is that there are quite a few items that can be selected that are not on the regular checklist such as ice protection, radio selection, lights, fuel configuration, weather radar management, MEL items, etc. Most of these items have the potential to lead to some sort of an incident.digits_ wrote: ↑Fri Nov 25, 2022 8:06 amOn the contrary, this accident is a good example as to why extra checks are useless if you don't have the discipline to follow the ones you have. The company already had such a procedure in place to check the fuel at the beginning of cruise. But if you don't have the checklist discipline to perform the checks when necessary, then piling on extra checks won't help. Does that surprise anyone?
So more checks is the answer? Please...
If you already need to check an item *3* times, which this crew didn't do, do you honestly believe requiring the same check a 4th time would have made any difference?
