Here's a proof that
AoA is stationary (maximum, minimum, or point of inflexion) with respect to angle of climb/descent when, for a given airspeed, thrust is horizontal. It requires no knowledge of how the lift or drag vary with AoA other than that they both be continuous differentiable functions. It's therefore true for any lift/drag curve at all.
As before, the aircraft is rigged so the thrust line T is parallel to the zero-AoA direction. The direction of motion is shown right to left, parallel with the drag D, and β is the angle between the vertical (W) and the lift vector L, i.e. the angle of climb/descent. Without loss of generality (i.e. by choice of units) let W = 1.
See the following figure:
- Screen Shot 2013-12-02 at 3.20.00 PM.png (45.16 KiB) Viewed 1447 times
We wish to prove that if α = -β then dα/dβ = 0.
Applying elementary trigonometry to the diagram:
cos β = L + (sin β +D).tan α -- eq.1
Differentiate both sides w.r.t β
-sin β = dL/dβ + tan α.(cos β + dD/dβ) - ( (sin β+D)/cos^
2 α ).(dα/dβ) --eq.2
D and L are functions primarily of α but since a value of α fixes a value of β we can also consider them as functions of β.
Using the change of variable rule for differentiation:
dD/dβ = (dD/dα).(dα/dβ) and
dL/dβ = (dL/dα).(dα/dβ)
-sin β = (dL/dα).(dα/dβ) + tan α.cos β + tan α.(dD/dα).(dα/dβ) - ( (sin β+D)/cos^
2 α ).(dα/dβ) --eq.3
Therefore:
-sin β - tan α.cos β = (dα/dβ).[ (dL/dα) + tan α.(dD/dα) - ( (sin β+D)/cos^
2 α) ] --eq.4
now set α = -β. Then -sin β = sin α, cos β = cos α and the LHS is
sin α - tan α.cos α = sin α - sin α = 0, identically
therefore from eq.4:
(dα/dβ ) . [ some function of D(β) and L(β) ] = 0 --eq.5
If two quantities P and Q satisfy P.Q = 0 then either P = 0 or Q = 0 (or both).
In this case the term in the [ ] in eq.5 is not identically zero for all β, therefore the other part must be.
dα/dβ = 0.
QED.
