HS-748 2A
Re: Pic from a swamper
Post by HS-748 2A »
Thanks for that Bob - TNE looks pretty sharp.
Re SKY above though, aren't those Whips' it's on in Fiji?
beaverbob
Post by beaverbob »
The one pictured is not SKY. That is DQ-GWW SKY became DQ-GEE
Bob
HS-748 2A
Post by HS-748 2A »
beaverbob wrote:The one pictured is not SKY. That is DQ-GWW SKY became DQ-DEE
Bob
Gotcha.
beaverbob
Post by beaverbob »
DQ-GEE Serial 1358
beaverbob
Post by beaverbob »
Small Error should be GEE not Dee
Bob
Rudder Bug
Post by Rudder Bug »
Prairie Chicken
Post by Prairie Chicken »
I guess more dual is required as I've had no joy with either suggestion.
Are the ones in your Windows Photo Gallery on line or just saved on your hard drive? Did you upload them?
You can paste on here any photo or graphic that has a URL (http://www.whatsoever.jpg) Just right click on the photo and Copy, then right click to Paste them here, between the "Img" and "/Img" tags provided above.
The pics in Photo Galleray are on my hard drive, and they're ones I imported from my Nikon. From Photo Gallery, I tried copy & paste between the img brackets, and get nothing.
Or if your forum 'User Control Panel' (forum top right) is set up you can just go to the bottom of the post entry - place where you write your entries - and select "Filename", "Browse", then "Add File" right from your computer.
That didn't work either. It starts to copy a file, runs for a bit, and then quits. Leaves me with nothing, just as before starting. I'm thinking the problem is the size of my files? They tend to be pretty big ... 2 + mb.
Suggestions, or photobucket?
Prairie Chicken
Rudder Bug
Prairie Chicken
Go Photobucket, it's relatively easy and feel free if any question.
Good luck!
beaverbob
Post by beaverbob »
Hows this dock
Somewhere in the QC Islands
Northcoast Air Beaver 1987-88.jpg (430.65 KiB) Viewed 4816 times
Bushav8er
Post by Bushav8er »
Quote:
Or if your forum 'User Control Panel' (forum top right) is set up you can just go to the bottom of the post entry - place where you write your entries - and select "Filename", "Browse", then "Add File" right from your computer. End Quote.
You're right...problem is the file size, to big. Reduce them in file size and dimensions and try it again it'll work :wink:
xsbank
Post by xsbank »
Hey Beaverbob, NCAS? Can't read the name on the side but sure looks like GQA. Was that the one that was winched out of the water at Port Simpson? I have a photo in my logbook (not me!) but my old log is elsewhere. Rare sunny day. Love low tide and the dreaded dock pilings... :rolleyes:
beaverbob
Post by beaverbob »
Xbank, Yes Northcoast in 1987 and the plane is FGQF. I think the dock is at Skidigate. I don't know which one was winched out of the water.The quality of the picture is due to scanning a dusty slide.
Bob Bates
beechnut
Post by beechnut »
Bob If I remember correctly almost all of North Coasts planes have been winched out of the water at some time or other. Beechnut
jamesbay
Post by jamesbay »
Okay, dumb question, how is the best way to attach pics?
beaverbob
Post by beaverbob »
Click "post reply"
Scroll down to "upload attachment"
Click "choose"
Find picture on your hard drive from the screen that pops up.
Double click picture or picture file.
click "add file"
scroll back up and click "submit"
Note: Picture file will not upload if not a jpeg or is too big of a jpeg.
beaverbob
Post by beaverbob »
One more thing about posting pictures.
Scroll all the way to the bottom of any forum page and see the list of everything you can and cannot do.
It must say: "You Can post attachments in this forum"
Hope this is all clear enough.
Bob
jamesbay
Post by jamesbay »
Hey thanks, I'll give er a go.
beaverbob
Post by beaverbob »
Have you ever seen glassy water like this in Butte befor.
Not oftain.
I posted the wrong one and can't seem to remove it. The correct one has the dust mostly removed.
BB
A beautifull reflection 1.jpg (560.99 KiB) Viewed 4269 times
jamesbay
Post by jamesbay »
I'm sure some will recognize this plane.
03-05-2005 5-50-43 PM_0069.JPG (391.76 KiB) Viewed 4266 times
cplanedriver
Post by cplanedriver »
hey Fabulous Phil, is that you? If not sorry.. VQD flew resort work last summer in Mb.. Saw Phil with her in Thompson last June....
Fly Safe
cpd
jamesbay
Post by jamesbay »
A couple more.
30-04-2005 8-50-28 AM_0067.JPG (214.09 KiB) Viewed 4150 times
30-04-2005 5-26-31 PM_0068.JPG (429.6 KiB) Viewed 4151 times
19-07-2005 6-48-56 AM_0133.JPG (339.59 KiB) Viewed 4149 times
just curious
Post by just curious »
I recognize the Sabourin Colours, but not that flippin' big beak!
That's the last Otter built by deH. Fecteau bought it off the production line.
jamesbay
Post by jamesbay »
A couple of pics from a cheap camera.
xsbank
Post by xsbank »
Whatchew doing up above that 10/10ths puffy?
