The Inuit have thirty two different words for snow.
I do not know which one means: sticks like poop to a blanket. But the leading edge of snow in a winter warm front can stick to your airplane like poop to a blanket. Or even if our northern friends have a word for such snow. That is why it is so important to know where the fronts are located. So you can avoid flying along them in the danger zone.
Penetrating fronts should be done with extreme prejudice.
You must know where the air mass is coming from to determine the energy levels and moisture levels you can expect. The speed of front is an indicator of the fronts energy as well .The height of the frontal clouds can determine what kind of monster you might be fighting. It might look VFR underneath a cloud but if that cloud is going up to 50,000 feet avoid it, like eye contact in the men`s room at the San Francisco airport.
Most light aircraft have very limited ice protection :
-Pitot Static heat (sometimes they work)
-Carb Heat
-Fuel vent position in low air pressure area
-OAT
-very poor defrost venting that is usually the same standard as an early 1960`s sports car.
Most light training aircraft do not have any de-ice equipment such as boots ,TKS systems ,hot wings, or the ability to shed ice accumulations .
Ice costs a lot of money to fly with. Aircraft fly much slower when iced up and you may run out of fuel if you have not allowed for a forty knot speed reduction at cruise. Avoiding areas of big ice will save you money.
Flying a stalled aircraft is a challenge to most in training. Some flight schools never demonstrate how to fly an airplane when it is fully stalled. They rush to recover at the first sign of a stall .Recognition and Recovery is the exercise, and is usually done without much fun at the primary training level. Flying a fully stalled airplane requires lots of room and nice weather.
An iced up aircraft when it stalls will make you a test pilot and you better be on your best game to avoid death, disease and pestilence. Although if you are dumb enough to get that far down the rabbit hole as that you probably are not coming back out without help from the sky pixies being generous with their pixie dust.
Pay attention, lest the earth reach up and smite thee
