L-1011 help
L-1011 help
Procedures for pylon overheat? And if anyone has any Worldways, Transat, Royal, and/or Air Canada L-1011 manuals they would like to part with, please let me know.
Re: L-1011 help
F/E will advise which is the affected system
PNF, on command, will smoothly close the throttle
Hi Press Valve - Close
If the overheat warning goes out:
Operate engine at thrust setting that which keeps NACELE OVHT LT extinguished
If the overheat warning is on after 30 seconds:
Shutdown the affected engine using the Engine Failure/Precautionary Shutdown procedure.
L-1011-500 OH Section 4 PG17 Rev 39 05-01-00
Re: L-1011 help
That applies to Nacelle and/or Pylon overheat.
Re: L-1011 help
Curious as to why, if you are operating a L-1011, that you would not have the appropriate manual?L-1011 wrote:Procedures for pylon overheat? And if anyone has any Worldways, Transat, Royal, and/or Air Canada L-1011 manuals they would like to part with, please let me know.
Re: L-1011 help
Yeah... Good point. No active ElTens left in Canada... And an overheat seems a bit out-there for a desk flight sim failure.Longtimer wrote: Curious as to why, if you are operating a L-1011, that you would not have the appropriate manual?
WhiskeyWhiskey
Re: L-1011 help
Not sure what is more strange... A guy asking about a pylon over heat... Or xchox knowing the answer.
But xchox is right. I will throw in...don't fire the bottles just for a pylon overheat.
Re: L-1011 help
One of my favourites... Are there many (or any) still kicking around? Last I saw some pictures from Africa...
Re: L-1011 help
9 apparently active, including SN1067, former AC machine (FTNJ) now with Orbital Sciences.
I believe the RAF retired their fleet a few years ago.
