Just Could Not Kickout this Crosswind
John Desramaux
Post by John Desramaux »
schnitzel2k3
Re: Just Could Not Kickout this Crosswind
Post by schnitzel2k3 »
That's a great call. Most guys would've been trying to make that landing happen after the wheels touched down.
S.
Meddler
Post by Meddler »
I think they had already aborted when the wheels touched. At least I imagine that was the reason he had completely quit using the rudders by then.
Nark
Post by Nark »
schnitzel2k3 wrote:That's a great call. Most guys would've been trying to make that landing happen after the wheels touched down.
S.
It's a shame you believe that.
Semper Fidelis
av8ts
Post by av8ts »
Not sure if the winds were beyond the aircrafts or the pilots limits but good decision to go.
schnitzel2k3
S.
You think he should've just kept going with that? [no sarcasm]
S.
Might have worked out better if he lowered the wing into wind once he kicked the rudder in. Instead the wing actually is a bit in the wrong direction, he drifts then tries to get back to the centerline with rudder and is very nose into wind and not close to being straight.
Pretty easy to analyze from my seat here. Oh well, I've screwed it up before.:smt103
Nark
Post by Nark »
schnitzel2k3 wrote:
S.
S.
Not at all. What I was commenting on is that you assume most pilots will continue down a bad path.
Semper Fidelis
sstocker31
Post by sstocker31 »
Let me say first that I have no experience in the RJ85/146...only 737 here, your trying to make a nice landing out of it when you should of planted the sucker and got the spoilers out to do what they are supposed to do....
Rookie50
Post by Rookie50 »
Any guesses on the wind velocity?
CpnCrunch
Post by CpnCrunch »
Rookie50 wrote:Any guesses on the wind velocity?
24019G31KT
http://origin.flightaware.com/live/flig ... /EGLC/EICK
http://www.ogimet.com/display_metars2.p ... &send=send
Looks like a direct crosswind.
Rookie50
Post by Rookie50 »
Hmmm. Wonder what the limts are on different gear. Know a friend of mine who flies a light bizjjet, he says it's good to 25 direct
CpnCrunch
Post by CpnCrunch »
https://www.regional-services.com/files ... ance_2.pdf
"Demonstrated crosswind component 35 kt"
From the video, it looks like the pilot kicked out half the crab, then went back to full crab before landing, then gave up when it was obvious that the plane was landing sideways. I'm not sure what the correct technique is for this plane, but I'm guessing some combination of kicking out the crab, wing down, and planting it on the ground would have done the job...in my professional armchair opinion.
schnitzel2k3
[/quote][/quote]
I've met enough pilots that would've kept fighting, especially once those wheels hit. Not saying all, and my overly dramatic comment of 'most' probably could've been downgraded to 'some'.
Fair enough Nark? :wink:
S.
Nark
Post by Nark »
S.
I like it.
I will be so bold and to say most pilots don't have the stick and rudder skills to make a x-wind a non event.
Semper Fidelis
springlocked
Post by springlocked »
What can I say ------------ it's a smerf jet :smt040
schnitzel2k3
S.
I like it.
Agreed! Especially one approaching the demonstrated limits of a machine.
S.
Broken Slinky
Post by Broken Slinky »
Passengers on the left side would have enjoyed a nice view down the runway on that one. :)
Strega
Post by Strega »
I think he could have stuck it fine if he actually pushed, and held the rudder... mysterious control to some...
