TSB Deployed to Calgary for Westjet Encore "incident"
Axial Flow
Post by Axial Flow »
Longtimer
TSB Coming to YYC to investigate Encore Incident
Post by Longtimer »
Have not seen any reports on the incident, anyone have any info?
TSB deploys a team to Calgary, Alberta, to assess an aircraft incident
Edmonton, Alberta, 10 February 2016 – The Transportation Safety Board of Canada (TSB) is deploying a team of investigators to the Calgary International Airport to an incident involving a Bombardier DHC-8 operated by WestJet Encore. The TSB will gather information and assess the occurrence.
The TSB is an independent agency that investigates marine, pipeline, railway and aviation transportation occurrences. Its sole aim is the advancement of transportation safety. It is not the function of the Board to assign fault or determine civil or criminal liability.
For more information, contact:
Media Relations
819-994-8053
media@tsb.gc.ca
J31
Re: TSB Coming to YYC to investigate Encore Incident
Post by J31 »
TSB investigates WestJet 'electrical fault' on flight from Terrace to Calgary
http://www.cbc.ca/news/canada/calgary/t ... -1.3442958
arctic_slim
Post by arctic_slim »
never mind, I see now that it was Tuesday night incident. The one this morning probably had nothing serious.
Donald
Post by Donald »
According to another forum, after landing it was discovered that the electrical fault had caused a short circuit and fire in the wheel well area.
Vern
Re: TSB Deployed to Calgary for Westjet Encore "incident"
Post by Vern »
KK7
Post by KK7 »
Kudos to the crew for a job well done.
Donald
Post by Donald »
http://avherald.com/h?article=493c9d78&opt=0
A Westjet Encore de Havilland Dash 8-400, registration C-GWEP performing flight WS-3240 from Terrace,BC to Calgary,AB (Canada) with 31 people on board, was enroute at FL250 about 110nm northwest of Calgary when the crew received caution messages related to various electrical systems. The crew worked the according checklists, consulted with company maintenance and continued the flight to Calgary, where the aircraft landed safely about 30 minutes later.
The Canadian TSB reported maintenance found evidence of fire in the right hand wheel well. Damage was found on the AC contactor box, surrounding structure and the right hand main gear leg. Two investigators were dispatched to Calgary.
