Pt6
... gooooo onlazyeight wrote:Expect a big announcement around the same time.
Most certainly a base realignment with the possible reopening of the YVR RJ operation as there jets shift out of YYZ is the big rumour.PositiveRate27 wrote:... gooooo onlazyeight wrote:Expect a big announcement around the same time.
We shall see...Pt6-42 wrote:Thanks , hope this announcment is for the better ... Ie pay or sced.. But i wont hold my breath.... Its aviation
Probably not but with the way things have been going in the last year who knows what could happen. Get your ATPL exam done, 500MPIC and close to 1500 hours and you'll help your cause.Pt6-42 wrote:Do you think anyone with around 1000tt with 800 multi would have a chance?
I'm crossing my fingers for a CPA revision and CS100's. But I think that's a bit pie in the sky.AllClutch wrote: Most certainly a base realignment with the possible reopening of the YVR RJ operation as there jets shift out of YYZ is the big rumour.
Although this is probably what air canada management would like (it would save them tons of money), this is not what any Canadian pilot should want!lazyeight wrote: I'm crossing my fingers for a CPA revision and CS100's. But I think that's a bit pie in the sky.
Could we see AC start to focus more on International routes over the next years and Jazz becoming the "domestic" Air Canada?
I would love to see it, but the consensus seems to be the RJ going back into YVR. Hopefully youre right!Rowdy wrote:YVR RJ base returning? while it could happen.. it is unlikely, even though many YVR pilots wish and dream of it's return... It employs many Seasonal routes. YYC has them covered. They also don't overnight a ton of crews in YVR. The Q however.. we looked at numbers, anywhere from 4-6 crews a night in YVR which is the most expensive spot in the system. Not to mention the number of DH's to YVR from YYC for it, or the many who live in the YVR that commute to YYC being only a tiny piece of the puzzle. With solid load factors on the Q out of YLW, YYJ,PDX, SEA, and even YCD it would certainly make financial sense for a YVR Q base, especially with pressure from Encore.
Should see a lot of changes when this bid comes up in august.I for one hope it doest get massively delayed. Should see some significant opportunity. It'll be an interesting one thats for sure.
PML 2.0 perhaps?lazyeight wrote:Expect a big announcement around the same time.
