AVCANADA
It is currently Thu Oct 19, 2017 2:39 am
Post new topic  Reply to topic  [ 178 posts ]  Go to page 1 2 3 4 58 Next
Author Message
PostPosted: Wed Oct 12, 2016 1:20 am
Offline
New rfp was supposed to come out? Anyone have any info?
Top
PostPosted: Wed Oct 12, 2016 5:32 am
Offline
It's already come out and closed. I think the results are supposed to be announced by the end of October.
Top
PostPosted: Thu Oct 13, 2016 10:12 pm
Offline
Any new metal in the bids or still 200's?
Top
PostPosted: Fri Oct 14, 2016 7:52 am
Offline
Grouping northern Alta.
Top
PostPosted: Tue Nov 01, 2016 10:56 am
Offline
were supposed to be... sounds like longer now
Top
PostPosted: Wed Nov 02, 2016 3:38 pm
Offline
Any update on this?
Top
PostPosted: Mon Nov 07, 2016 8:00 pm
Offline
Any updates yet!
Top
PostPosted: Mon Nov 07, 2016 8:52 pm
Offline
Should be out by end of November hopefully. But AHS being another part government entity, it'll show up when ever it does. Northern Alberta RFP requires upgrade of aircraft, King Air 250s I think. Or quite newer 200s anyway.
Top
PostPosted: Tue Nov 08, 2016 1:24 am
Offline
What a shame they don't use PC12s, far better ship for the mission.
Top
PostPosted: Tue Nov 08, 2016 10:20 am
Offline
Personally I think the King Air is the perfect machine. Most of the missions are less than an hour of flying time, and it's just easy to do in a King Air. There is a company that uses a Twin Otter that is retrofitted for bariatric patients. so for the heavier set patients, a wider body Twin Otter or 1900 is also available and great. I'm sure the PC-12 is a very capable airplane for a similar mission, but having two turboprop engines is a must for AHS contracts. And personally, I prefer it that way too.
Top
PostPosted: Wed Nov 09, 2016 12:44 pm
Offline
It's really the rear door, size of the cabin, better landing gear and better sort field performance.
The multi engine saftey thing is more of a marketing pitch, how many MEDEVAC PC12s have gone down due to a engine failure?
Top
PostPosted: Wed Nov 09, 2016 1:30 pm
Offline
The multi engine saftey thing is more of a marketing pitch, how many MEDEVAC PC12s have gone down due to a engine failure?[/quote]
It only takes On
Top
PostPosted: Wed Nov 09, 2016 1:49 pm
Offline
What's wrong with King Air doors?
Top
PostPosted: Wed Nov 09, 2016 2:41 pm
Offline
Someone correct me if I'm wrong, but I believe that's an FAA only approved door mod. Not approved however by TC.
Top
PostPosted: Wed Nov 09, 2016 6:25 pm
Offline
Beech makes king airs with the cargo door on them from factory, plus there's the STC available through Avcon that installs the same door that the beech factory installs, plus a smaller version of the cargo door as well. Both are STC modifications not just 337 form modifications. Just like putting Raisbeck wing lockers, or the lifeport system on with an STC
Here's the page for the cargo airstair combo door:
http://www.avconindustries.com/product_details.php?id=9
And the smaller "baggage" door:
http://www.avconindustries.com/product_ ... .php?id=14
There might be other companies out there making this type of modification as well, this is the one I've heard of.
Top
PostPosted: Wed Nov 09, 2016 7:31 pm
Offline
Well dont tell PNR, or Central region. NAC, and helitransport both run KA's with the big door
Top
PostPosted: Wed Nov 09, 2016 8:51 pm
Offline
hopefully the Cargo door is legal and approved by TC. I've seen a few of them flying around up north already.
In terms of PC-12 single engine VS. the twin turbine, yes, obviously it looks great on paper. But I would never ever want to see even a single one go down with pilots, medics, patient or even the patients family on board, which is common practice in the king air medevacs. It only takes one accident to change the course of history. I might be biased , but I prefer my airplanes with more than one engine.
Top
PostPosted: Thu Nov 10, 2016 11:40 am
Offline
The only 200 I've ever seen with the cargo door was Tindi's, which is a B200C from the factory. Looks great but I think it has a lower pressure differential than a regular B200 which can be an issue for some patients and can effect your range.
Top
PostPosted: Thu Nov 10, 2016 11:08 pm
Offline
Why buy some fancy king air when a metro will do?
Big cargo door
Faster
Less fuel burn
Better cabin diff = lower pax cabin
Literally the only downside I can think of is noise
Top
PostPosted: Fri Nov 11, 2016 12:31 am
Offline
Because metro's are garbage
Top
PostPosted: Fri Nov 11, 2016 10:43 am
Offline
Big cargo door
Faster
Less fuel burn
Big door is generally not required, but can be STC'd.
Faster? Not too sure about that. With the -42 it will do 270kts and the -52 will touch 300kts. The King Air also climbs faster, so it's at altitude and cruising earlier. For the same stage length, I bet the race would be extremely close.
Okay, the Metro burns less fuel
Comparing 6.5 PSID to 7.0 really isn't worth mentioning.
How about ability to climb out of icing or above weather? The King Air is still making 850hp per side into the mid-teens and doing 1000+ fpm at FL280. How does the metro perform at 28,000ft?
King Airs also have better dispatch reliability and are more dependable.
I haven't met a pilot or mechanic that prefers the Metro over a King Air. Beechcraft are better to fly and easier fix.
If you are in a car crash, would you rather have a Chevy ambulance with a big turbo diesel V8 and studded winter tires come to get you, or a Oldsmobile with a straight-6 and Toyota Prius tires, because it burns less gas?
Top
PostPosted: Fri Nov 11, 2016 12:49 pm
Offline
Big cargo door
Faster
Less fuel burn
You know you've never flown a King Air when . .
To be honest, to cruise around North America with my family, I prefer a King Air 350 over most light jets!
Top
PostPosted: Fri Nov 11, 2016 1:36 pm
Offline
Same pressurization limitations, and no negative effects on patient care. Primarily used due to contractual obligations for Bariatric transport, but can obviously be used for 'normal' medevac missions as well. Also makes loading/unloading a walk in the park!
_________________
YG
Top
PostPosted: Fri Nov 11, 2016 2:00 pm
Offline
[quote="goingnowherefast"][quote="fish4life"]Why buy some fancy king air when a metro will do?
Big cargo door
Faster
Less fuel burn
Any Metro with the -10 Garrett is making 1,000 HP continues.
Top
PostPosted: Fri Nov 11, 2016 3:26 pm
Offline
Not at FL280 you're not!!! If you're not at 100% Torque and 100% RPM, then you are not making full rated horsepower.
BTW, the Metro 3 and 23 have -11, and -12 engines with even more power, but they still can't produce 1000 HP at FL280
Top
Who is online
Users browsing this forum: bhuntsy, Victory and 18 guests
Search for:
Jump to:
[ GZIP: Off ]
avcanada@gmail.com
AvCanada Topsites List
