What to know before training starts
Freakflyer
I am trying to get a jump on learning prior to receiving and offer for training. Just wondering what IATA codes should be memorized (Moncton FIR).
Re: What to know before training starts
I wouldn't really bother learning that before you get started. There's a list of like 60 or so (I'm going by memory here) airport identifiers you need to have memorized (Canadian, US and international), but you should have plenty of time to learn them before the ITA.
Unless I am mistaken, IATA codes won't do you much good in the ATS business. ICAO codes will be used in flight planning, and while the conversion from IATA to ICAO for domestic airports is fairly straightforward, basically everything outside of the US and Canada is completely different.
Good luck.
Good luck.
Freakflyer
Thank you NotDirty!NotDirty! wrote:Unless I am mistaken, IATA codes won't do you much good in the ATS business. ICAO codes will be used in flight planning, and while the conversion from IATA to ICAO for domestic airports is fairly straightforward, basically everything outside of the US and Canada is completely different.
Good luck.
I didn't realize that. Well, I guess I will start looking at the major N.American cities for their ICAO codes.
Do you have previous aviation experience? If not read as much as you can about airlines, airplanes, ATC in general, VFR flying, IFR flying and anything else related. The most common complaint amongst training teams is lack of general knowledge by the new employees. If you know in advance that you know nothing about aviation it is time to start reading up.Freakflyer wrote:Thank you NotDirty!NotDirty! wrote:Unless I am mistaken, IATA codes won't do you much good in the ATS business. ICAO codes will be used in flight planning, and while the conversion from IATA to ICAO for domestic airports is fairly straightforward, basically everything outside of the US and Canada is completely different.
Good luck.
"From the Ground Up" (book) is an excellent way to get general information on aviation. Teaches you everything from meteorology to theory of flight.Braun wrote:Do you have previous aviation experience? If not read as much as you can about airlines, airplanes, ATC in general, VFR flying, IFR flying and anything else related. The most common complaint amongst training teams is lack of general knowledge by the new employees. If you know in advance that you know nothing about aviation it is time to start reading up.Freakflyer wrote:Thank you NotDirty!NotDirty! wrote:Unless I am mistaken, IATA codes won't do you much good in the ATS business. ICAO codes will be used in flight planning, and while the conversion from IATA to ICAO for domestic airports is fairly straightforward, basically everything outside of the US and Canada is completely different.
Good luck.
TheSealRimRady
I don't think it's worth your time to try and find what airport codes they'll expect you to know before even receiving a course offer. Once you get your course offer, go to town on the ITA material!
I know where you're coming from, but enjoy your free time. If/when you start training, there won't be much of it!
Freakflyer
Happy New Year all!
Thank you Braun, fanman888 and TheSealRimRady,
Sorry for the late reply...I have been enjoying family over the holidays. I did order From The Ground Up and have started reading it. I have very little aviation experience. The little I have learned was from skydiving, but that barely scratches the surface. Braun, what should I know about airlines? The other topics you listed make sense, but just wasn't sure what I would need to know up front about airlines.
Thanks again guys. I appreciate all the info.
