YQB terminal
Message
Author
av8ts
YQB terminal
#1 Post by av8ts » Tue Mar 28, 2017 4:30 am
Sunday night the terminal radar was down for a while. There was a Jazz flight arriving from YUL planning the ILS 06. Flight was told because no radar the flight could not go direct to the IF for a straight in, after holding they had to do the full procedure (yes in 2017). Many airports we go to have no radar yet direct to fixes are allowed. Imagine if everyone was doing full procedures in YTS. Anyone explain this?
Canoehead
Re: YQB terminal
#2 Post by Canoehead » Tue Mar 28, 2017 7:16 am
So they were holding at the IF or someplace else?
A PT is not for the benefit of ATC... they would have cleared the flight for the approach only after the previous lander was reported down by the tower.
I'm only going to do a PT if there's no IF, no lead radial, or if I'm inbound from a direction where the PT makes sense.
If they were holding everyone at the VOR, then yes, a PT via QB is about the only way to conduct the approach correctly.
I miss the good old days in YTS of using all the navigation tools- ARC's, PT, circling- all to move traffic as expeditiously
as possible in a non-radar environment. Required everyone to be in the loop and on their game. But I'm weird like that :lol:
av8ts
Re: YQB terminal
#3 Post by av8ts » Tue Mar 28, 2017 7:44 am
They held at Pesac. After the previous a/c was down they requested direct to Kavat for the ILS but terminal said can't allow with no radar. So they were cleared to the VOR for that transition to the ILS which meant a procedure turn.
av8ts
Re: YQB terminal
#4 Post by av8ts » Tue Mar 28, 2017 7:47 am
I just looked at the plates. If 24 would have been active would that mean the NDB would be the only approach available?
Canoehead
Re: YQB terminal
#5 Post by Canoehead » Tue Mar 28, 2017 8:29 am
Well in a non-radar environment, ALNIB would be the place to go to commence a straight-in, as it's the IF. KAVAT technically wouldn't be legal.
As for not being able to go to any fix direct, I'm not sure why not, but I'd assume it was for separation from the previous traffic? But altitudes would be the trick here I'd imagine (like in YTS)? I don't know- I'm not a controller... but can't see why you can't do the RNAV to any runway either (unless it specifically says RADAR REQ'D). Perhaps an airspace structure thing?
Say Again, Over!
Re: YQB terminal
#6 Post by Say Again, Over! » Tue Mar 28, 2017 3:16 pm
When the CYQB radar is off line, radar coverage in the terminal is essentially nil. We can see airplanes above 10,000 about 15-20nm west and it goes steadily higher as you look east. Traffic at SIMTO cannot be seen on radar at 16,000.
In the case you mention, the problem becomes one of "airspace to be protected". On a NAVAID airway, the width of the airspace to protect is about 8 miles (4 either side). On RNAV routes or point to point navigation, we have to protect 10 miles either side of the track. You can see how this quickly becomes problematic. To take someone from PESAC to ALNIB or KAVAT, the swath of airspace encroaches on other sectors and departure routes. Furthermore, we don't actually have a plot board where we can draw this out. so if someone else is in the airspace, we then have no way to determine for sure if their airspace blocks touch or not. We're therefore stuck with not many options to improvise and we chose to use something very simple (if grossly inefficient). The tracks to the VOR are routes that are 8nm wide. That helps us clear up some departure routes should they be needed. They all lead to a hold at the YQB VOR, which has it's own defined airspace block. From there, we know at what distance we can climb or descend other traffic.
This is something that happens very infrequently and for which we don't train very much. Our goal with these non-radar procedures is to offer some service with as little complexity as possible for the controllers involved so as to avoid jeopardizing safety. If procedures are too complex, we risk having confusion as to what rule can be applied where. Don't forget, our people in CYQB TCU are trained with radar which they use 99.99% of the time. We realize that at that moment when our radar goes off, there are many other airports up north that can handle more traffic than us. We know it and it's frustrating for us too! But we can't make complex procedure that people might never use for months or years. That would be unsafe. The controllers that specialize in "procedural" control and work those airports up north with stream lined procedures do so with great efficiency because of the procedures they know, train and work with.
Hope that helps clarify this! If you have more questions, don't hesitate!
Felix
Felix
YUL ACC
QB & OW TCU
av8ts
Re: YQB terminal
#7 Post by av8ts » Wed Mar 29, 2017 4:37 pm
That makes sense and answers my questions.
kilocharliemike
Re: YQB terminal
#8 Post by kilocharliemike » Thu Mar 30, 2017 7:24 pm
I think it was our medevac ahead of that Jazz AC, we also got cleared for the approach to 06 via YQB transition, the fms wanted to fly the procedure turn but we were cleared visual and just went in at the ndb. did Jazz do the PT?
KCM
kilocharliemike
Re: YQB terminal
#9 Post by kilocharliemike » Thu Mar 30, 2017 7:25 pm
KCM
