Enerjet Twin Otter ?
Looks like Enerjet no longer has any Boeing's listed on the Canadian register. The only airplane that shows up is a Twin Otter, C-GKTM, registered since June 1st.
Are they using it, or maybe just a sub lease to someone else ? Is the Boeing operation done ?
Mark: C-GKTM
Common Name: Dehavilland
Model Name: DHC-6 SERIES 300
Serial No.: 844
Base of Operations: Airdrie - CYYC, Alberta, CANADA
Registered Owner Information
Name: 1263343 Alberta Inc.
Address: #119-1440 Aviation Park N.E.
http://wwwapps.tc.gc.ca/saf-sec-sur/2/c ... hSimp.aspx
URC
Mark: C-GKTM
Serial No.: 844
URC
Re: Enerjet Twin Otter ?
Keeping the OC alive while the cash rolls in to start a ULCC.
So for all the CAR's experts out there. How does Enerjet maintain Operator Details (OC..?) for a Boeing 737 with only a wrecked Twin Otter on the registry?
http://wwwapps.tc.gc.ca/saf-sec-sur/2/C ... 2&lang=eng
http://wwwapps.tc.gc.ca/Saf-Sec-Sur/2/C ... hSimp.aspx
The last 737 left in Feb 2017.
http://wwwapps.tc.gc.ca/Saf-Sec-Sur/2/C ... RchHs.aspx
705.01 This Subpart applies in respect of the operation by a Canadian air operator, in an air transport service or in aerial work involving sightseeing operations, of any of the following aircraft:
(a) an aeroplane, other than an aeroplane authorized to operate under Subpart 4, that has a MCTOW of more than 8 618 kg (19,000 pounds) or for which a Canadian type certificate has been issued authorizing the transport of 20 or more passengers;
The Twin Otter is certified for 20 pax:
SECTION 2 TC Approved
LIMITATIONS DHC-6 SERIES 300
2.14 Occupancy Limitations
Para 2.14: Occupancy Limitations
22 occupants including all flight crew.
No, it's certified for 22 occupants, including all flight crew. To go over 19 pax you have to have 1 Flight Attendant. If you had 20 pax, plus 2 pilots, plus 1 FA you would have 23 occupants. It's only certified for 19 pax plus an FA plus 2 pilots.Brint wrote: ↑Wed Apr 11, 2018 7:36 am 705.01 This Subpart applies in respect of the operation by a Canadian air operator, in an air transport service or in aerial work involving sightseeing operations, of any of the following aircraft:
