Canadian STC on N registered aircraft
skymarc
Post by skymarc » Sat Aug 05, 2017 7:05 am
Can you put a Canadian STC only mod on an N registered plane?
Im talking about some skis that are only STC in Canada. Are these legal to fly on N registered aircraft in the US?
AirFrame
Re: Canadian STC on N registered aircraft
Post by AirFrame » Sat Aug 05, 2017 8:08 am
skymarc wrote:Can you put a Canadian STC only mod on an N registered plane?
Given the general level of reciprocity between the US and Canada in aviation matters, it wouldn't surprise me if you could. But the best place to ask is the FAA, as they regulate the N registered aircraft.
helicopterray
Post by helicopterray » Sat Aug 05, 2017 12:14 pm
You will have to submit a Form 337 for modifications to the FAA. Use the supporting data from the Canadian STC.
skymarc
Post by skymarc » Sat Aug 05, 2017 5:45 pm
Would the owner need approval or just submiting the 337 is fine?
helicopterray
Post by helicopterray » Sat Aug 05, 2017 11:49 pm
The Form 337 is from the AME signing out the maintenance release. It would be a pretty good idea to let the owner know you're doing it.
Return to “Maintenance”
