How are People Filing IFR Flight Plans?
Several flight planning websites like Fltplan.com, Jetplan.com etc offer an ability to file online. Nav Canada has the "Collaborative Flight Planning System" ( https://plan.navcanada.ca ). Some guys are calling it in on the phone. I personally like having an electronic or hard copy of exactly what I filed and ATC has on their end.
What's the best way to file these days?
Re: How are People Filing IFR Flight Plans?
Sounds archaic but Fax is the way to go
I have run into problems filing on the phone (cleared FPR and they didn't accept the filed route) so I like filing with NavCanPlan. Works well and it's easy to take a screenshot. I'll still file on the phone though if a computer isn't handy or I don't have time.
Phone or Foreflight, which emails you confirmation of filing, and your route clearance if filing IFR.
Normally call it in.
Wahunga!
Over the phone worked best. Fltplan.com had issues with northern routes sometimes. Once you are used to the system, the phone works almost as quickly.
SuperchargedRS
- HiFlyChick
Phone has proved most reliable so far
+ 1 on Fltplan, I really like the preferred routes that show up.
"I need a time machine"
I really like CFPS, but there is one dumb thing. The master flight plan list I made of 10 or so flights I often fly populates Navcanada's computer with 10 master flight plans. Multiply that by the half dozen pilots at out company using it and when someone phones in a flight plan the FIC or ACC has to sort through 25 "masters" to figure out which one is accurate.
I liked having a catalogue of flight plans available so all I had to do was change the ETD, and number of pax. I deleted all but 2 of my plans after Navcan complained, now I have to change a dozen fields and already I've made a few dumb mistakes, which is a combination of medevac rush rush, and trying to look at the ICAO form on a cell phone screen.
ForeFlight. Takes a bit to get used to but once you figure out the features it’s pretty slick.
praveen4143
I hope one of the NavCan FIC guys/gals can jump in here and share their $0.02... But when I last spoke to one of the briefers at the FIC in Kamloops, he said that they hated the flight plans that came from Foreflight and other flight planning software because the flight plans didn't mesh well with their systems and they had to manually edit/correct each flight plan that came their way. He mentioned having to call back the odd person to confirm certain parts of the flight plan because of this issue.
Phone to Flight Services is always the fastest and the most reliable IMHO. I want to say I’ve gone from filing to copying a clearance inside of ten minutes doing it that way.
Nothing worse than having to sit with engines running on the phone to IFR data or FIC when the faxed or electronic flight plan hasn’t gone through or you get an abortion of a clearance because FIC had to fix all of the mistakes.
- confusedalot
It's been awhile since I had to file my own flight plans....the phone in my era was the easiest, even up to 2006, if not the only option.
Sad to hear that in our connected world, that it is not always efficient to file something so easy, and that we rely on old tech. to do this basic job.
Hell, you can order pizzas online...............
- Brantford Beech Boy
We use Fltplan.com.
At a prior company, I used to use the Nav Canada online filing system way back in 2005ish (when dinosaurs roamed the Earth...)
never had any issues with Fltplan. Have filed online and gotten the clearance in less than 5 minutes.
We do lots of trans-border work and their eAPIS program is worth every penny.
The one thing I would like to see is the ability to file IFR itineraries electronically. In this situation, which is the norm for most northern ops, the phone is the best (only!) method.
BBB
BBB
I found this out too by doing the same thing (VFR not IFR). Even the previous owner's master flight plan is still showing up in the system.co-joe wrote:I really like CFPS, but there is one dumb thing. The master flight plan list I made of 10 or so flights I often fly populates Navcanada's computer with 10 master flight plans. Multiply that by the half dozen pilots at out company using it and when someone phones in a flight plan the FIC or ACC has to sort through 25 "masters" to figure out which one is accurate.
Once (and only once) I filed a VFR online through CFPS, and when I went to close by phone it was not in their system. All other times it has worked, but it was a bit unnerving.
Jet Jockey
Instructor_Mike
Strictly over the phone. IFR flight plan or Itinerary for multiple uncontrolled airport hops.
We use an excel sheet with some macros for our flight planning. Our Chief of Ops is really good with that stuff. Since we mostly just go to the 5 same airports repeatedly I do it from memory usually.
Depart timmins at 1200 zulu, 17 thousand direct, Moosonee 55 minutes enroute, Alternate Timmins, 4.5 hours fuel, 2 plus manifest and then captain is me.
(Assuming full fuel for another trip starting in Moose)
lostaviator
Just don't turn my transponder on. They don't even know I'm there.
But phone... In the time it takes to sign in online, etc, I could have already talked to someone at FIC, and been on my way to get a coffee. Plus it's nice to support fellow staff in aviation in an era of jobs going to computers
The eApis part of Fltplan as stated earlier is the best part and worth every penny. The only issue I have had is accidently inputting Zulu time instead of Local. I wish they would allow you to select your preference.
This brings up a good point. When I file VFR through CFPS it goes straight to the FIC and the ACC cant close flight plans for me, but when I file IFR through CFPS it only goes to the ACC. The odd time I've needed to get FSS to make changes while enroute, they don't have access to my flight plan and have to phone the ACC to make changes.ScottS wrote:I found this out too by doing the same thing (VFR not IFR). Even the previous owner's master flight plan is still showing up in the system.co-joe wrote:I really like CFPS, but there is one dumb thing. The master flight plan list I made of 10 or so flights I often fly populates Navcanada's computer with 10 master flight plans. Multiply that by the half dozen pilots at out company using it and when someone phones in a flight plan the FIC or ACC has to sort through 25 "masters" to figure out which one is accurate.
Having two separate departments that don't seem to have access to eachother's computers seems bureaucratic in nature.
I had a acquaintance doing that in a high performance bird at around 12-14000 feet, because he didn't want to deal with Nav Can, think about that next time you drop thru 12500 in IMC, I do! I corrected the behavior.lostaviator wrote:Just don't turn my transponder on. They don't even know I'm there.
Problem with master flight plans in CFPS is that many pilots think it's like a "saved list" and multiple copies of flight plans are saved that way. Sometimes, master plans for the same aircraft contain different data (example: equipment, colors, etc). That forces us to confirm all the information on the phone when using a master, which almost takes as much time as starting a FP from scratch. IMO, master plans should be created and updated by the owner only, while leaving the possibility to the different pilots to save different flight plans, but locally only.co-joe wrote:I really like CFPS, but there is one dumb thing. The master flight plan list I made of 10 or so flights I often fly populates Navcanada's computer with 10 master flight plans. Multiply that by the half dozen pilots at out company using it and when someone phones in a flight plan the FIC or ACC has to sort through 25 "masters" to figure out which one is accurate.
As for VFR flight plans forwarded to the FIC and the IFR ones to the ACC, it's for the purpose of alerting service. All the data is then sent to CAATS and the FIC can see all the IFR flight plans, but just some limited data in forms of flight strips (at least here in QB). Normally, ACC should be able to close your VFR flight plan though, as we are able to close IFR flight plans. However, I agree that there is still a lot of work to be done for better systems integration.
This has been dramatically improved since the beginning, There has been some work to correct many problems. Still not perfect, but much better now. CFPS is still the preferred way. However, flight plans filed using any online tool sometimes contain errors caused by the lack of knowledge from the user.praveen4143 wrote:I hope one of the NavCan FIC guys/gals can jump in here and share their $0.02... But when I last spoke to one of the briefers at the FIC in Kamloops, he said that they hated the flight plans that came from Foreflight and other flight planning software because the flight plans didn't mesh well with their systems and they had to manually edit/correct each flight plan that came their way. He mentioned having to call back the odd person to confirm certain parts of the flight plan because of this issue.
