Page 1 of 1
Cold weather oil indications
Posted: Wed Jan 31, 2018 11:41 pm
by rigpiggy
We had some issues with oil press indications in the cold, the first guy i flew with had several 206/185s. He used to fill the oil pressure tube with hydraulic fluid every fall.
I gots to tell ya it works like a hot damn, oil pressure within seconds, ask your ame if you have similar issues
Re: Cold weather oil indications
Posted: Thu Feb 01, 2018 5:24 am
by valleyboy
The good old days -- mention that now and most AME's will look at you if you had 2 heads -- simply put in this day of CYA, it's not legal. I wonder if external gauges mounted on the cowls is an approved mod
Posted: Thu Feb 01, 2018 6:54 am
by SuperchargedRS
rigpiggy wrote: ↑Wed Jan 31, 2018 11:41 pm
What kind of temps are we talking here?
I've had my 185 out to about -28c and never had that issue
Posted: Thu Feb 01, 2018 11:30 am
by valleyboy
It usually happens with a cold soaked aircraft (stored outside and plugged in) between -30 and -40 (40 being the cut off point) - no problems with a hangared aircraft. The issue a lot of the times was to get oil pressure indication for the initial start in the morning or after sitting for a couple hours with raps on.
Posted: Fri Feb 02, 2018 5:31 am
by Heliian
Oil pressure should come alive withing 30 seconds of start.
Posted: Fri Feb 02, 2018 9:04 am
by J31
Flew lots of 185, 206, 207 down to -40 and rarely any problems with multi-grade oils. However we did clean the oil lines out with varsol if there were problems. This would introduce fresh engine oil in the lines.
Posted: Mon Feb 05, 2018 1:24 pm
by rigpiggy
The oil theat was pumped out of the lines in the hangar could only be decribed as "grease"
Posted: Mon Feb 05, 2018 1:25 pm
by rigpiggy
That and we are in a twin. The oil lines are about 8' long, all but about 2' is in unheated spaces
