Is this a good reason for a high speed RTO?
C-FCAF, a Boeing 767-375 aircraft operated by Air Canada, was conducting flight ACA792 from Los Angeles/Los Angeles Intl, CA (KLAX) to Toronto/Lester B. Pearson Intl, ON (CYYZ) with 8 crew members and 211 passengers on board. On takeoff from Runway 25R, a Right Generator failure occurred when the aircraft was travelling at approximately 130 knots. The flight crew elected to abort the takeoff, without further incident. The operator’s maintenance replaced the right hand IDG as per AMMM24-11-01 PB 401, and a test run confirmed serviceable.
confusedalot
Re: Is this a good reason for a high speed RTO?
Post by confusedalot »
Oh boy, here we go.......
My vote is no. But what do I know.
GRK2
Post by GRK2 »
Generally speaking NO.
High speed rejects in heavy jets is a tricky subject and may heat up brakes and wheels to the extent that overheats might occur. Almost all operators will state that in the high speed regime (over 100 KIAS) reject BEFORE V1 only for:
1) Engine fail (with 2 parameters)
2) Engine Fire Warning
3) ANY Fire Warning
4) Traffic (ATC call included here)
5) Take Off Config Warning (although almost all of these occur before thrust is even set...Low Speed Warning)
6) Any warning which leads to the belief the aircraft may not safely fly.
In general, below 80Kts...reject for any caution light/aural. Between 80-100 only for a Warning light/Aural. See above for high speed. (A Generator fail is a caution light/warning on the B767... FWIW)
I won't armchair this one...wasn't there so can't comment.
goingmach_1
Post by goingmach_1 »
who gives a sh_t. Nobody got hurt, good job. Move on
rudder
Post by rudder »
RTO below 80kts is a non event. Auto brakes are not even armed. EICAS caution messages not inhibited.
Above 80kts any RTO is a potentially risky maneuver. I don’t mean 81kts, but more like V1-5kts, particularly on a runway that is balanced due to reduced T/O thrust setting.
Delta used to teach “fire/fear/fail/shear” as the high speed RTO criteria. Any fire indication. Any power plant failure. Any wind shear indication. And lastly - any other item which in the opinion of the Captain made continued flight less safe than RTO.
Many EICAS caution messages are inhibited in the high speed take off regimen. Generator is not one of them so it is a judgement call.
Good job to the crew.
Nothing broken, nobody hurt, nothing to see here.
telex
Post by telex »
altiplano wrote: Sun Feb 04, 2018 11:40 am Good job to the crew.
Stunning. You fully endorse doing something other than what the manufacturer's QRH says about a rejected takeoff?
Above 80 knots and prior to V1, the takeoff should be rejected for any of
the following:
• fire or fire warning
• engine failure
• if the airplane is unsafe or unable to fly.
How about... go flying, start the APU, continue the flight, and land without incident. Just a thought.
Mind you I'm just one of those dick heads that tries to follow a QRH to the letter.
av8ts
Post by av8ts »
Is that where the bar for a good job is now? Nobody died or got hurt
mbav8r
Post by mbav8r »
That’s a great threshold, for a good job!
Since nobody commenting so far was there, you have a piece of the picture. I don’t have anymore info than that but I can certainly imagine a scenario or two where you might reject for a gen failure. APU U/S, or maybe the other one had quit on the previous leg, so in a split second you need to decide if you want to risk a double Gen failure after T/O. Maybe the other one was already MEL’d, so would you fly all the way to YYZ on the APU Gen or circle around burning fuel to return and have one fixed, me personally I’m not flying five or so hours on one Gen unless I have to.
Not enough info and very easy to criticize when it’s not your ass strapped in, also I imagine it wasn’t just a balanced field, probably some excess runway unless of course the chose an intersection departure(see thread about that topic)
telex
Post by telex »
mbav8r wrote: Sun Feb 04, 2018 12:33 pm That’s a great threshold, for a good job!
What does the QRH say about rejecting for a generator failure? It's very simple.
I can tell you what it does not say. It does not say blah blah blah what if.
It says this:
the following:
• engine failure
Do you still advocate for disregarding manufacturer direction?
Your dramatic on the scene account is riveting but irrelevant.
It's called threat and error management. You goofballs are analyzing the result vs the incorrect action applied in a certain situation. Please tell me you understand this concept. Please.
ps. how much extra fuel are you packing that you need to burn off fuel for your landing? Wouldn't you be under max landing weight at departure for a five hour flight?
There are always more details that are unknown. I wonder if there was an accidental belief that a generator warning meant that an engine had failed. While I have never had an actual engine failure in a jet, I have noticed in the sim at least once(during a landing) that the first indication was a generator fail warning. Of course that was at low thrust and there was no yaw indication to help identify the situation.
mbav8r wrote: Sun Feb 04, 2018 12:33 pm Since nobody commenting so far was there, you have a piece of the picture. I don’t have anymore info than that but I can certainly imagine a scenario or two where you might reject for a gen failure. APU U/S, or maybe the other one had quit on the previous leg, so in a split second you need to decide if you want to risk a double Gen failure after T/O. Maybe the other one was already MEL’d, so would you fly all the way to YYZ on the APU Gen or circle around burning fuel to return and have one fixed, me personally I’m not flying five or so hours on one Gen unless I have to.
I personally would not do a high speed RTO for a second generator failing.
Haha! Telex, good one!
You're one to talk about understanding concepts!
While the AOM says that for the reasons you listed you should reject a takeoff, it does not say that it is limiting.
What does it say?
The Captain has the sole responsibility for the decision to reject the take-off.
We really don't know what that crew had out there.
Maybe they should have done it different?
Made a mistake on the failure recognition?
Felt a big vibration/surge/heard a clank when the IDG let go?
Had other restrictions?
Operating with MELd APUs isn't uncommon, particularly on NA flights because they don't like to send them overseas so will put them on that type of sector.
Were there other factors?
Is the report 100% accurate?
Whatever it is, they are experienced, 25+, even 30+ year veterans flying those machines and they made a difficult split second decision to a good outcome and that gets a good job from me with the information presented.
Zaibatsu
Post by Zaibatsu »
Nope.
Risk goes up exponentially after 80 knots on a reject.
A reject after 80 should only be for engine failure, fire, control issues, or structural problems.
Plane can fly with one generator. It can fly with no generators.
No harm no foul doesn’t cut it. We have SOPs and don’t fly by the seat of our pants for a reason... and fatalities and hull losses have plummeted because of it.
If the Captain wants to brief outside of SOPs, fine. But he’d better have a really good reason for it. There is no conceivable reason I can think of to reject for a generator failure above 80 without an associated engine failure or fire.
Schooner69A
Post by Schooner69A »
With just over 12000 feet of runway and a 0.3% uphill run, do any of the armchair airframe drivers know the accelerate/stop distance required?
Might give a little insight into the decision made...?
confusedalot
767 three quarters full and fuel for Toronto, meh.....7 or 8000 feet at min takeoff flap setting? It's been a long time since I've flown the plane and the books are long gone, so don't go too far with that.
telex
Post by telex »
altiplano wrote: Sun Feb 04, 2018 3:41 pm Haha! Telex, good one!
What does it say?
Wrong again.
This is why you reject above 80 knots:
the following:
• engine failure
If you choose to not accept manufacturer procedures as the way to operate an aircraft I have nothing further.
telex
Post by telex »
Schooner69A wrote: Sun Feb 04, 2018 4:50 pm With just over 12000 feet of runway and a 0.3% uphill run, do any of the armchair airframe drivers know the accelerate/stop distance required?
12000 feet of bare and dry pavement is sufficient for a 767 to complete an RTO. Works for 747 and 380 as well.
telex wrote: Sun Feb 04, 2018 10:29 pm
It also makes it sufficient to reject above V1 for many aircraft at lighter weights and be able to easily stop before the end of the runway. Maybe that is how it works at some companies.
telex
Post by telex »
pelmet wrote: Mon Feb 05, 2018 1:50 am
Now an advocate for rejecting after V1? Where do those performance numbers get generated?
You are wrong Telex.
Again. It's not limiting to only the reasons you post.
For those reasons Boeing simply says you should reject, but not only for... every situation can be different and it's the Captain's to make in a split-second.
The first line of the SOP says:
Not you, not even Boeing.
You might disagree, you might have done it different, but it's not your responsibility or decision, nor do you have any information beyond a 5 line report. It was this Captain's decision, he made it, and followed through with a successful maneuver to a successful outcome.
Schooner69A
The reason I posed the question involving runway remaining is because of an incident I had involving carburetor icing many years ago.
To counter the formation of ice in the carburetor, the recommended actions in the "Emergency Procedures" section was to "...apply full throttle and pull the carburetor heat knob full out until the engine runs smoothly; then remove carburetor heat and readjust the throttle..."
I have no doubt that following the recommended procedure would have solved my problem; however, I modified the procedure by selecting carb heat "ON" and reducing the power to idle.
Why?
Because the engine started to wind down about a hundred feet in the air on take-off... With four thousand feet of runway in front of me, the decision was obvious. It was obvious from thousands of hours of experience that given my altitude, my airspeed, and the available run remaining, a safe landing could be accomplished.
I have no experience on a Boeing 767; however, whatever the reason for the rejection, the captain knew that a safe outcome would be experienced if he stayed on the ground.
Now, if either of us had wound up off the end of the runway in among the sagebrush and the cacti, we'd have had our mussentouchits whacked. However, we didn't, and they weren't...
PS Observant folks will notice the sexist assumption I've made... (;>0)
GRK2
Post by GRK2 »
Yes, you can hilight the Captain's sole responsibility all you want. What if he/she was wrong? Not following SOP and/or manufacturers recommendations and bending tin by making up your own shit will cost a job. Every. Freakin'. Time. Why even go there? Simpler to follow the rules, do what you agreed to do when you signed the tech log that certified you agreed everything was correctly done, and retire when you want...and you know what? It's satisfying...seriously....The comments I see here about RTOs are chilling...
GRK2 wrote: Mon Feb 05, 2018 9:15 am Yes, you can hilight the Captain's sole responsibility all you want. What if he/she was wrong? Not following SOP and/or manufacturers recommendations and bending tin by making up your own shit will cost a job. Every. Freakin'. Time. Why even go there? Simpler to follow the rules, do what you agreed to do when you signed the tech log that certified you agreed everything was correctly done, and retire when you want...and you know what? It's satisfying...seriously....The comments I see here about RTOs are chilling...
Where does it say he didn't follow manufacturer's recommendations?
Based on the information posted/quoted in this topic:
The manufacturer says:
"if A happens, do B"
This does in no way mean that:
"if A doesn't happen, don't do B"
That's really basic logic. Maybe that's why operators prefer a degree :twisted: :?:
CpnCrunch
Post by CpnCrunch »
rudder wrote: Sun Feb 04, 2018 11:06 am Many EICAS caution messages are inhibited in the high speed take off regimen. Generator is not one of them so it is a judgement call.
Seems a little odd to not inhibit a caution that you're expected to ignore during that phase of the takeoff.
digits_ wrote: Mon Feb 05, 2018 9:42 am
Right on.
