Page 1 of 2
"Currently"
Posted: Sun Nov 17, 2019 8:54 am
by Old timer
I am trying to decide if I should be amused or annoyed. The amount of pilots who say "currently" in their transmissions is incredible.
Flying just south of Calgary the other night, almost every airplane I heard was adding this to their radio call.
I am a firm believer in saying what is neccessary but nothing more.
Thoughts?
Re: "Currently"
Posted: Mon Nov 18, 2019 11:19 am
by KissPlusOne
Just to clarify, you mean that to say, "x-traffic, xxx is CURRENTLY over the town of X at X feet, blah blah blah..." is wasting time on the radio when you could just say, "x-traffic, xxx is OVER the town of X at X feet, blah blah blah"?
It isn't as blatantly useless to say "currently" as it is to say, "any conflicting traffic, please advise." I would much rather eliminate that phrase first before fine tuning our radio speak.
I teach students to be as concise as possible, but IF you need to make a longer call, please do! In the end, it'll be better to take 30 seconds to clarify than 10 seconds to leave people confused, and pulling evasive maneuvers mid downwind because you called in the wrong location...
With that being said, some days when I'm in the circuit with a student, I just turn the radio down because of all the chatter. I train at an uncontrolled airport. We can use our eyes for a bit.
In short, we need to sharpen before we can hone (I think I got that order correct). Let's get rid of ACTPA, and then worry about little words and "umms". Ideally we would all speak with the confidence and brevity of a motivational speaker, but we have to work to that point as a whole. If one guy does it, it's not going to change anything. This industry as a whole needs to accept this challenge before any progress will be made in the way of clear, concise radio communication.
Re: "Currently"
Posted: Mon Nov 18, 2019 11:36 am
by Heliian
Yes, it's currently as opposed to where you will be going. No harm here.
Re: "Currently"
Posted: Mon Nov 18, 2019 11:59 am
by digits_
Heliian wrote: ↑Mon Nov 18, 2019 11:36 am
Do you also use currently to indicate the current altitude you are at versues the altitude where you will be at in an hour?
I haven't found a single situation that warrants the use of "currently" in any radio transmission. But please, prove me wrong, I'm curious!
Re: "Currently"
Posted: Mon Nov 18, 2019 2:17 pm
by photofly
More or less:
"Golf Foxtrot Echo Lima passing 3700 climbing 6000".
digits_ wrote: ↑Mon Nov 18, 2019 11:59 am
Per the CFS page C2:
London radio, Golf Foxtrot Echo Lima position report, YSO 090 023 at 45, 3500, VFR Kingston"
vs.
London radio, Golf Foxtrot Echo Lima position report, YSO 090 023 present time, 3500, VFR Kingston"
"currently", or "present time", or whatever, does have a meaning, even if it can often be left unsaid.
While we're finding micro-itches to scratch, could we ask people not to say "about" or "approximately" - as in, "Golf Foxtrot Echo is about three miles north of the town of Sumspot"? I think we can assume that you don't have a tape measure to the town hall.
Re: "Currently"
Posted: Mon Nov 18, 2019 2:59 pm
by digits_
photofly wrote: ↑Mon Nov 18, 2019 2:17 pm
More or less:
vs.
None of your examples are using "currently". Although I must admit I would be questioning the use of "present time" as well. Nice to know it is in the cfs, but when would it realistically need to be used?
Agreed on the "about" and "approximately"
Re: "Currently"
Posted: Mon Nov 18, 2019 3:43 pm
by Aviatard
Approximately 4.2 nautical miles...
Lining up for immediate takeoff...
Re: "Currently"
Posted: Mon Nov 18, 2019 4:08 pm
by photofly
digits_ wrote: ↑Mon Nov 18, 2019 2:59 pm...
"Present time" as a form of words isn't in the CFS; an element of a position report is "time over" - so you're going to have to find a form of words if the time over is "now". You could equally well say "currently". Or "now". Or maybe you should always use the time, and never say "now" or "currently" or "present time". But that seems a bit silly.
But since most people make position reports based on where they are "now", and the appropriate standard for a position report requires time over fix as part of the report, it's not inappropriate to say "now", or "currently", or "present time".
I wonder what CAP413 says ... let me look.
Re: "Currently"
Posted: Mon Nov 18, 2019 4:18 pm
by digits_
photofly wrote: ↑Mon Nov 18, 2019 4:08 pm
"Present time" as a form of words isn't in the CFS; an element of a position report is "time over" - so you're going to have to find a form of words if the time over is "now". You could equally well say "currently". Or maybe you should always use the time, and never say "now" or "currently" or "present time". But that seems a bit silly.
When would you ever make a position report for a time other than the current time? If you have been out of radar range on some oceanic crossing or remote arctic oceanic flight and you had trouble reaching someone, ok, I can see that you might need to report your last known location.
But for "normal" VFR position reports?
Here is the navcanada booklet regarding VFR phraseology.
https://www.navcanada.ca/EN/media/Publi ... eology.pdf
Page 34 deals with position reports. No time is mentioned, "currently" or equivalents aren't used either.
Re: "Currently"
Posted: Mon Nov 18, 2019 4:27 pm
by photofly
Time is required as part of a VFR position report in CAP413, the AIM and the CFS, all of which are more formally correct than the Navcanada booklet... you choose.
I’ve given (by necessity) many many position reports ”late”, both VFR and IFR.
I don’t say “currently”, or “present time” on CFA frequencies, but I can see why you might want to.
Re: "Currently"
Posted: Mon Nov 18, 2019 5:11 pm
by photofly
Can we compromise on “at this time”?
Re: "Currently"
Posted: Mon Nov 18, 2019 6:54 pm
by CL-Skadoo!
I think one should say “literally” instead
Re: "Currently"
Posted: Mon Nov 18, 2019 9:59 pm
by Big Pistons Forever
Personally I would just like to see pilots take a 3 second pause on the frequency change over instead of just changing the freq and immediately start talking. On my last 36 minute flight 3 transmissions were blocked when somebody started talking even though there was already a transmission occurring on the frequency.
In any case there is an easy rule for good radio comms. "engage you brain before your thumb"
Re: "Currently"
Posted: Mon Nov 18, 2019 10:06 pm
I have to admit that got me thinking. How about when ATC asks you for something you are already doing ?
eg ATC " reduce to min approach speed"
ABC " ABC currently at min approach speed"
Re: "Currently"
Posted: Tue Nov 19, 2019 7:50 am
by ahramin
Ooooo. Good one BPF.
Re: "Currently"
Posted: Tue Nov 19, 2019 9:29 am
by digits_
Big Pistons Forever wrote: ↑Mon Nov 18, 2019 10:06 pm
Okay, I personally wouldn't use currently in that case, but I admit it is the most appropriate example soo far
It is also the only (?) example where "Unable" and "Wilco" are both correct statements and will have the same outcome
Re: "Currently"
Posted: Tue Nov 19, 2019 11:10 am
by youhavecontrol
I'm starting to get annoyed by "aaaannnnddd.... Buttsville traffic..." while talking as if they're trying as hard as possible to sound cool.
Re: "Currently"
Posted: Tue Nov 19, 2019 11:41 am
by digits_
".... CXABC with you .... "
WE KNOW
Re: "Currently"
Posted: Tue Nov 19, 2019 4:40 pm
by Heliian
Ooh, what about "showing"?
As long as it's understandable, an extra word isn't going to hurt you. Still better than having to listen to everyone's flight plans.
Re: "Currently"
Posted: Tue Nov 19, 2019 4:50 pm
by photofly
So can we reach a consensus on the following:
"Uhhh... aaaaand.... C-GABC with you, now currently showing about approximately 3.43 miles east of Sumspot at this time, conflicting traffic please advise..."
Re: "Currently"
Posted: Tue Nov 19, 2019 6:31 pm
photofly wrote: ↑Tue Nov 19, 2019 4:50 pm
I am disappointed in my fellow instructors here
Let me help you with some corrections
"Uhhh... aaaaand.... Piper PA 28 Warrior Two C-GABC with you, now currently showing about approximately 3.43 miles east of Sumspot at this time, Ummmm Errr descending towards the airport and following Goats Run Lane, aaaaaaand conflicting traffic please advise, over ..."
Re: "Currently"
Posted: Tue Nov 19, 2019 9:04 pm
by photofly
Touche.
Re: "Currently"
Posted: Wed Nov 20, 2019 12:05 am
by 5x5
While we’re at it, one more little correction...
"Uhhh...advisory traffic on 126.7.... aaaaand.... Piper PA 28 Warrior Two C-GABC with you, now currently showing about approximately 3.43 miles east of Sumspot at this time, Ummmm Errr descending towards the airport and following Goats Run Lane, aaaaaaand conflicting traffic please advise, over ..."
Re: "Currently"
Posted: Wed Nov 20, 2019 9:16 am
by TG
5x5 wrote: ↑Wed Nov 20, 2019 12:05 am
Don't forget to repeat the all thing in French
Re: "Currently"
Posted: Wed Nov 20, 2019 1:07 pm
by iflyforpie
Let’s not forget the ten minute back and forth for a “resolution advisory” between two or more planes occupying the same 200 cubic miles of airspace. Always laterally and looking and continuing to call.. rather than vertically and forgetting.
