Pilot leaves towbar on runway??
https://www.bbc.com/news/uk-england-essex-51237265
Now, did he leave it on the ramp, in which case shoot the journalist, or did he taxi out and take off with the towbar dragging in front of the airplane?
Are those grind marks from dragging on tarmac, in the photo??
Re: Pilot leaves towbar on runway??
Pretty sure that happened to the cutlass at MRC years back. Minor damage only.
Definitely left it on until takeoff. My bet is that it fell off after rotation/liftoff since anything sooner would have been a pretty good bump to him and hopefully gotten his attention. The damage to that towbar wasn't caused by someone dragging it while walking around.
Moral of the story: If you don't have clear, positive memory of performing a task, assume you didn't. I had one day where I couldn't remember if I'd put the caps back on after fueling the 172. Fueled, pushed back, got in the plane, briefed passengers, just about to start up but couldn't get the itch out of my brain that something wasn't right so I got out to check. Sure enough, one cap left off.
This can all be easily prevented. The last thing you do before getting in the aircraft is your final check. I have my own one that covers the variety of general aviation aircraft that I fly....Chris M wrote: ↑Mon Jan 27, 2020 6:44 am Definitely left it on until takeoff. My bet is that it fell off after rotation/liftoff since anything sooner would have been a pretty good bump to him and hopefully gotten his attention. The damage to that towbar wasn't caused by someone dragging it while walking around.
I start at the front of the aircraft and say either to myself or out loud as I walk around the aircraft, no towbar, no intake plugs, no chocks, no tiedowns, oil cap secure, fuel caps secure, no pitot cover, no external locks, baggage door secure.
Takes about 30 seconds and ensures that none of these items are missed and that you don't have to undo your seat belt and go back outside to check if it suddenly dawns on you that you are not 100% sure about these items. A simple thing that I bet that virtually no school or instructor teaches their student learning to fly.
Why do I do it? Because I am the kind of guy that would eventually have one of these items happen to me....or maybe I already have.
Intake plugs, chocks, pitot cover, tie-downs, oil and fuel-caps secure... that sounds a lot like a walk-around inspection to me.A simple thing that I bet that virtually no school or instructor teaches their student learning to fly.
Do you include other things from the walk-around? "I don't remember checking the alternator belt tension... or the stall warning horn... " If you missed the loose fuel cap on your walkaround, what's to say that you'll spot it on your final check? Maybe you should check the plane a third time, or a fourth time.
Do you have a final final check, that your final check was done? Where does it all end?
This pilot (allegedly) forgot to stow his tow-bar because he was unnerved by an earlier near collision with a cyclist while driving to the airport. Perhaps that would have made him forget his "final" check too.
You are doing the Transport Canada thing. Seizing a mistake by a pilot, blaming flight schools and instructors, and saying a simple fix is to implement (yet) another checklist.This can all be easily prevented..... A simple thing that I bet that virtually no school or instructor teaches their student learning to fly.
The problem is, if you do this every flight, at one point it will become some automatic reflix, and you might still miss thing. The longer the list of items you check, the higher the chance you will miss something. Especially if it is the second time you check it, it gives the impression the first time is not important.pelmet wrote: ↑Mon Jan 27, 2020 8:51 amThis can all be easily prevented. The last thing you do before getting in the aircraft is your final check. I have my own one that covers the variety of general aviation aircraft that I fly....Chris M wrote: ↑Mon Jan 27, 2020 6:44 am Definitely left it on until takeoff. My bet is that it fell off after rotation/liftoff since anything sooner would have been a pretty good bump to him and hopefully gotten his attention. The damage to that towbar wasn't caused by someone dragging it while walking around.
If you really want to check stuff right before departure, stick to the real killer items.
no towbar: important
no intake plugs: probably important for most types
no chocks: what is the worst that could happen? you taxi over them or you get out and remove them
no tiedowns: worst that could happen? you won't move or rip one off. won't kill you
oil cap secure: important, but you usually have to open a cowling or hatch to access this. The danger here is not doing the job properly, not forgetting to do the job. So if the hatch is closed, no point in checking it again.
fuel caps secure: if you can't see them from the cockpit, that could be important
no pitot cover: if done properly, this won't kill you, as you will notice there is no airspeed indication during take off
no external locks: if you follow the other checklists properly, you will notice this during the flight control check
baggage door secure: usually not critical
Some items are to prevent embarrassing/inconvenient events and others are items that have led to many fatal accidents(including baggage doors on some aircraft by the way).digits_ wrote: ↑Mon Jan 27, 2020 10:17 amThe problem is, if you do this every flight, at one point it will become some automatic reflix, and you might still miss thing. The longer the list of items you check, the higher the chance you will miss something. Especially if it is the second time you check it, it gives the impression the first time is not important.pelmet wrote: ↑Mon Jan 27, 2020 8:51 amThis can all be easily prevented. The last thing you do before getting in the aircraft is your final check. I have my own one that covers the variety of general aviation aircraft that I fly....Chris M wrote: ↑Mon Jan 27, 2020 6:44 am Definitely left it on until takeoff. My bet is that it fell off after rotation/liftoff since anything sooner would have been a pretty good bump to him and hopefully gotten his attention. The damage to that towbar wasn't caused by someone dragging it while walking around.
Feel free to take my advice ……..or not. Based on your response, I think I know which is your choice. That is up to you and perhaps you are not as likely as me to forget one of these items on rare occasion.
Uh huh.
So... it's all the instructor's fault, we can fix this with another check list, and now the last of the holy trinity of AvCanada memes, if you don't take my perfect advice and do as I say, you're an idiot!
Many of these items(it is not a checklist by the way) can be put in place after the walkaround. Discover you need some oil or fuel which is done after the walkaround. Chocks put in place after the aircraft is moved with a towbar(perhaps out of the hangar where you did your walkaround). Intake plugs left in until the last minute to keep the engine warm. Baggage door used after the walkaround and then it wasn't closed. Nothing about the alternator belt or the stall warning is going to change since the walkaround, so they are not checked again.photofly wrote: ↑Mon Jan 27, 2020 9:18 amIntake plugs, chocks, pitot cover, tie-downs, oil and fuel-caps secure... that sounds a lot like a walk-around inspection to me.A simple thing that I bet that virtually no school or instructor teaches their student learning to fly.
By the way, while doing this final check which frequently happens after having left the aircraft subsequent to completing the walkaround(such as to file a flight plan, get a weather update, take a leak, pay the fuel bill, meeting the pax, etc, etc...….it give you a change to take a quick glance during that 30 seconds to discover that another aircraft or vehicle clipped your wing or tail.
Such common sense.
Just a suggestion from someone who has done a few of these things in the past, but not since I started doing my final check several years back. Anyways, I will keep an eye out for more Cadors reports to see if perhaps, I am just being paranoid...a little bit of which is a good thing.
By the way, I do it for killer items after the pre-takeoff checklist is complete as well. My own technique. Obviously excessive for some. The only problem is...there are a lot of dead people out there who would not be if their pilots had done a final killer item check....
https://en.wikipedia.org/wiki/Northwest ... Flight_255
….and that is just one of many examples of guys who didn't check their killer items. After all, the checklist will cover it all.
I'm sure the pilot in question has a lot of common sense - but if it was common sense, why do you have to invent a new checklist to cover it?
I'm surprised that nobody has commented on the real point of this story, which is that he was rattled from his earlier incident with the cyclist and it affected his performance. He probably shouldn't have gone flying at all. That's the learning point here - distraction and fitness to fly - not final checks.
You are sure that he has a lot of common sense but figure that after his incident on the way to the airport, he shouldn't have gone flying but decided to do so anyways. OK.photofly wrote: ↑Mon Jan 27, 2020 12:02 pmI'm sure the pilot in question has a lot of common sense.
I'm surprised that nobody has commented on the real point of this story, which is that he was rattled from his earlier incident with the cyclist and it affected his performance. He probably shouldn't have gone flying at all. That's the learning point here, nothing about final checks.
The final check(for GA aircraft) might save the day for a rattled pilot(or sick pilot, fatigued pilot, or distracted pilot - as the report says) who for whatever reason decides to fly anyways. As they say....Stuff Happens.
The cause of that accident was:pelmet wrote: ↑Mon Jan 27, 2020 11:52 am
If he followed the existing checklists, everything would be fine.The National Transportation Safety Board determines that the probable cause of the accident was the flightcrew's failure to use the taxi checklist to ensure that the flaps and slats were extended for takeoff. Contributing to the accident was the absence of electrical power to the airplane takeoff warning system which thus did not warn the flightcrew that the airplane was not configured properly for takeoff. The reason for the absence of electrical power could not be determined.
One more checklist wouldn't help. The more items and checklists you use, the less attention people will pay to them.
I've flown airplanes where the controls needed to be checked 3 times between engine start and line up. 3 times, because it's super important and we must be safe right? Nope! Students made 3 half assed attempts at a control check instead of treating the control check with the respect it deserved.
1) "we'll check it again 2 more times, so it isn't that important"
2) "we already checked it and we will do it once more, so it isn't that important"
3) "we already checked it twice, I'm sure it will be fine now"
Whereas if you check it once, you better do it right, because it is your only chance.
Guys like the pilots on that airliner probably think along your line of thinking. If you follow the checklist, everything will be fine. Just follow the checklist. But on occasion, an item gets missed. How do I know that? Because I have missed an item on a checklist....and more than once. Then there are situations like contaminated runway ops, where the checklist is done but the flaps are left up until holding short of the runway. Then the flaps are extended. Until someone forgets. Of course, the warning system should alert the crew...until it doesn't. And even if it does warn the crew, it might end up with a warning/demotion/firing at some airlines or an embarrassing explanation to the higher-ups.digits_ wrote: ↑Mon Jan 27, 2020 1:44 pmThe cause of that accident was:pelmet wrote: ↑Mon Jan 27, 2020 11:52 am
From an airliner point of view...….If only they had done similar to what I recommend close to lining up such as....speedbrakes stowed, flaps set, stab trim set, rudder trim set, v-speeds visible, LNAV and VNAV armed(or whatever is appropriate for your aircraft)(some are not killer items but can create an issue). A lot of people would be alive. It takes a little over 5 seconds and is not a checklist. Some would rather engage in non-pertinent discussion during the 10 minute wait for takeoff or enjoy watching the airliners land, etc. Usually, that is still possible.
Here is another bunch of deaths from a crew that never felt that a final check of certain items before takeoff could save the day....
https://en.wikipedia.org/wiki/Delta_Air ... light_1141
If only....
It’s a list of things to check. How is it not a checklist?
If only they had done similar to what I recommend close to lining up such as....speedbrakes stowed, flaps set, stab trim set, rudder trim set, v-speeds visible, LNAV and VNAV armed.... and is not a checklist.
Actually, I recommend checking the elevator again just prior to the takeoff roll in addition to the checklist. It could become jammed subsequent to the control check. Just a bit of an up/down movement to ensure that it is free. I did start doing that a while back but have been lazy about it.digits_ wrote: ↑Mon Jan 27, 2020 1:44 pm I've flown airplanes where the controls needed to be checked 3 times between engine start and line up. 3 times, because it's super important and we must be safe right? Nope! Students made 3 half assed attempts at a control check instead of treating the control check with the respect it deserved.
Good idea don't you think.
Call it a mental one. One the C172 I flew the other day, after lining up, I checked the fuel tank selector, fuel on/off selector, trim set, mixture set, mags on both, boost pump off, flaps set. If it were an older 172...also primer locked.photofly wrote: ↑Mon Jan 27, 2020 3:45 pmIt’s a list of things to check. How is it not a checklist?
I recommend everyone similar. Took about ten seconds.
So what’s wrong with the manufacturers checklists, that you have to invent your own?
Last thing we want is pilots making up their own procedures.
There is nothing wrong(in general) with manufacturer's checklists. What is wrong is with pilots brains which is why we have so many accidents from guys that did the checklist. Look at the link to the Delta 727 crash. The checklist was completed yet the flaps were up(meaning that one should not just respond "fifteen. fifteen, green" on the assumption that the flaps were extended earlier in the taxi out). But that is what happened. If one of the pilots had checked his killer items after the completion for this checklist, those dead pax would be alive. Seems a reasonable trade-off for 'Making up procedures".
Well then the checklist wasn’t completed, was it? Maybe the pilots thought it was ok because their own made-up checklists they’d decided to do later, were better, so didn’t pay any attention.
Layer upon layer of checklists, that’s the answer to every problem.
- rookiepilot
The checklist was not completed. End of story.
Do you read the links you post? Just curious.
"Based on the aircraft's failure to climb at takeoff speed, its roll instability, and the absence of sounds indicating the flaps or slats were deployed, the NTSB determined that the plane's failure to climb resulted from the flight crew's failure to deploy the flaps and slats as required by the pre-flight checklist."
I'm not getting this thread. If the crew HAD completed the checklist -- flaps would be done.
If you are missing an item, you are not following the checklist. Running a checklist takes some practice and training. It's not just reading from a list and mindlessly regurgitating replies.
You read the item, you flip the switch if required and you verify the switch is in the correct position. Then you continue. It's not a race to go through everything like crazy without checking. If you feel like you need your own checklist to "really check", you are probably rushing the actual checklist in the airplane. If the checklist in the airplane is insufficient, change it.
Different checklist for deicing conditions exist. If you follow a checklist, you will not "forget" an item.pelmet wrote: ↑Mon Jan 27, 2020 3:42 pm How do I know that? Because I have missed an item on a checklist....and more than once. Then there are situations like contaminated runway ops, where the checklist is done but the flaps are left up until holding short of the runway. Then the flaps are extended. Until someone forgets.
In a multicrew environment that is dangerous advice. If one crewmember suddenly starts to run his own checklist when you are expecting to start the take off roll or when you are lining up the lane. That creates confusion in a multi crew cockpit.pelmet wrote: ↑Mon Jan 27, 2020 3:42 pm From an airliner point of view...….If only they had done similar to what I recommend close to lining up such as....speedbrakes stowed, flaps set, stab trim set, rudder trim set, v-speeds visible, LNAV and VNAV armed(or whatever is appropriate for your aircraft)(some are not killer items but can create an issue). A lot of people would be alive. It takes a little over 5 seconds and is not a checklist. Some would rather engage in non-pertinent discussion during the 10 minute wait for takeoff or enjoy watching the airliners land, etc. Usually, that is still possible.
Even single pilot, this only makes sense if you don't trust the checklist. In that case the remedy is "change the checklist" not "invent your own"
That final check is called "line up checklist" or "before take off checklist". Follow it.pelmet wrote: ↑Mon Jan 27, 2020 3:42 pm Here is another bunch of deaths from a crew that never felt that a final check of certain items before takeoff could save the day....
If only....
I have the impression that the root of your argument boils down to: "people make mistakes when running a checklist, so run the checklist twice to catch the mistakes".
Let's put some random numbers on it to make a point. Let's say a pilot misses 1% of the items when running a checklist. If you run the checklist twice, the chance of forgetting that item is 0.01% according to that philosophy.
However, what will really happen is that people will not pay attention to the checklist anymore if they have to run it twice. So you might get 10% of missed items on the first run, and maybe 20% of items on the second run. That gives you a 2% chance of a mistake versus running the checklist just once accurately.
The final killer item check is the answer to your first sentence. Obviously you don't plan to do it and that's fine. There are a lot of pilots and pax who really wish it had been done. Others can decide for themselves if they feel the 10 to 30 extra seconds is worth it.photofly wrote: ↑Mon Jan 27, 2020 4:45 pmWell then the checklist wasn’t completed, was it? Maybe the pilots thought it was ok because their own made-up checklists they’d decided to do later, were better, so didn’t pay any attention.
At the airlines you can't. That's the whole point of SOPs in a multicrew environment: to follow the company determined standard way of doing things. Not doing your own checks because you feel like it.
If the SOPs are unsafe, SMS it. If not, follow them, even -especially- if you disagree with them!
rookiepilot wrote: ↑Mon Jan 27, 2020 4:50 pmThe checklist was not completed. End of story.
From the CVR....
"0859:08 CAM-3 before takeoff checklists complete"
OK...in the end, my safety check works wonders for those who are under the impression that their pre-takeoff checklist is complete when in fact it is not for whatever reason.
Would have saved these guys as well...
https://reports.aviation-safety.net/200 ... EC-HFP.pdf
