Sunglasses
CClub
Sunglasses
Post by CClub »
Fellow pilots:
What kind of sunglasses do you where? I need a good pair that will comfortably fit underneath a headset without too much noise leakage.
Panama Jack
Post by Panama Jack »
I swear my by aviator style Serengetti Drivers. Cuts glare great, plus, in this day and age, it helps to see the world through rose tinted lenses.
-President Ronald Reagan
CF-RYE
Post by CF-RYE »
All I know is the cost of them seems to be directly proportional to the odds of loosing or smashing them. Had a pair of Oakley polarized lost them off the float in less than a month. Been wearing the same $10 pair for the last 2 years!
Although, I hear from optometrists it’s not a good idea for pilots to skimp on glasses. So if ya can afford it get a good pair.
CClub
Post by CClub »
How well do those Serengetti's fit underneath a headset? I don't have the best of the best of headsets but I like it as quiet as I can get.
Sparky
Post by Sparky »
Is it true you're not supposed to wear polarized sunglasses when flying?
shitdisturber
Post by shitdisturber »
Sparky wrote:Is it true you're not supposed to wear polarized sunglasses when flying?
Nah, it's a big concern if you're doing a lot of driving in and out of tunnels; leaving aside the whole "returning to the womb" thing. Polarizing sunglasses can't adapt to the darkness, or the light, fast enough.
Panama Jack
My Serengettis have pretty thin, uh, thingies (what do you call those things that connect the glasses to your ears??) with the wrap around the ears feature, so when I get held upside down by my ankels by people demanding money they won't fall off.
Honestly, I find they are OK for compatability with headsets but all glasses will reduce somewhat the noise reduction provided by a headset. Headsets are a separate issue for me-- I have always been an ANR guy. Even then, I have found that some airplane types are still too noisy-- I used to fly one with an ANR headset AND used earplugs underneath. Flying without ANR, earplugs are manditory for me-- don't be fooled that the claim of noise reduction means you won't experience some amount of hearing loss.
Louis
Post by Louis »
I also have Serengeti drivers, and they fit pretty well. You can also put prescription lenses in them if you need to.
Sd: Aren't polarized glasses also a problem with glass cockpit displays? As in showing some colours differently, or not showing them at all?
oldtimer
Post by oldtimer »
Watch for the polarized thing. Many will block out vision through a heated windshield. Kingairs are bad for this. Just look into the rear window of most new cars, if there are balck or dark spots, they may not work well in some airplanes.
Post by ahramin »
I have never found a better pair of sunglasses than Serengetis. They have lasted me longer than any other pair too! Though i did lose them for a couple days and then found them in the seat of the pawnee, minus the arms. Had to go all over town but i found new arms for $20.
corn-shoot
Post by corn-shoot »
Picked these up at Smokin Joe's in Pickle Lake. They are the best set I've ever owned.
Northern Flyer
Post by Northern Flyer »
CF-RYE so you wear polerized sunglasses, thats why you spank it on all the time. :D
Its very true that polerized glasses suck in a King Air, also flying floats I found that it was harder to judge the waters surface with them on. They are designed for fisherman to see into the water and take the glare off the surface.
I don't know what sunglasses are the best, but wear something, the sun is almost always shining into my office window, and it will screw your vision.
Yoyoma
Post by Yoyoma »
Damn Corn-shoot, and I thought I was the only guy who owned these!!
Image In the business world, the rearview mirror is always clearer than the windshield...W. Buffett
rotorfloat
Post by rotorfloat »
From the aviation safety newsletter 3/03, FWIW.
A pilot who can’t see is an accident waiting to happen. Without good glare protection, flying on bright, sunny days can be tiring and hazardous — and it can effect night flying too. Exposure to bright sunlight for a whole day without protection interferes with proper night adaptation for 12 to 24 hours! The following brief summary will focus on how to choose your sunglasses and the advantages and disadvantages of the various types.
There are three problems caused by bright sunlight: glare, infra-red (IR) radiation and ultraviolet (UV) radiation. Glare, although the most obvious nuisance — causing tearing, distraction and fatigue — is responsible for less serious problems than IR or UV radiation. Cutting down glare by using very dark sunglasses, however, can cause problems because reducing transmitted light reduces visual acuity, as anyone who has driven from a bright road into a dark tunnel whilst wearing sunglasses can verify. Even moderately dark sunglasses can, on a bright day, cut your vision down from 20/20 to 20/40.
On the ground, UV is partially filtered by the earth’s atmosphere, but the higher you go, the less the protection. UV light is not filtered equally by all types of sunglasses and can damage the eye, causing early cataracts (lens opacities). Cheap sunglasses should be avoided as they may only cut down glare. Good sunglasses reduce light transmission to 12-20 percent, but should cut down UV transmission by at least 90 percent. Looking directly into the sun should be avoided as IR can quickly injure the sensitive retina at the back of the eye. Prolonged and unprotected exposure in bright sunlight, particularly if combined with a wide snow cover, can seriously degrade vision. As you can imagine, mountain climbers are quite familiar with the need for top-quality eye protection.
Sunglasses may be constant-gradient, photochromic or polarized. Polarized lenses are great for fishing, but bad for flying. Due to manufacturing stresses, there may be small areas of polarization in an aircraft canopy or windscreen and, if the angles of polarization in the glasses and the windscreen differ, a blind spot can be produced. Polarization may also interfere with depth and distance perception, particularly during a bank. Just what you need turning on final!
Photochromic lenses that darken with increasing UV light are good for driving, but polycarbonate aircraft canopies shield out much of the ultraviolet rays and may interfere with their proper darkening. Additionally, going from bright sunlight into cloud the glasses may take several minutes to lighten. Constant-gradient glasses come in various colours and are the most commonly used. All are about equally effective for glare, but green or grey lenses have the least adverse effect on your vision. Yellow lenses are good in haze, but less effective in bright sunshine. Sports orange lenses should not be chosen because they interfere with blue-green discrimination and may make red warning lights more difficult to see. Pilots with colour deficiencies should not use coloured lenses and should stick to a quality grey lense.
What is best? Where vision is concerned, do not gamble your eyes by using cheap sunglasses; also keep in mind that price is not always a good gage of quality, as some trendy polarized models costing well over $150 are not what you need at all. You should budget anywhere between $75 and $150 for good aviation sunglasses. Constant-gradient lenses that reduce light transmission to 15-20 percent and block 90 percent of UV light are ideal. Neutral grey, green or brown lenses are the most popular. Blue, orange or polarizing lenses should not be worn while flying. If in doubt, ask your Civil Aviation Medical Examiner for advice. In the long run, it is wiser to save your eyes than to save your money!
This article was originally published in ASL 3/1994, and has been slightly updated by our Civil Aviation Medicine Branch. — Ed.
CClub
Post by CClub »
Thanks for that rotorfloat. That has some good information in it. I had a good pair of Oakleys years back that had a green tint and I loved it.
CF-RYE
Post by CF-RYE »
So it’s the polarized lenses eh…. and here all these years I though me “spankin it on” was solely due to my incompetence. :oops:
I've got prescription Ray-Ban Aviatiors, so I can look like Tom Cruise. 8)
They should be coming back in style soon. I saw a rap dude on an Outkast video with 'em.
-istp
Snow Monkey
Post by Snow Monkey »
Serengetti's are great, just recently went to the Ray Ban drivers glasses and personally found them to be even better thinner arms less noise leakage.
Always Moving
AMBER
Post by Always Moving »
I use to have some okeleys and they work great and since they had the sides and nose made out of rubber, I would wearing them ontop of the earpice betwen the earpice and the metal of the headset, it might look a little funny but they did not give me a headache or have any air leakage since they where not on in the earpice, they were "gliding" in my head
Lanky Pilot
Post by Lanky Pilot »
I have a pair of "steel swingers" made by Arnette. The arms on them are extremely flat and seem to fit quite well under my headset. They cost around $80 or so.
wallypilot
Post by wallypilot »
serengettis all the way. have had 2 pairs....the first pair was stepped on after a couple years of service. second pair has been with me now for about 3 years, and they are still the best i have tried. you can find them with nice thin arms, too, so that they minimize the effect to the headset seal.
cheers
wp
Louis
Post by Louis »
Has anyone here ever had Randolphs? Do they do a good job?
epsyb
Post by epsyb »
I personnally have 3 pair of sunglasses and they all do a great job, depends on wath you prefer.
Oakley minute
Adidas
Ray ban New aviator.
Of course if you cant afford these, there's plenty of cheaper sunglasses that'll do the job, it's up to you. At one point, when you found the tint that you like and that permits you to do your job well, it's all a question of style!! 8)
Blue Side Down
Post by Blue Side Down »
I wear Randolphs because, after all, it's not about how they feel- it's about how you look -and if Randolphs don't say 'pilot', then I don't know what does.[/img]
penguin
Post by penguin »
-istp
You're an ididot. :mrgreen: [/quote]
