Have you ever heard of propeller failures caused by stress rising nicks ?
Yes, two. One having been experienced by a participant of AvCanada - 'his story to tell, not mine. The other, a floatplane friend who lost a few inches of tip on his 180 prop. The engine mount was damaged by the resulting vibration, but he made it home - sort of safely....
I advocate prevention, rather than the hope of repair for propellers. Yes, nicks can be dressed out, and tips reshaped, but to the manufacturer's limit, which may not be as much as one hopes for. In my junior years, I near scrapped a 182 prop by picking up some gravel at Maple airport. Leavens saved the blades, but that was it for them, no more tolerance for future damage.
Later I bought my 150. I got the McCauley manual, and made the measurements of the blades, there was not a lot left for future repair. The blades were okay, just not lots left if I was hard on them. So I was determined to be really careful with the prop. 34 years and 3000 hours later, I've had to dress out one small nick, and otherwise sand smooth the leading edge during annual inspections. The prop still meets the McCauley measurements with reserve. There are a few worthy tricks to prevent prop blade damage, they're worth knowing.
I'm intolerant of pilots who taxi light nosewheel planes around with the elevator limp, hold the nose high with up elevator. Nosewheel Cessnas respond well to being taxied with 15 flap extended, the changed airflow over the tail, combined with the up elevator, lifts the prop noticeably off the surface. And really watch out where you do runups, of course, with the elevator held nose up. No full power the brakes off for takeoff, add power on the roll, holding the nose up.
'Think I'm anal about this? Yup! I am responsible for my props, and those of other people's planes (a few with brand new props) which I fly from time to time. Since the 182 in the early days, I have not damaged a prop since....
If you think that you might be rough on prop blades, and it's worth the cost of the wear and tear, buy an MT prop, the blades can be repaired by replacement of damaged core, and leading edges.
