Frequency Wild
Frequency Wild
Can someone please explain what this is, how it works, and what it does for the aircraft electrical system?
thanks
thanks
A.C. Wild Electrical Power
I googled a thread on "A.C. Wild" for ya. Tux...
http://www.airliners.net/discussions/te ... n?id=68366
AC wild
It is a slang term used for AC variable frequency output of an AC generator. Called Wild AC. The speed of the AC generator will determine the frequency it produces.
Some systems use this "wild AC" before it is regulalated by inverters, generator control units (GCU's,) or rectified to DC.
Systems that use this current will not be subjective to variable frequency example - prop heat, maybe pitot heat.
Is this what you are refering to?
PITA
PITA
