Venr
on the 1900 UA-UC models Venr (also known as One-Engine Inoperative EnRoute climb speed) can be found in the Emergency procedures section under emergency airspeeds. (125 KIAS)
Used to meet minimum climb gradients with flap retraction beginning in the 3rd segment and into the final segment to 1500 AGL.
There are actually 3 models. The 1900, the 1900C and the 1900D.
http://www.tc.gc.ca/aviation/applicatio ... num=050021
Looking4Higher
Venr is "One Engine Inoperative Enroute Climb Speed" which is required to be calculated for each departure. And as previously posted it is for the 3 and 4 segment of the take of climb to ensure obstacle clearance in the event of an engine failure during takeoff.
Now as for what specific speed Venr is, Venr varies with weight. The greater the weight the higher the Venr speed will be much like a Va speed. The 1900D at MCTOW of 17120lbs. will have a Venr of 123kts. If you really want to know the 1900C Venr let me know I can get that for you as well.
Still Looking
Still Looking
- Cat Driver
ScudRunner
- Cat Driver
- Cat Driver
