Best cub sim
rigpiggy
Best cub sim
Post by rigpiggy »
Got a buddy who's wife have him lessons on a supercub. He wants to practice on a SIM first what is best simulator program with a piper cub model?
citabriaguy
Re: Best cub sim
Post by citabriaguy »
Would it be possible to set him up with a tricycle that he can push around a big room from the opposite end?
lownslow
Re: Best cub sim
Post by lownslow »
Don’t do it! At that stage a sim is largely negative training.
Re: Best cub sim
The best sim for Piper Cub training will be one of these:
To be used while holding one of these:
Note, yellow is the preferred colour.
TrilliumFlt
Re: Best cub sim
Post by TrilliumFlt »
Head out to the local Walmart; grab a shopping cart and then run as fast as he can across the parking lot pushing it backwards. For "advanced" training he could hang something heavy on the handle to simulate the weight of the engine and then try it again.
Re: Best cub sim
TrilliumFlt wrote: Fri Jan 13, 2023 7:37 am Head out to the local Walmart; grab a shopping cart and then run as fast as he can across the parking lot pushing it backwards. For "advanced" training he could hang something heavy on the handle to simulate the weight of the engine and then try it again.
For extra realism, put about $200k of fresh eggs in the cart, too.
TrilliumFlt
Re: Best cub sim
photofly wrote: Fri Jan 13, 2023 7:39 am
Perfect, should be able to score a PPC with that kind of quality training completed. :wink:
rigpiggy
Re: Best cub sim
Post by rigpiggy »
lownslow wrote: Thu Jan 12, 2023 10:29 pm Don’t do it! At that stage a sim is largely negative training.
Don't know about that. The kid for 11th birthday was given choice day of skiing or can flight.....Went to the school, rode along"just want photos of kid". About 20 minutes in with the kid basically holding private pilot tolerance, instructor looks back at me "flight simer? Me "Yep". I hate flight simmers, can't teach them anything.
TrilliumFlt
Re: Best cub sim
PilotDAR wrote: Fri Jan 13, 2023 6:50 am The best sim for Piper Cub training will be one of these:
You could add a IMC conditions to this model and get some instrument time logged as well. :wink:
FL030
Re: Best cub sim
Post by FL030 »
rigpiggy wrote: Thu Jan 12, 2023 8:08 pm Got a buddy who's wife have him lessons on a supercub. He wants to practice on a SIM first what is best simulator program with a piper cub model?
I would make a paper trainer. Print out the cockpit and stick it on the wall and practice using the checklist that they use. I bet those schools make bank from students taking forever to complete the checklist with the engine running on the ground.
Re: Best cub sim
How long a checklist do you need in a cub?
5x5
Re: Best cub sim
Post by 5x5 »
photofly wrote: Fri Jan 13, 2023 5:24 pm How long a checklist do you need in a cub?
Depends who's defining the "need".
Mark Twain
fish4life
Re: Best cub sim
Post by fish4life »
If it’s just a j-3 cub I can’t think of almost anything that would require a checklist. They don’t have flaps, no mixture control, lots don’t even have a battery or electrical system.
Checklist
Mags on both
Primer in
Carb heat off
Go flying
Re: Best cub sim
5x5 wrote: Sat Jan 14, 2023 9:31 am
Assume CAR602.60 is defining the need.
Re: Best cub sim
The FAA approved Flight manual for the PA18-150 does not include a checklist. So a common sense approach to assuring that the airplane is properly configured for the next phase of flight would be wise.
Re: Best cub sim
My interpretation of 602.60 is that the checklist (or placards) that are mandatory for carrying on board don't have to be provided in the flight manual or by the manufacturer. The checklist (or placards) does/do have to "enable the aircraft to be operated in accordance with limitations specified in the aircraft flight manual, aircraft operating manual, pilot operating handbook or any equivalent document provided by the manufacturer;"
It also says:
A checklist or placards referred to in paragraph (1)(a) shall enable the aircraft to be operated in normal, abnormal and emergency conditions and shall include
(a) a pre-start check;
(b) a pre-take-off check;
(c) a post-take-off check;
(d) a pre-landing check; and
(e) emergency procedures.
(my emphasis)
I think that means that if the manufacturer didn't give you a checklist (or placards) including those items, you should create one, in order to be able to carry it on board.
fish4life
Re: Best cub sim
Post by fish4life »
photofly wrote: Sun Jan 15, 2023 1:21 pm My interpretation of 602.60 is that the checklist (or placards) that are mandatory for carrying on board don't have to be provided in the flight manual or by the manufacturer. The checklist (or placards) does/do have to "enable the aircraft to be operated in accordance with limitations specified in the aircraft flight manual, aircraft operating manual, pilot operating handbook or any equivalent document provided by the manufacturer;"
It also says:
(my emphasis)
The manufacturer didn’t make one because a cub is dead simple, can’t even think of something that would be on a post take off check for a fixed gear, no flap, no mixture, no electrical system aircraft
Re: Best cub sim
That was kind of my point. Hard for an FTU to milk a student with checklistitis in a cub.
TeePeeCreeper
Re: Best cub sim
Post by TeePeeCreeper »
photofly wrote: Sun Jan 15, 2023 7:03 pm That was kind of my point. Hard for an FTU to milk a student with checklistitis in a cub.
But it’s a “SuperCub” so that means an extra thingamagigger leaver for the prop I think… Our friends to the south would consider it a “complex” aircraft. Go figure!
goldeneagle
Re: Best cub sim
Post by goldeneagle »
TeePeeCreeper wrote: Mon Jan 16, 2023 2:45 am But it’s a “SuperCub” so that means an extra thingamagigger leaver for the prop I think… Our friends to the south would consider it a “complex” aircraft. Go figure!
Every 'SuperCub' I flew had a fixed pitch propeller, flaps, electric system and a 150hp engine.
Re: Best cub sim
For a Cub, wouldn't most of these conditions apply mostly simultaneously for most of the flying?
Re: Best cub sim
PilotDAR wrote: Tue Jan 17, 2023 11:49 am
Regulations don’t specify the need for different checklists for each of those conditions :)
Squaretail
Re: Best cub sim
Post by Squaretail »
They have not yet made a sim that accurately portrays a cub. Or the ground handling, take off and landing characteristics of any taildragger for that matter.
Re: Best cub sim
Who are “they”, and how do you know?
I WAS Pez
Re: Best cub sim
Post by I WAS Pez »
Soooo, it seems that Redbird actually did one as a one-off for Oshkosh a few years ago.... https://www.youtube.com/watch?v=BVnlfra7gk0
Some articles suggest it may have been available for purchase, but doesn't seem to be on their site any longer.
Not that I'm suggesting this seriously, as others have said, to the OP, tell your buddy to go flying. What he'll learn in a plane like a Cub really can't be taught in a sim....
