Pitt Meadows accident?
CKNW was saying there has been a crash of a light airplane at Pitt Meadows.
bigsky
Post by bigsky »
the professional
Post by the professional »
I did not know the man, but I knew the plane. Condolences to the family.
Mark C-FAFY Serial No 6AFY84
Common Name Rand Model RAND KR-2
Base Of Op. - Country CANADA
Base Of Op. - Province British Columbia
Base Of Op. - Location Abbotsford
File Location Vancouver Basis for Eligibility for Registration Amateur Built - CAR Standard 549
Type of Registration Private
Category Aeroplane Weight (Kgs) 453
Manufacturer ADRIAN H. CARTER
Year of Manufacture 1986
Country of Manufacture CANADA
Owner Registration
Owner Registered Since 2000-01-05 Last Certificate of Registration Issued 2003-05-06
Engine Piston Number of Engines 1
Wilbur
Post by Wilbur »
greenwich
Post by greenwich »
Sad news...
Sadder is the fact that home-builts crashing seems to be an annual occurrance out there in the Delta.
G
"Slow and steady wins the race"
V1 Rotate
Post by V1 Rotate »
From what I heard this is what happened:
The aircraft in question was landing on 26L and was told to pull up and go around. He initially refused to comlpy with the instrcuction and had to be told again. He then did pull up and go around and proceded to make a tight circuit with all turns steeply banked and low. Seems that he either stalled or spiraled out of of the turn to final.
"I have control!"
