Upgrade requirements.
twinpratts
Post by twinpratts »
What are the requirements for a new hire FO to upgrade at jazz?
Obviously ATPL, but how about PIC, time on company aircraft, multi time requirements etc?
Thanks in advance
Dash.Trash
Re: Upgrade requirements.
Post by Dash.Trash »
- ATPL
- Pulse
twinpratts
Follow up question; is the YYC base closing?
canadian_aviator_4
Post by canadian_aviator_4 »
twinpratts wrote: Mon Aug 07, 2023 8:49 pm Follow up question; is the YYC base closing?
Also curious what jazz future plan is for Yyc?
cdnavater
Post by cdnavater »
twinpratts wrote: Mon Aug 07, 2023 8:11 pm What are the requirements for a new hire FO to upgrade at jazz?
Thanks in advance
ATPL and a pulse is not accurate, if you do not have the experience to back up your choice to bid it, you will not be successful.
No instructors with an ATPL were successful in the upgrade process, one was fired but the rest had to go back and repeat some of the training to be an FO. We even had some very experienced pilots, including with RJ time not make it through.
So no, a pulse won’t help, you need a brain too and if you’re a 1500 hour ATPL holding instructor bidding left seat on an RJ, you lack brain capacity.
The same pilots with a few thousand hours take the FO spot and come back after a year on the aircraft for the left seat have a much higher success rate, not perfect but still higher and from what I’ve seen of some of the new hires, a year won’t be enough.
QKZXKV
Location: Nickelbelt/Concrete Jungle/Lobster country...
Post by QKZXKV »
Nothing official but it's shrinking. The RJ will have only departures to YEG in the fall, and the Q very few departures. Jazz is becoming mainly a YYZ operation.
