not a delay you hear in the winter too often
rigpiggy
Post by rigpiggy »
Delayed this am. -16 in yyc, the person in charge of the air conditioning pushed the Apu to full hot. Cabin was 38 degrees, delayed boarding until cabin came down to 25. As a kid I used to crank the thermostat after a cold walk from school, house would be 90f(ya I'm old).
The q400 uses a duct regulated air temp to set the acm bypass valve. Please do not set to full hot, otherwise we shall have more delays
Pig
dontcallmeshirley
Re: not a delay you hear in the winter too often
Post by dontcallmeshirley »
rigpiggy wrote: Wed Oct 25, 2023 4:48 am Delayed this am. -16 in yyc, the person in charge of the air conditioning pushed the Apu to full hot. Cabin was 38 degrees, delayed boarding until cabin came down to 25. As a kid I used to crank the thermostat after a cold walk from school, house would be 90f(ya I'm old).
Pig
And why was that a delay? Cooling the cabin in -16 degrees OAT with the APU functioning normally should take a matter of 3-5 minutes at most.
CaptDukeNukem
Post by CaptDukeNukem »
dontcallmeshirley wrote: Sun Oct 29, 2023 6:21 pm
Pig
Or just open a couple doors. -16 cools a cabin real fast.
Return to “WestJet Encore”
