Sorry for your loss CaptDukeNukem. I am not judging the actions of the Bearskin crew. The crew did not have much time or altitude to analyse the failure that they had. I'm sure they did the best they could but sadly the crew and several passengers lost their lives.rookiepilot wrote: ↑Fri Mar 08, 2024 2:23 pmYeah, and you also don’t tend to die in a simulator, and you know an engine failure is coming, too.CaptDukeNukem wrote: ↑Wed Mar 06, 2024 9:45 pmI knew the FO. Armchair quarterback is a shitty way to analyze things.
We can not stick our head in the sand carry on as normal and hope for the best. We need to learn from this crash and realize that the TPE331 has failure modes that are very different from a piston or PT6A engine.
The Bearskin crew had about 30 seconds to analyse the failure they were dealing with. That is why pilots operating the TPE331 need to know the engine failure modes and memory drills cold and with instant recall.
The TPE331 is a single shaft engine with the propellor directly connected to the power turbine and gas turbine. It DOES NOT have autofeather! It does have Negative Torque Sensing (NTS) system that can activate with a total engine failure by increasing propellor pitch to reduce drag. But NTS only gives you a few extra moments to react and feather the failed engine.
When a TPE331 suffers internal damage, the engine may continue to run but at a reduced speed. If this happens the propellor is driven towards 0 pitch in an effort by the governor to increase to selected engine speed. The NTS most likely will not be active and the result is you have a 9+ ft spinning propeller at 0 pitch causing massive drag.
The only way out of this is to quickly identify the failing engine and immediately pull the STOP/FEATHER lever on the affected engine. This action shuts off fuel to the engine, dumps oil pressure from the propellor allowing the spring in the propellor dome to drive the prop to feather.
If the gas turbine stops producing power, then the Negative Torque Sensing system should dump oil pressure from the propellor and partially feather the propellor. This gives you a few seconds more time to react but you still need to identify the failed engine, pull the STOP/FEATHER lever to complete the engine shutdown and feather the prop.
I'm not sure what your point is rockiepilot? That is why we train in simulators, to experience what could kill us in the real airplane. The simulator allows us to train for events like this.
Unfortunately, I do not think there are any TPE331 full motion simulators operational anymore.
So operators of the TPE331 need to know the engine failure modes and memory drills cold. They need to train these critical items in the airplane but are limited to what can safely be accomplished.
